nreslifer Samba Member
Posted: Sat Jul 23, 2016 8:37 am Post subject: Steering wheel nut |
There is no washer installed with a steering wheel nut correct? |
bluebus86 Banned
Posted: Sat Jul 23, 2016 9:39 am Post subject: Re: Steering wheel nut |
nreslifer wrote: |
My recollection and my manual both indicate a washer is to be under the nut on the steering wheel.
So, you are supposed to have a washer there
good luck _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
EVfun Samba Member
Posted: Sat Jul 23, 2016 9:46 am Post subject: Re: Steering wheel nut |
2 nuts and 1 washer in this order:
1. washer against the steering wheel
2. nut against the washer
3. nut to hold onto the steering wheel
I'll volunteer for that last position. _________________
Wildthings wrote: |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Sat Jul 23, 2016 1:17 pm Post subject: Re: Steering wheel nut |
That and a lot more available in the parts manuals here:
http://oacdp.org/
Right now the type 1 manual is available thru the "Upcoming" button at top right. _________________ In Stereo, Where Available! |
glutamodo The Android
Joined: July 13, 2004 Posts: 26323 Location: Douglas, WY
Posted: Sat Jul 23, 2016 1:31 pm Post subject: Re: Steering wheel nut |
by the way, that washer, is a big spring washer (wave style)
_________________ Andy T.
Bruce Samba Member
Posted: Sun Jul 24, 2016 12:02 pm Post subject: Re: Steering wheel nut |
59 and earlier did not use a washer. Instead the nut had part of the hex turned round to half the thickness.
The 56-59 steering wheel has a counter bore for this odd nut to fit into.
60-mid 74 used a standard half nut, M18 with single wave flat washer.
http://www.thesamba.com/vw/classifieds/detail.php?id=1652866 _________________
Posted: Sun Jul 24, 2016 12:30 pm Post subject: Re: Steering wheel nut |
Thanks everyone for responding,this car has taken a long time to do.It's finally getting put back together.Only thing I can think of is Murphy has been sneaking
into the garage over the years and taking a part here and there. |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34013 Location: Conejo Valley, CA
Posted: Sun Jul 24, 2016 2:43 pm Post subject: Re: Steering wheel nut |
nreslifer wrote: |
That's alright. As you rebuild things, you will have parts left over. After a few years it will all balance out.
