E machine Samba Member
Joined: April 02, 2009 Posts: 18 Location: san Bernardino calif
Posted: Wed Jul 13, 2016 10:50 am Post subject: Fuchs wheels |
What is the widest rim I can use under my 67 VW beetle rear fenders? |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76949 Location: Sneaking up behind you
Posted: Wed Jul 13, 2016 11:41 am Post subject: Re: Fuchs wheels |
I "think" deep 7s will fit. _________________ Glenn
Member #1009
#BlueSquare |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Thu Jul 14, 2016 9:01 pm Post subject: Re: Fuchs wheels |
Are you using wheel adapters or drilled drums/discs?
Some adapters acts like spacers. Some are up to an inch thick. This will obviously effect your wheel width fitting under the fenders, assuming your using OEM size fenders and not some aftermarket/custom widened fender _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
Jos.Hall Samba Member
Joined: January 29, 2011 Posts: 336 Location: Sunny So Cal.
Posted: Thu Jul 14, 2016 9:23 pm Post subject: Re: Fuchs wheels |
What both of them said. If you're using drums or discs (without adapters or spacers) then you can fit a 7" Fuch under the fenders. You have to remember though that there are different offsets for 6'', 7'', and 8'' fuchs. Also you can get original fuchs in 14'', 15, and 16''. If you're going for that classic old school look, then a 15''x7'' is pretty fat in the rear. More importantly is the tire size and I believe the largest tire you can fit is a 215 but I wouldn't go above a 205.
Keith Goss' Chop top had original '73 RSR 7'' fuchs on the rear and it looked perfect if you ask me.
