jberger Samba Member
Posted: Wed Jul 20, 2016 8:39 am Post subject: Re: July 2016 engine job ~ 1991 Vanagon Multivan |
djkeev wrote: |
Babin wrote: |
Coolant would get in the crank case from the cylinder base right? I didn't saw anything about putting sealant at the cylinder base. |
Screen shot from Ben's Place....... Clearly shown on the upper right.
Dave |
While I'm sure adding Locktite 518 is an ok practice, the only thing the Orings need is a bit of oil or light grease. Same with Pushrod tube seals. I use some added dirco to the cylinder base but it's not necessary. He'll be just fine. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
Posted: Wed Jul 20, 2016 8:50 am Post subject: Re: July 2016 engine job ~ 1991 Vanagon Multivan |
djkeev wrote: |
Yep, Oring + petroleum product will seal well....
But Oring with a proven sealer compound will in all probability seal better and for longer.
Hopefully he didn't slip in the Orings dry.
Dave |
I totally agree.. A little lube makes everything fit better.
I actually think that is the benefit of 518, it appears to create a slimy film that doesn't wash away. I have worked on quite a few vans with it slathered all over the place due to some recommendations on here.. Don't understand using it on fuel line connections.. Just sayin. |
Babin Samba Member
Joined: July 09, 2016 Posts: 166 Location: Québec, Canada
Posted: Thu Jul 21, 2016 2:13 pm Post subject: Re: July 2016 engine job ~ 1991 Vanagon Multivan |
It took forever to put the engine back in. The needle (pilot) bearing had gotten smaller somehow. We had to use a very small grinder to get the hole bigger (1mm). But it was finally in yesterday by the end of day. Today all wire back, BUT NO OIL PRESSURE!!.... Even the gauge read zero. I would really appreciate any help in resolving this. I fear the oil pickup is block, since I didn't open the case I never got to check this far in. I did put 4.5L of 20w50 oil. I also filled the filter before installing it. |
Posted: Thu Jul 21, 2016 2:18 pm Post subject: Re: July 2016 engine job ~ 1991 Vanagon Multivan |
Oil pump lost prime. Quick shot of air in the dipstick tube from your compressor while turning it over will take care of it lickity split.. No sh.. |
Babin Samba Member
Posted: Thu Jul 21, 2016 2:28 pm Post subject: Re: July 2016 engine job ~ 1991 Vanagon Multivan |
I can't wait to try... thanks a million in advanced if it work!!!!! |
Posted: Thu Jul 21, 2016 3:02 pm Post subject: Re: July 2016 engine job ~ 1991 Vanagon Multivan |
Babin wrote: |
No oil pressure? That's a major bummer!
I hope the air trick works for you.
You ground the pilot bearing down?!?
Metal Doesn't shrink like that, there's a bigger problem you masked over. I hope it doesn't come back to bite you.
Ghia
Vanagon
Beetle
Babin Samba Member
Posted: Thu Jul 21, 2016 6:09 pm Post subject: Re: July 2016 engine job ~ 1991 Vanagon Multivan |
Just in case this doesn't work. Any other way to prime the oil pump? Was there a way for me to avoid this during reassembly? Something I miss out? |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Thu Jul 21, 2016 6:17 pm Post subject: Re: July 2016 engine job ~ 1991 Vanagon Multivan |
Babin wrote: |
..Was there a way for me to avoid this during reassembly? |
Haven't had to do this on a WBX but on other engines I have packed the oil pump with Vaseline to help it get primed at initial start-up. |
spin the oil filter loose, then crank. When you make a mess, tighten it back up and crank for pressure.
Worst case remove the filter, and pump oil into the center part of the filter adapter, while rotating the engine backward by hand (to prime the pump gears). _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
T3 Pilot Samba Member
Joined: January 10, 2011 Posts: 1507 Location: Deep South of the Great White North
Posted: Thu Jul 21, 2016 6:38 pm Post subject: Re: July 2016 engine job ~ 1991 Vanagon Multivan |
All good tips.....
Here's mine: disconnect the coil from the distributor so that you can crank but not start the engine while circulating oil/verifying pressure. _________________ 1988 Vanagon
The most important part in every vehicle is the nut behind the wheel...... |
Babin Samba Member
Posted: Thu Jul 21, 2016 8:18 pm Post subject: Re: July 2016 engine job ~ 1991 Vanagon Multivan |
Thanks T3 Pilot,
I had done that (crank with disconnected coil) prior to starting the engine for the first time. I cranked for like 30 sec.
The engine actually run 4 time 10-20 sec each time trying to get/measure pressure. Hopefully no damage. I hope this bearing guard grease was good enough to lower the amount of damage.
I will try the compress air first thing in the morning. Then I will move on to the oil filter ideas. |
Babin Samba Member
Posted: Fri Jul 22, 2016 5:25 am Post subject: Re: July 2016 engine job ~ 1991 Vanagon Multivan |
jberger!!! You rocks!
A couple of small air shoot while crank and it quickly builded pressure again. Wow..
Now I think the lifter empty out while I was trying yesterday because the engine didn't sound that great at first. Cyl 1 sound like it's got a lifter not totally pressure up. What would be the best thing to do to get it good. I'm still in the coolant filling (3 gal out of 4) part of it before I try breaking in the motor. I would tend to run it for a couple of minute until the clic clic end up and then readjust the valves rocker before breaking in. What do you think?
Babin Samba Member
Posted: Fri Jul 22, 2016 5:40 am Post subject: Re: July 2016 engine job ~ 1991 Vanagon Multivan |
Thanks Dave!!
I really appreciate all the help. |
Babin Samba Member
Posted: Mon Jul 25, 2016 2:37 pm Post subject: Re: July 2016 engine job ~ 1991 Vanagon Multivan |
I still have that clong-clong noise after 3-5 minute at 2000 rpm trying to get the coolant purge up. How long should I expect to run the engine before the lifter noise go away? Should I re-adjust the valve? after a certain amount of time maybe? |
CdnVWJunkie Samba Member
Joined: February 01, 2004 Posts: 1110 Location: Sarnia, Ontario, Canada
Posted: Mon Jul 25, 2016 2:45 pm Post subject: Re: July 2016 engine job ~ 1991 Vanagon Multivan |
Babin wrote: |
Every engine is different. I've had some lifters pump up very very quickly while others can take as long a 45 minutes of driving to fully quieten down. |
Babin Samba Member
Posted: Tue Jul 26, 2016 8:43 am Post subject: Re: July 2016 engine job ~ 1991 Vanagon Multivan |
Ok! run it for 5-7 minutes this morning at 2000 rpm to finish the coolant purging process and the ticking was a lot better right off the start. I will now adjust the the valve rockers and check all the lifter are hard and nicely primed. Then I will break the piston rings and lifter procedure by going on the road at high rpm and on hill climb at high RPM as suggested by Dave. |
Babin Samba Member
Posted: Tue Jul 26, 2016 11:48 am Post subject: Re: July 2016 engine job ~ 1991 Vanagon Multivan |
I did as best as possible to break the rings and new lifter in as Dave suggested. Then I drop the oil while the motor was still hot and filled it again.
Two thing are worrying me at the moment. There was a serious constant hissing noise at high RPM (3000-3500). That would go away when I pressed the clutch. There also is a bit of oil dripping at the front of the engine. I'm afraid that would come from the flywheel seal area. What do you think?
Other than that there was good power and an ok engine noise. I will let it sit until tomorrow for the pistons and rings to cool all the way down. |
Babin Samba Member
Posted: Wed Jul 27, 2016 11:24 am Post subject: Re: July 2016 engine job ~ 1991 Vanagon Multivan |
My engine bay after the refeshed motor.
