D78Q85V87 Samba Member
Joined: December 27, 2012 Posts: 120 Location: Washington
Posted: Wed Jul 20, 2016 10:38 pm Post subject: Headlight issues |
Hello all,
I have a 1987 Wolfsburg weekender Vanagon and have just discovered an issue with the headlights. They will turn on when the key is off or with auxiliary power, but once the van is started, they turn off. They will not stay on while running. Does anyone have any idea how I could get this fixed?
Thanks for your time and knowledge, I really appreciate they help. |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7754 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Thu Jul 21, 2016 6:35 am Post subject: Re: Headlight issues |
Do you lose anything else when the headlights go off? (Fan, wipers, etc.)
This could point to bad ignition switch or the related "load reduction relay".
Check it & report back... _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Thu Jul 21, 2016 8:19 am Post subject: Re: Headlight issues |
dhaavers wrote: |
Check it & report back... |
Thank you! I will look at that later today. |
Posted: Fri Jul 22, 2016 5:54 pm Post subject: Re: Headlight issues |
dhaavers wrote: |
I am sorry for getting back to you so late, I have been working and helping out around the house and this was the soonest I could get a look at it. I went through everything and all fans wipers and other lights work. The only thing that doesn't work is the driver's side blinker. It only turns on but it doesn't blink when on to signal a left turn. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32584 Location: Reading Pennsylvania
MURRAYMW1 Samba Member
Posted: Fri Jul 22, 2016 8:46 pm Post subject: Re: Headlight issues |
Replace the bulb. _________________ Mark
85 Westy - current
Past - 85 weekender; 72 camper, 65 van; many bugs 54 - 72 |
Posted: Fri Jul 22, 2016 9:41 pm Post subject: Re: Headlight issues |
djkeev and MURRAYMW1 thank you both for your replies. Speaking to the grounds point I just finished cleaning them all up. To clarify, The headlights are fully functional and on when the key is in auxiliary power, they all work great, but once your turn the van on and it's idling, they turn off. |
Posted: Sat Jul 23, 2016 5:54 pm Post subject: Re: Headlight issues |
Thank you for your reply. I just ordered the part and it is on it's way. |
Posted: Sat Jul 23, 2016 7:37 pm Post subject: Re: Headlight issues |
djkeev wrote: |
Vanagon does not have an auxillary key position.
Off
On
Start
If On powers the headlights and all works well before you turn to start.....
Then once you turn to Start and the return spring pushes you back to On it doesn't work.
And your grounds are known good......
I suspect the ignition switch contacts are burned.
Dave |
It is on it's way. I just ordered it. Thank you very much for your reply and help I really appreciate it. |
Posted: Sun Jul 24, 2016 10:17 pm Post subject: Re: Headlight issues |
djkeev wrote: |
D78Q85V87 wrote: |
djkeev wrote: |
Off
On
Start
Dave |
Please do keep in mind that I am 3,000 miles away (unless you're in DC) And guessing on needed repairs via keyboard.
The ignition switch is a known weak electrical link on older VW's.
No harm will come from replacing it and it may actually fix your ussue at hand.
Dave |
Its a less than $7 part so I figure why not it will probably need to be replaced eventually like you said and at the very least it will be something we can rule out as not the problem. When I get it and put it in if it don't work I will continue to look for help. Regardless, thank you for your assistance I really appreciate it. |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16501 Location: Brookeville, MD
Posted: Mon Jul 25, 2016 9:27 pm Post subject: Re: Headlight issues |
I just got the part today and I tried it without taking the whole steering wheel apart like on of you said (thank you for that by the way it saved a TON of time) After all of that that wasn't the issue.
So to reiterate my problem in case others are just coming in, the headlights will not stay turned on when the van is running. When the key is off the headlights are off, when the key is turned on the headlights are on, after the key has turned to start and the van has started, the headlights turn off. Does anyone have any idea what is going on?
Thank you to all who have submitted comments and proposed solutions thus far I am very grateful to you for sharing your knowledge with me, and grateful for the assistance. |
Merian Samba Member
Posted: Mon Jul 25, 2016 10:24 pm Post subject: Re: Headlight issues |
check the relays for the lights & the grounds
$$ on ign. switch is not wasted as it will surely fail eventually - take it with you as a spare _________________ .... |
Posted: Tue Jul 26, 2016 9:12 am Post subject: Re: Headlight issues |
Thanks guys, I will have another look at the grounds and check relays. I was also thinking maybe wires go crossed because there is a new stereo in the van that is hooked through the ignition, could that be the problem? |
jmranger Samba Member
Posted: Tue Jul 26, 2016 9:42 am Post subject: Re: Headlight issues |
Do you have the same behavior with high and low beams?
With the engine running, are you able to flash your headlights?
What about the parking lights? Working as expected?
Any recent work on the van? The new stereo - before or after the issue appeared?
Do you know when the issue appeared, or could it have been like that, unnoticed, for a long time?
Has your van been upgraded with headlight relays? |
pablum Samba Member
Posted: Tue Jul 26, 2016 2:26 pm Post subject: Re: Headlight issues |
Not sure if this helps, or if I'm being too simple minded, or perhaps I'm not recalling this correctly, but: is that not the opposite of the normal behavior? iirc, my headlights won't go on when I've flipped the switch until I've started the engine.
To me that says it's a logic problem, like two leads are switched, or something like that.
Just sayin'. |
Merian Samba Member
Posted: Tue Jul 26, 2016 2:55 pm Post subject: Re: Headlight issues |
yeh - who put that stereo in? _________________ .... |
