schwartzkafer Samba Member
Posted: Sun Jul 10, 2016 6:33 pm Post subject: 56 door striker |
I did a search on these, and have read that a 56 is a different striker, assuming original latch mechanism. What I put in is the ones that everyone is saying is for 57 on cars. Seems like my door is latching fine... So, my question is- would an original 56 latch work with the later striker, and if not, how will it act? I don't know if the latches are original, or the ones Wolfsburg West sells, that work with the later latches. |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14576 Location: 18 miles North of the border
Posted: Sun Jul 10, 2016 8:20 pm Post subject: Re: 56 door striker |
The door striker is pretty much the same on 1956-only compared to 1957-later.
VW did some minor improvements to the latch. If I remember correctly, the 1956-only version had a White wedge with a metal bottom. The later latches used an all Black plastic wedge. _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Mon Jul 11, 2016 10:23 am Post subject: Re: 56 door striker |
schwartzkafer wrote: |
Seems like my door is latching fine... |
Your door closes properly . . . with two clicks.
Your latches and strikers must be compatible.
Your question is- would an original 56 latch work with the later striker, and if not, how will it act?
What are you referring to as a "later" striker? A part number would be helpful!
I've never messed with any Bugs older that '55 . . . they are, for sure, different than the later cars and there is no way you will mistake them for what you need to use.
I can tell ya a little about a few of the newer strikers.
Part #111 837 036 (for the right side.) . . . NON-ADJUSTABLE wedge. Uses two different lengths of screws for attachment. Hard to find nice, unbroken strikers.
Part #111 837 036A (for the right side.) . . . Wedge (usually off-white) has the adjustment screw. Uses two different lengths of screws for attachment. Hard to find nice, unbroken strikers.
The above strikers will interchange with each other as far as being able to latch the door.
Part #111 837 036B (for the right side.) . . . Wedge (usually black) has adjustment screw. Uses three short screws for attachment. These are the strikers that are reproduced. Will NOT work with the earlier latch because the bottom "notches" are spaced/shaped differently than the "notches" on the earlier striker plates. Use one of these striker plates with an early latch and the door will close to the first "click", but will NOT close to the second "click"!
Does this help answer your question? _________________ Jesucristo es mi Seņor y Salvador! |
