volwing Samba Member
Posted: Sat Jul 23, 2016 4:32 am Post subject: Motor Size Determination |
What visable difference is there between a 1600 and 1776? Is the spacing between the cylinder studs and the cylinder fins a clue? |
Posted: Sat Jul 23, 2016 5:15 am Post subject: Re: Motor Size Determination |
This is #2 cylinder of my motor in question.
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76911 Location: Sneaking up behind you
Posted: Sat Jul 23, 2016 8:44 am Post subject: Re: Motor Size Determination |
You have to remove the head and measure the cylinder. _________________ Glenn
Member #1009
#BlueSquare |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31362 Location: Hot Arizona
Posted: Sat Jul 23, 2016 12:34 pm Post subject: Re: Motor Size Determination |
Glenn wrote: |
You have to remove the head and measure the cylinder. |
Or you can remove the head and measure the piston diameter. Sometimes you can read the stamped mm diameter on the piston crown. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
EVfun Samba Member
Posted: Sat Jul 23, 2016 1:11 pm Post subject: Re: Motor Size Determination |
I don't know if anyone has done this, but it would seem that you could get some idea if you could semi-accurately measure how close the top of the cylinder is the the head studs at the head. You would be trying to determine if the head was opened up for a larger cylinder. _________________
Wildthings wrote: |
modok Samba Member
Joined: October 30, 2009 Posts: 26785 Location: Colorado Springs
Posted: Sat Jul 23, 2016 3:34 pm Post subject: Re: Motor Size Determination |
EVfun thanks for saying what I was thinking. Logic (not always accurate) tells me a measurement taken relating the stud to fins makes sense. Hoping someone could measure a 1776 so I could compare. |
