davew18 Samba Member
Joined: February 13, 2016 Posts: 21 Location: sonoma county
Posted: Sun Jul 17, 2016 7:47 pm Post subject: 3x3 suspension kit |
My apologies if this is a pretty obvious question, I tried searching with little to no help, if I have over looked a good thread or if you can direct me to a good thread/source that would be awesome!
I want a 3x3 suspension for my bug, from what I've read this is pretty common, is there a best place to buy this kit?
How about the classifieds, do they come up often?
I've also been considering getting everything accept the coilovers cause I should be able to get those put on a account I have, however the rest of the parts I would be s.o.l.
Also I've read the 3x3 is the best for a off-road application, as to where the 5x6 and 6x6 were unnecessary for the weight of these.
Mine specificily will be used for mountain trails, jumping, Boulder filled trails, rough rough use.
Also showing my rzr buddies why I did not want to spend 30 grand to be wrapped in plastic is an extreme bonus.
So overall the question is is a 3 x 3 kit the best all around?
Is there better for my type application?
is there a best place to buy or do they come up frequently enough in classified sections?
Thank you so much for your time. Dave |
tripicana Samba Member
Joined: February 13, 2003 Posts: 1164 Location: colorado springs
cbeck Samba Member
Posted: Mon Jul 18, 2016 5:34 pm Post subject: Re: 3x3 suspension kit |
You are going to have to have some kind of structure to hook the top of the shocks to. I am using the factory spring plate stops with the plates notched 1/8 ". My shocks are 26.06" extended and 16.03" collapsed. I am limited in travel by the type 2 cv's. Type 1's won't really articulate nearly enough. Mine is pretty soft in the rear now, I suspect after everything is installed and running, I probably will need larger torsion bars. |
Justbuggin175 Samba Member
Joined: April 01, 2013 Posts: 85 Location: California
Posted: Fri Jul 22, 2016 3:54 pm Post subject: Re: 3x3 suspension kit |
im looking for 3x3's also. who makes the best 3x3's? and does someone make a 3x3 with a built in hiem joint so i dont have to use a spring plate conversion kit that bolts to the trailing arm like on the 5x5s and 6x6's? |
cbeck Samba Member
Posted: Fri Jul 22, 2016 5:49 pm Post subject: Re: 3x3 suspension kit |
There is a guy at woodsbuggy.com that advertises as madmike, claims he can build whatever you want. |
Posted: Fri Jul 22, 2016 6:50 pm Post subject: Re: 3x3 suspension kit |
im sure i can find some one in california to make them if i had to, i was just wondering if they were already made. |
