andrewvwclassic Samba Member
Joined: January 25, 2012 Posts: 920 Location: los angeles
Posted: Mon Jul 18, 2016 10:45 pm Post subject: New cable - clutch won't engage |
hey guys i was puting a new bowden bracket on because i noticed the old one was broken on one side and hanging. anyway I now cannot engage the clutch and shift into gear. When I attempt to shift the gar just jerks and stops. could it be a sensor or did I do something to the control arm for the throwout. Any advice would be much appreciated. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17968 Location: Eugene, OR
Posted: Tue Jul 19, 2016 4:44 pm Post subject: Re: New cable - clutch won't engage |
It is all about the bowden tube flex/length/no drag etc to get the clutch to release properly. No sensors as it is strictly a mechanical operation. The clutch/throwout bearing/clutch arm/clips/cable all have to match & be adjusted correctly to get good shifting! _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
dirtslinger Samba Member
Joined: January 20, 2009 Posts: 392 Location: South Bay, So Cal
Posted: Tue Jul 19, 2016 8:41 pm Post subject: Re: New cable - clutch won't engage |
You more than likely just need to tighten up on the wing nut adjuster. _________________ 1967 Class 5
1970 Class 11 HSD Racing
1972 5/1600 V-MAR/Rasta Baja
1956 Baja
1960 Sand Rover buggy
1965 Street bug
1967 Squareback |
Posted: Tue Jul 19, 2016 9:59 pm Post subject: Re: New cable - clutch won't engage |
ok guys dropped the motor and everything checked out too bad it did not occure to me that it was the clutch plate rusted from sitting the last 7 months jammed up before I put the engine back on. Any methods that will save me from dropping the engine again to free up the pressure plate. I already tried to start it in 1st,2,nd,3rd, ect. Can I get more torque if I try to drive it from first gear and rev it up and down. any other ides would be helpful. thanks for all the great imput. I forgot to mention that I have been doing a lot of rusting and electrical and the car has been sitting. I got a new set of empi 34's dialed in and am wanting to get it on the road asap. |
Posted: Wed Jul 20, 2016 8:57 am Post subject: Re: New cable - clutch won't engage |
You get a 'do over' until you get it right. Better to follow the Manual & not risk breaking the clutch/transmission? _________________ https://imgur.com/user/FisherSquareback/posts
