igtoth Samba Member
Joined: May 09, 2006 Posts: 385 Location: Ribeirão Preto, SP, Brazil
Posted: Fri Jul 15, 2016 1:55 pm Post subject: Spring plates |
Hi,
Which one is correct for 57 oval window? Please note they are slightly different.
Thank you.
_________________ 1957 Typ 113 - Polarsilver
1959 Typ 113 - Flint Grey
1975 Typ 221 - Last yr Brazilian Split Window
Ighor Toth |
Snort Samba Member
Joined: April 02, 2005 Posts: 1957 Location: Seattle, WA
Posted: Fri Jul 15, 2016 4:12 pm Post subject: Re: Spring plates |
The one one the left, no slots for the axle tube bolts. I'm not sure when they started with the slots but my 57 does not have them. |
EVfun Samba Member
Posted: Fri Jul 15, 2016 4:26 pm Post subject: Re: Spring plates |
Snort wrote: |
...and I dismantled a '59 that did have the slots. That poor thing was a case of death and decay, but it helped some other Bugs live.
BTW - I just noticed that you are in my neighborhood Snort. _________________
Wildthings wrote: |
Joined: August 31, 2013 Posts: 12848 Location: North Carolina
Posted: Fri Jul 15, 2016 7:03 pm Post subject: Re: Spring plates |
While maybe not "correct", I'd use the one that wasn't pounded on with a 5# mallet, at least until I could find a correct one. The slots will give you some toe in adjustability & the slots will mostly be hidden by the bolts/nuts. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Snort Samba Member
Posted: Sat Jul 16, 2016 6:54 am Post subject: Re: Spring plates |
EVfun wrote: |
BTW - I just noticed that you are in my neighborhood Snort. |
It's always good to know there are others here to share in the abundance of carburetor ice and window condensation. |
