redbug64 Samba Member
Joined: July 21, 2005 Posts: 513 Location: Fairfax/Essex, Vermont
Posted: Fri Jul 22, 2016 5:04 am Post subject: KF help |
Hey folks,
I'm looking at Klassic Fabs sight trying to make a list of metal I would like to purchase for my double cab. In the included pic, would you consider the large missing part the "under 3rd window rocker"? Behind that there is a vertical seam and a narrow piece between the cut area and the bedside. What might that be called? Thanks!
_________________ Jason Arms
Fairfax, Vermont
1954 Standard Beetle
1965 Firetruck Red Double Cab
1975 Porsche 911
1984 Rabbit L
1988 Scirocco 16v
Random Toyota daily drivers because winter. |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7047 Location: Lawrenceville, Ga
Posted: Fri Jul 22, 2016 7:00 am Post subject: Re: KF help |
redbug64 wrote: |
Hey folks,
looks like the left hand side c pillar
https://www.klassicfab.com/klassicfab/en/192-c-pillar-busdouble-cab-rhd-left-side _________________ regards
Uli
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Fri Jul 22, 2016 7:16 am Post subject: Re: KF help |
redbug64 wrote: |
Hey folks,
For the left side, I think you need
KF969/KF970 is the long piece under the window.
KF404/KF406/KF408 D pillar on the left side
No, that is for a RHD where there is a c pillar on the left side.
A LHD DC has an A, B and D pillar on the left side, and a A, B, C, D on the right hand side
Posted: Fri Jul 22, 2016 7:17 am Post subject: Re: KF help |
I'm confused on the "c" pillar. A is the front where the front door hinge mounts, b would be the middle where the rear door hinge mounts, c would be the one behind the rear door and the thin part after the under 3rd window..?? I don't see B pillar and it looks like he is calling the b a c?? _________________ Jason Arms
Fairfax, Vermont
1975 Porsche 911
1984 Rabbit L
1988 Scirocco 16v
Posted: Fri Jul 22, 2016 7:25 am Post subject: Re: KF help |
nlorntson wrote: |
redbug64 wrote: |
Hey folks,
A LHD DC has an A, B and D pillar on the left side, and a A, B, C, D on the right hand side |
you are right, i was thinking of the correct part but clicked on the wrong one _________________ regards
Uli
Posted: Fri Jul 22, 2016 7:29 am Post subject: Re: KF help |
Posted: Fri Jul 22, 2016 12:41 pm Post subject: Re: KF help |
Yes. I fully understand the lettering and locations. Thanks for the diagram. my question is that I'm trying to decifer what parts to order from kf to fix the loewer parts of my cab area. Here is what I think I understand:
Kf970 would be the outside skin of the lower portion behind the drivers door
Kf961 would be the same thing but smaller behind the rear door on the pass side
Kf498 would be the rocker (inside and outside) below the rear cargo door
Kf480-481 middle pillar.. What is this part?
Kf452 is called c pillar but it has door hinge mounts???
Kf480/481 middle pillar. Is this the one between the cab side and bed side? It seems like "pillar" is used to describe inside supports and not outside panels?? I guess the lack of photos and weird labeling is confusing. _________________ Jason Arms
Fairfax, Vermont
1975 Porsche 911
1984 Rabbit L
1988 Scirocco 16v
Posted: Fri Jul 22, 2016 1:31 pm Post subject: Re: KF help |
Kf970 would be the outside skin of the lower portion behind the drivers door - YES
Kf961 would be the same thing but smaller behind the rear door on the pass side - YES
Kf498 would be the rocker (inside and outside) below the rear cargo door - YES
Kf480-481 middle pillar.. What is this part? - see below
Kf452 is called c pillar but it has door hinge mounts??? - No hinge mounts that I can see. For reference look at KF454 which is the 12" long version
Kf480/481 middle pillar. Is this the one between the cab side and bed side? - YES, on the inside I believe.
It can help to google the KF part numbers as some of the resellers do have pictures. |
Posted: Fri Jul 22, 2016 1:51 pm Post subject: Re: KF help |
Kf 452 and 53 are different lengths of the same part as far as I can tell. One said above hinge... I'm also then not seeing the outside sheet metal narrow before bedside.. The "d" pillar outside lower part.. Googling gets me pics of swimsuits, not kf parts.. _________________ Jason Arms
Fairfax, Vermont
1975 Porsche 911
1984 Rabbit L
1988 Scirocco 16v
Posted: Thu Jul 28, 2016 5:15 am Post subject: Re: KF help |
So in the above arrowed pic, what kf part is "B" on the right side and "D" on both sides? That's my question here. _________________ Jason Arms
Fairfax, Vermont
1975 Porsche 911
1984 Rabbit L
1988 Scirocco 16v
VWsArent4Hippies Samba Member
Joined: April 13, 2005 Posts: 3079 Location: The Bull City
Posted: Thu Jul 28, 2016 9:23 am Post subject: Re: KF help |
I made these for reference, hope it helps:
