GoWestYoungMan Samba Member
Joined: September 30, 2013 Posts: 81 Location: northern Canada (brrrrr!!!)
Posted: Thu Jul 21, 2016 4:20 pm Post subject: How do you connect this darn shift coupler? |
http://imgur.com/a/Jumlp
Ok, so I've read these shift couplers are not recommended because they can break. Thing is getting delivery of another one is going to take a week or two and I'm hoping to at least use this one for now while I fix my clutch issues.
But the transmission shaft and the shifter rod do NOT line up, they are at different angles, with the shifter rod angling downwards and there's no way this coupler will slide over both shafts at the same time because it's not bendable. So how the heck do you get it on? |
jsturtlebuggy Samba Member
Posted: Thu Jul 21, 2016 4:42 pm Post subject: Re: How do you connect this darn shift coupler? |
You are never going to be able to use a stock early coupler at the angle you have there between the hockey stick and shift rod.
You are going to have to use some kind of u-joint or the later coupler that is square and can pivot. I think it was in 1965 that it changed.
I see you have adjuster at the shift rod, the adjuster for the later ones has a 10mm, real close to 3/8in hole in it for the pivot bolt. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
dustymojave Samba Member
Posted: Thu Jul 21, 2016 4:47 pm Post subject: Re: How do you connect this darn shift coupler? |
That sort of misalignment will ensure the coupler will fail, regardless how well it's made.
There's a guy CNC machining couplers which will deal with the mis-alignment just fine. I read a thread about it in the last couple of weeks. I'll look and see if I can find it. _________________ Richard
SoCalBajas Member
Dark Earth Samba Member
Posted: Thu Jul 21, 2016 5:01 pm Post subject: Re: How do you connect this darn shift coupler? |
Here's the thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=656824&highlight=shift+coupler
I hear what you're saying about getting it going for a little while. But there's no way that I can recommend to quick fix that. _________________ Richard
SoCalBajas Member
Posted: Thu Jul 21, 2016 5:10 pm Post subject: Re: How do you connect this darn shift coupler? |
Fair enough. But mine doesn't have the bolt hole in shift rod for that beautiful aluminum connector. Do I just drill one through it? |
Posted: Thu Jul 21, 2016 5:39 pm Post subject: Re: How do you connect this darn shift coupler? |
GoWestYoungMan wrote: |
Did you read all the way to the end of that thread?
My last post was:
Quote: |
I wasn't saying to drill a hole through the hockey stick shaft in the trans. I was suggesting to loosen the jam nut on the shift adjuster, remove the end of the adjuster,
and drill THAT hole through so you can use one of the machined aluminum couplers shown above.
The adjuster piece would then need to be turned 90° so the bolt passes through the adjuster left to right instead of up or down.
You might want to ask the guy who makes the couplers to make yours to fit a 1/4" allen shoulder bolt. I firmly believe it would be strong enough and would be a smaller hole through that adjuster piece. |
SoCalBajas Member
Posted: Thu Jul 21, 2016 6:56 pm Post subject: Re: How do you connect this darn shift coupler? |
Thanks. I think I got it now. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20378 Location: Just a tiny bit west of Yosemite Valley
Posted: Thu Jul 21, 2016 7:03 pm Post subject: Re: How do you connect this darn shift coupler? |
Get adjustable shifr rod adapter for late model and exchange center piece of early one for later one....
