mraible Samba Member
Joined: December 27, 2013 Posts: 70 Location: Denver, CO
Posted: Thu Jul 21, 2016 4:18 am Post subject: 250 AMP Alternator with a 3.2L SC Engine? |
Hello all,
I have a 1966 VW Bus with a Porsche 3.2 SC Engine in it. I’ve only had it finished for a few months, but I’ve had a blast driving it. Next month, I hope to install a stereo in my bus that draws 240 amps at high volume (120 amps at low). My stereo installer is recommending I get an AMP that can put out 250 amps. Do you know if Porsche makes an alternator that big? If so, can you recommend one for this engine?
My installer said a bigger alternator might draw away from the horsepower. Do you know how much it might draw and if there’s a way to get that HP back (e.g. bigger carbs)?
Thanks,
Matt _________________ '66 Porsche Bus
'90 H6 Syncro |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21474 Location: Oklahoma City
Posted: Thu Jul 21, 2016 9:32 am Post subject: Re: 250 AMP Alternator with a 3.2L SC Engine? |
mraible wrote: |
Hello all,
Thanks,
Matt |
Are you sure you don't mean WATTS?.... .......most large diesel rigs dont have over 140 amps......
Now.....unless this is one of the stero systems that uses upwards of 1000 watts.....for "Dba drag racing".....as its called (who has the loudest wall of sound.....contests).
In that case.....yes there are a couple of companies that make alternators just for that. I wi drop ij a link in a few. Ray |
Posted: Thu Jul 21, 2016 9:34 am Post subject: Re: 250 AMP Alternator with a 3.2L SC Engine? |
Yep, I'm sure I don't mean watts. Output is expected to be 2400 watts total. I like to feel my music. _________________ '66 Porsche Bus
'90 H6 Syncro |
AtLeeb Samba Member
Joined: August 31, 2012 Posts: 1 Location: Los Angeles
Posted: Mon Dec 26, 2016 12:35 pm Post subject: Re: 250 AMP Alternator with a 3.2L SC Engine? |
You may have already found a solution to this, but if you haven't, I'd do a little more research on the how your electrical system can support your planned stereo gear. E.g.:
https://www.amazon.com/gp/product/B004LQ1QSY/ref=o...PDKIKX0DER
Multiple HD batteries wired in parallel may be a viable alternative. You've got a Transporter so you have the room.
As for the alternator in your 3.2 engine, there might be a larger capacity, non-factory unit that can fit into the fan housing area.
Less complicated: Source the correct alternator and mount it externally using a modified A/C compressor bracket or other custom bracket. As for the bearing support for the factory fan, use the factory alt. housing w/o the rotor and field windings. |
