jocabot Samba Member
Posted: Mon Jul 18, 2016 6:51 am Post subject: 1970 VW Bus Dash Blinker bulbs not working when engine is ON |
Hi, I need some help to figure out how to fix this issue. My turn signal indicators do not work when ignition is on On or Start position.
The only way to make them work is with the emergency flasher switch engaged and ignition switch at off. As soon as I turn the key to On position, the blinker bulbs stop working...
I did not have this problem before I changed the flasher relay. However, I wired everything as required (see: http://www.netlink.net/mp/volks/schem/flash6a.gif). See this page for more info: http://www.netlink.net/mp/volks/htm/signals.htm
This is the 4-prong relay I've installed: VWC-211-953-215-C from cip1.
The dash indicator is currently wired to KBL terminal. Should I try to hook it on 49a ?
Also, pardon my lack of electricity knowledge, but does the dash indicator bulbs have to be wired to the same fuse as terminal 49 is wired to ?
Thanks ! |
Tcash Samba Member
Posted: Mon Jul 18, 2016 8:17 am Post subject: Re: 1970 VW Bus Dash Blinker bulbs not working when engine is ON |
49 = white wire on (+) terminal on the hazard switch
31 = brown ground wire hooked behind instrument panel
49a = Blue turn signal wire
P = blue/red wire to dash indicator lights
jocabot wrote: |
Thanks ! |
First make sure all the lights on the outside are working.
Check your fuses and give them a spin.
Quote: |
The dash indicator is currently wired to KBL terminal. |
This is right. Leave it where it is.
This is the circuit
click on pic
Take a look at this thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
Good luck
Tcash
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Mon Jul 18, 2016 8:26 am Post subject: Re: 1970 VW Bus Dash Blinker bulbs not working when engine is ON |
The dash indicator bulbs for turn signal are supplied power all the time that the key is on from the same wire that powers the oil & gen warning lights (black wire running to back of the instrument cluster). They are intermittently grounded by the flasher relay to make them flash. There is a small black wire from fuse 4 that powers the turn signal, oil, and gen lights. This is the same fuse as the green wire that goes to 15 on the flasher switch
The blue wire to the indicator bulbs is supposed to be wired to KBL on the flasher relay.
Take the wire off KBL on the flasher relay and ground it, then turn ignition on. The turn signal indicators should light up steady.
If they do, make sure your new flasher relay has a good ground off of terminal 31. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Mon Jul 18, 2016 8:32 am Post subject: Re: 1970 VW Bus Dash Blinker bulbs not working when engine is ON |
Thanks Tcash.
Lights on the outside are working, all fuses are new and properly seated in fuse box.
The only difference I see on the circuit is that my 31 terminal is simply grounded individually to a bolt on the chassis. Could it make a difference if I ground it together with the brown ground wire coming from the instrument cluster ? |
Posted: Mon Jul 18, 2016 8:55 am Post subject: Re: 1970 VW Bus Dash Blinker bulbs not working when engine is ON |
It shouldn't matter where it is grounded as long as it's grounded but you may want to put a meter on that bolt and make sure there is actually a grounded path there. _________________ 1965 Volkswagen 1500 Variant S
Posted: Fri Jul 29, 2016 11:52 am Post subject: Re: 1970 VW Bus Dash Blinker bulbs not working when engine is ON |
@sjbartnik: I've tried that : "
Take the wire off KBL on the flasher relay and ground it, then turn ignition on. The turn signal indicators should light up steady. "
The turn signal indicators effectively light up.
Also, I've taken a pic of the actual relay I have, and the circuit seems to be different than the generic pic taken from cip1's website.:
I have limited knowledge of electrical diagrams, but it appears to me that the only terminal which goes on and off when the flashers are on is 49a. Should I try and hook the blue/red wire to dash indicator lights on 49a together with the Blue turn signal wire ?
Thanks again! |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3899 Location: Seattle, WA
Posted: Fri Jul 29, 2016 3:58 pm Post subject: Re: 1970 VW Bus Dash Blinker bulbs not working when engine is ON |
So what about terminal K1 on your relay? Is that what you're referring to as "KBL"? You simply MUST have a terminal that goes to ground intermittantly. If your relay doesn't do that, then it is the wrong relay for your bus. _________________ '67 bug: seized by the authorities
Posted: Sun Aug 06, 2017 3:47 pm Post subject: Re: 1970 VW Bus Dash Blinker bulbs not working when engine is ON |
Problem solved!
I've connected the blue/red wire to the 49a along with the blue wire, using a y-splitter connector. It works perfectly now! |
