Rathguten Samba Member
Posted: Sat Jul 16, 2016 10:17 am Post subject: Please help ID a partial front clip... '54? |
Hi y'all. I purchased this partial front clip to harvest the metal section between the dash and fuel tank in order to replace the one on my '50 and was told that it came from a '54. The door check straps have two screw holes instead of just an opening. Just looking to confirm the year if anyone can help.
Thanks!
txoval Samba Member
Joined: January 23, 2004 Posts: 3540 Location: The Woodlands, TX
Posted: Sat Jul 16, 2016 10:31 am Post subject: Re: Please help ID a partial front clip... '54? |
Looks like my 54...two screws to attach door stop |
splitjunkie Samba Member
Posted: Sat Jul 16, 2016 10:59 am Post subject: Re: Please help ID a partial front clip... '54? |
I would say '54 or '55.
That section is different on the sides from a non crotch cooler split. It still has the area where the crotch coolers would reside. You won't be able to replace the entire panel you will have to utilize the corners from the old one. _________________ Chris
Posted: Sat Jul 16, 2016 11:51 am Post subject: Re: Please help ID a partial front clip... '54? |
I sort of figured the panel wouldn't be an exact fit. But honestly anything is better than what is on my '50 now.
Thank you very much for the replies. |
Posted: Sat Jul 16, 2016 1:11 pm Post subject: Re: Please help ID a partial front clip... '54? |
I should clarify. The later panel should fit but the shape where crotch coolers would be will make it look incorrect if someone knows to look for it. _________________ Chris
srm1956 Samba Member
Joined: February 18, 2008 Posts: 245 Location: Huntington Beach, CA.
Posted: Sat Jul 16, 2016 4:56 pm Post subject: Re: Please help ID a partial front clip... '54? |
Look like 54-55. You can tell my the location of the fuse block, where the hood release tube would be and the floor heater vent mess. What's the date on the speedo? Also check speedo cable nut. Mine was date stamped _________________ Der
Blitzkrieg
Kafers
My VW motto is - Out with the OLD. In with the EVEN OLDER !!!!!!!!!! |
janerick3 Samba Member
Posted: Sun Jul 17, 2016 10:12 am Post subject: Re: Please help ID a partial front clip... '54? |
Definitely 1954-55. I like the tombstone antenna base. My '54 has one as well. _________________ Thanks,
Jan K. |
Posted: Mon Jul 18, 2016 4:46 am Post subject: Re: Please help ID a partial front clip... '54? |
Thanks janerick3 for the information on the antenna base. I was wondering about that as well. |
