sled Samba Member
Posted: Fri Jul 22, 2016 11:20 am Post subject: Re: Alaskan Original Paint 58 PGSG |
Yes it is, but it would be better to get a nice hinge and reweld it into the door. Either way you will end up paint matching so might as well have a hinge with solid fingers _________________ drive your split. |
Chris Paterson Samba Member
Joined: February 21, 2010 Posts: 1068 Location: Newbury Park, CA
Posted: Fri Jul 22, 2016 11:22 am Post subject: Re: Alaskan Original Paint 58 PGSG |
sled wrote: |
Yes it is, but it would be better to get a nice hinge and reweld it into the door. Either way you will end up paint matching so might as well have a hinge with solid fingers |
So it just welds into the inside of the door. I have to find one. Maybe I'll put up a want ad, or if someone has one they'd sell PM me! _________________ - Chris
58' PGSG |
srfndoc Samba Member
Posted: Fri Jul 22, 2016 11:39 am Post subject: Re: Alaskan Original Paint 58 PGSG |
Chris Paterson wrote: |
sled wrote: |
So it just welds into the inside of the door. I have to find one. Maybe I'll put up a want ad, or if someone has one they'd sell PM me! |
I think they are actually press fit or secured with a type of rivet. Either way they are really hard to find. I looked a long time for one until this guy popped up with some NOS ones:
http://www.thesamba.com/vw/classifieds/detail.php?id=1862836
Wrong year for you but what your looking for. _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
Posted: Fri Jul 22, 2016 11:43 am Post subject: Re: Alaskan Original Paint 58 PGSG |
srfndoc wrote: |
sled wrote: |
Wrong year for you but what your looking for. |
I saw that one, would be nice if it was correct for my bus! I'm sure someone has a junk cargo door they'd be willing to sell me. I put up a wanted ad and I'll just wait and watch. _________________ - Chris
58' PGSG |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10196 Location: Petaluma, CA
Posted: Fri Jul 22, 2016 12:21 pm Post subject: Re: Alaskan Original Paint 58 PGSG |
Could you just replace the hinge pin and ignore the broken finger? At least that would make it relatively functional, and you could skip blending the paint. |
Posted: Fri Jul 22, 2016 12:29 pm Post subject: Re: Alaskan Original Paint 58 PGSG |
campingbox wrote: |
That's a thought. I can tell the pin is rusted in there though so it would involve drilling it out, most likely. That's how I'm assuming the fingers broke on it in the first place. But then again, if I mess it up I could just go back to the other plan and I don't lose anything. _________________ - Chris
58' PGSG |
Stocknazi Samba Member
Posted: Fri Jul 22, 2016 4:58 pm Post subject: Re: Alaskan Original Paint 58 PGSG |
campingbox wrote: |
That's a thought. I can tell the pin is rusted in there though so it would involve drilling it out, most likely. That's how I'm assuming the fingers broke on it in the first place. But then again, if I mess it up I could just go back to the other plan and I don't lose anything. |
You could remover the hinge half from the bus, wrap a wet rag around it, leaving only the finger exposed and heat it with a torch and drive the pin out. Drilling it out would be a PITA.
You will have to remove the hinge to replace it, so might as well get those 2 screws out. _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Fri Jul 22, 2016 5:21 pm Post subject: Re: Alaskan Original Paint 58 PGSG |
many years back there was a PGSG '58 from Alaska for sale here in Oklahoma too @ $1500... shouldda' bought it... had to do a double take with yours... real nice... Enjoy. _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
Posted: Sat Jul 23, 2016 8:51 am Post subject: Re: Alaskan Original Paint 58 PGSG |
Working on the little details
58' PGSG |
Posted: Tue Jul 26, 2016 9:18 pm Post subject: Re: Alaskan Original Paint 58 PGSG |
Here's my middle seat mounting clamp I guess
Boy that's disappointing!
I took the window frame off the passenger side because there was no vertical divider and the window wouldn't slide. So I bought a couple dividers and painted them and got the seal etc. It turns out regular felts were used on the bottom instead of sigla and that's why it wouldn't slide.
More surprisingly, there was not one single bolt or screw in the whole window frame holding it on! So no front or side m8 bolts. No m8 screws in the back and no m6 nuts holding the frame on. Fortunately I had the bolts and screws lying around, even the wavy washers. _________________ - Chris
58' PGSG |
AlteWagen Troll
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
Posted: Wed Jul 27, 2016 12:08 am Post subject: Re: Alaskan Original Paint 58 PGSG |
EverettB wrote: |
I feel like your comment indicates you know this but:
That is Brazilian garbage.
Yes I know. I've been buying up original seat hardware. Thanks for the link. I was more intrigued by the ingenious bolt and nut configuration and how that somehow held the seat down to the floor slots. _________________ - Chris
58' PGSG |
Posted: Thu Jul 28, 2016 8:58 pm Post subject: Re: Alaskan Original Paint 58 PGSG |
Yes all 4!
But interestingly, the two silverish ones say 3a and 3b the other two do not. What does it mean? _________________ - Chris
58' PGSG |
Posted: Thu Jul 28, 2016 11:45 pm Post subject: Re: Alaskan Original Paint 58 PGSG |
EverettB wrote: |
I've noticed they have different codes like that but haven't kept track.
I figured they were production codes of some sort.
In the photo I posted above, it looks like some of them say 3c too. |
I think I won't get too crazy about having matchy matchy. It might knock down the value of the bus a bit... but it's a compromise I'm willing to make for expediency. _________________ - Chris
58' PGSG |
Posted: Fri Jul 29, 2016 7:03 am Post subject: Re: Alaskan Original Paint 58 PGSG |
EverettB wrote: |
I think I won't get too crazy about having matchy matchy. It might knock down the value of the bus a bit... but it's a compromise I'm willing to make for expediency. |
Haha, I thought about telling you you better get matching ones but I don't think they matched on original Buses either.
I'm pretty sure the ones I pposted above are all from the same Bus since they all have the same sort of blue overspray on them. _________________ How to Post Photos
Posted: Fri Oct 28, 2016 2:56 pm Post subject: Re: Alaskan Original Paint 58 PGSG |
Got these og paint wheels and I'm pretty excited about it! (No they're not date matched, I was just happy to have original paint PGSG wheels)
The neighbors listed their house for sale and we bought it. We've been renting in this neighborhood that we love and we were sad when our landlord wouldn't sell the place to us. Anyway this sort of derailed my plans on things for this bus!
Here's me moving
58' PGSG |
oakman Samba Member
Joined: February 05, 2014 Posts: 1715 Location: Edge of the Desert, Ca
Posted: Fri Oct 28, 2016 5:36 pm Post subject: Re: Alaskan Original Paint 58 PGSG |
Congrats on the house purchase, being next door makes it easier! The wheels look great. Damn, two og paint pgsg's?? Let me know if you get tired of all that green, I can take one off your hands! |
