TimBlack Samba Member
Posted: Tue Jul 19, 2016 8:55 am Post subject: Carb Confused |
73 1600 DP Ghia hard to start for a while. Acted like flooding that went away. Then it went to once starting, it flooded out. The accelerator pump fine. Float fine. Looked down carb with a flashlight after trying to start and witnessed the big aluminum main fuel feed just pours gas down the throat.
What do I do now? |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Tue Jul 19, 2016 9:08 am Post subject: Re: Carb Confused |
check the float valve to make sure it is shutting off the fuel.And check to see if it is a genuine Solex or a crappy aftermarket. _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
c21darrel Samba Member
rcooled Samba Member
Joined: September 20, 2008 Posts: 2504 Location: Santa Cruz, CA
Posted: Tue Jul 19, 2016 11:00 am Post subject: Re: Carb Confused |
TimBlack wrote: |
...the big aluminum main fuel feed just pours gas down the throat. What do I do now? |
The fuel level in the float bowl is too high. It should be about 18mm (.70") from the top edge of the bowl with the float in place. This problem is usually caused by a faulty needle valve or a leaking float. Another cause could be fuel pressure that's too high, but this is less likely when using a stock fuel pump.
c21darrel wrote: |
shouldnt the squirter be brass? |
Yes, the accelerator pump nozzle is brass, but the main fuel discharge arm is cast into the lower carburetor body and is of the same material. _________________ '63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
'62, '63, '65, '69 Bugs (all long gone) |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24735 Location: Olympia Wash Rinse & Repeat
Posted: Wed Jul 20, 2016 8:08 pm Post subject: Re: Carb Confused |
Float chamber breather pipe at 12 O'Clock.
Accelerator nozzle at about 4 to 5 O'Clock. _________________ In Stereo, Where Available! |
