Brent'sGarage Samba Member
Joined: January 18, 2016 Posts: 22 Location: Dallas, Tx
Posted: Thu Jul 21, 2016 8:52 am Post subject: Best product for Brake system flush |
I have read that I can use Denatured alcohol to flush my brake system. Can anyone verify or suggest a better product to use?
Thanks, Brent |
slalombuggy Samba Member
Posted: Thu Jul 21, 2016 8:53 am Post subject: Re: Best product for Brake system flush |
Brake fluid
brad |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Thu Jul 21, 2016 8:55 am Post subject: Re: Best product for Brake system flush |
What he said. why complicate things? _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
bug1200 Samba Member
Joined: July 07, 2015 Posts: 222 Location: Philippines
Posted: Thu Jul 21, 2016 8:56 am Post subject: Re: Best product for Brake system flush |
Brent'sGarage wrote: |
Thanks, Brent |
i just use plain brake fluid.
i just bleed each wheel till clean brake fluid comes out, i think thats enough to remove the crud and moisture if any, since brake fluid is quite corrosive anyway. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31385 Location: Hot Arizona
Posted: Thu Jul 21, 2016 9:55 am Post subject: Re: Best product for Brake system flush |
bug1200 wrote: |
I just use plain brake fluid.
This _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Mos6502 Samba Member
Posted: Thu Jul 21, 2016 4:21 pm Post subject: Re: Best product for Brake system flush |
Thanks, Brent |
Where did you hear this? I'm pretty sure doing that would destroy the rubber in the system. Just use brake fluid. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51156 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Jul 21, 2016 4:42 pm Post subject: Re: Best product for Brake system flush |
Flushing for what?, just a fluid change?, or switching from DOT3 to DOT5?
Unless you are planning on opening each part of the system and blowing it out with compressed air clean new fluid as all you need. Let it drain overnight and refill in the AM, the act of bleeding will make sure there's new fluid everywhere and the flow will wash out the sediment. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
zoobyshoe Samba Member
Joined: June 26, 2014 Posts: 461 Location: San Diego, Ca.
Posted: Thu Jul 21, 2016 4:45 pm Post subject: Re: Best product for Brake system flush |
Autozone sells a 1 gallon container of brake fluid for $20. A person could flush out their brake system pretty well with that much. |
Posted: Sat Jul 23, 2016 5:34 pm Post subject: Re: Best product for Brake system flush |
I have always used clean brake fluid for a flush..Somewhere, I don't remember where, mentioned the denatured alcohol...sounded strange to me too, and I was worried especially about the rubber in the Master cylinder and calipers coming in contact with it. I spent a lot of money to make this right. I didn't want to do it unless it was the best idea.
Here's the deal: I now have gone completely through the brakes, new calipers, new Master cylinder, new reservoir, new hoses to MC...everything. The MC still has some contaminated fluid in it and is still in the car and I didn't want that to cause problems at my Varga calipers or else I was going back to drums again!
Again, thanks to all for the feedback |
