SteveG62 Samba Member
Posted: Sat Jul 09, 2016 3:41 pm Post subject: HELP 55 oval front hood frozen |
I just bought a 55 oval and the front trunk is frozen.
Any ideas |
EVfun Samba Member
Posted: Sat Jul 09, 2016 10:40 pm Post subject: Re: HELP 55 oval front hood frozen |
Cut the center of the loop out of the hood handle and unscrew the handle halves? _________________
Wildthings wrote: |
Mr. OGPaint Samba Member
Joined: September 24, 2010 Posts: 823 Location: Oregon
Posted: Sun Jul 10, 2016 12:37 am Post subject: Re: HELP 55 oval front hood frozen |
I've gotten lucky going into the backside of the apron if one of the access holes is missing, make sure the cable is pulling on the release.. Also try wiggling side to side, sometimes if there is no hood seal the hood can hang on the seal lip. Two people can help, one to hold the release and one to try the hood. Good luck.
Also, the above cutting the handle trick is a good last resort. _________________ https://instagram.com/mr.ogpaint
Patrick Hall |
thevinster Samba Member
Posted: Sun Jul 10, 2016 12:46 am Post subject: Re: HELP 55 oval front hood frozen |
We used a crowbar |
0nebadbug Samba Member
Joined: October 01, 2009 Posts: 1087 Location: Rockford, Illinois
Posted: Sun Jul 10, 2016 6:23 am Post subject: Re: HELP 55 oval front hood frozen |
If the latch cover inside is not present you can usually snag the locking mechanism/wire with a hook tool with some patience but if the cover is there then just cut the handle in half and unscrew the 2 halves and buy a new handle... _________________ ::: Slowoval ::: LaDawri Sebring ::: '61 Creampuff ::: Dust Storm '66 ::: |
motofly196 Samba Member
Joined: June 01, 2008 Posts: 1467 Location: Eastern WA
Posted: Sun Jul 10, 2016 7:55 am Post subject: Re: HELP 55 oval front hood frozen |
If it's like any other 55' I've seen, the spare tire well is rusted out. This provides great access to the hood latch! Jack it up and crawl under there and see if you can access the latch (if the spare tire isn't in there). |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Sun Jul 10, 2016 2:17 pm Post subject: Re: HELP 55 oval front hood frozen |
Push down, pull up, wiggle side to side. Do all three motions at the same time. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
schwartzkafer Samba Member
Posted: Sun Jul 10, 2016 6:38 pm Post subject: Re: HELP 55 oval front hood frozen |
Just a guess, as I've never done it, but im guessing you could bend the access cover out of the way, then use a long needle nose to activate the latch mechanism. The cover is held on by 1 screw, and a metal tab,and i'm gueesing it wouldnt be hard to move out of the way. Once inside, just bend the cover tab back into shape. Good luck! |
stanovich Samba Member
Joined: March 18, 2013 Posts: 191 Location: central coast calif
Posted: Sun Jul 10, 2016 7:45 pm Post subject: Re: HELP 55 oval front hood frozen |
if original handle I would try from the access holes. Ive done it along time ago 41 years to be exact. give it a try first |
