ClassicCamper Samba Member
Posted: Fri Jul 01, 2016 9:32 pm Post subject: Side Trim Question |
I was able to pick up a tube of molding from a local VW show. I'm getting my 412 painted and trying to find the correct width of the original side trim. (Goes around the middle of the doors, etc) The tube I got has these in it:
Not sure which width is correct. Also, the last painter pinstriped over the trim clip holes, so I'll need clips as well.
Thanks in advance for your advice. - Ron _________________ 1973 412 Wagon
1976 Westy
1978 SB Vert |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21519 Location: Oklahoma City
Posted: Sat Jul 02, 2016 8:12 am Post subject: Re: Side Trim Question |
The smaller strips on the bottom are correct. The top larger one 3 looks similar to what goes on the lower rockers....but looks slightly narrow. It may be a type 3 profile.
Late Type 3 and type 4 used the same waistline trim profile. They use the same clip. Check at ISP west.
Also.....look at this carefully. If the holes in your fenders are actually still there....ok. if they were just painted over....ok....poke them out.
Personally....I am welding mine up and will be adhering trim with high strength adhesive. In the long run its less problematic with trim coming loose and clips needing to be replaced.
I say this because I assume you are keeping this car longterm. The original clips are rust magnets...especially in the rear quarter panel areas. They leak inside especially because vibrations and a few dents here and there cause alignment issues.
Also...the biggest problem is that these strips are not sealed to the body. The trim is hollow....and collects every manner of dirt and fine leaves. The dirt and crud stay wet inside the trim clips and collects around the clips. The little red seals do not seal perfectly and or bad with age.....and you need to pressure wash the trim strips and would be stunned at how much crud washes out from underneath. This pressure washijg also leaks past the seals.
Yes....you can get around this to a large degree by installing the trim clips and carefully sealing with silicone. Ray |
Posted: Sat Jul 02, 2016 8:49 am Post subject: Re: Side Trim Question |
Thanks Ray- when I took off the lower, wider trim on the car, it was filled with very fine road dust, rocks, etc.. I can see how these would be rust magnets. I do plan on keeping this car for the long-haul. I hope the car feels the same about me. _________________ 1973 412 Wagon
1976 Westy
1978 SB Vert |
Posted: Tue Sep 27, 2016 11:02 pm Post subject: Re: Side Trim Question |
I thought I requested this before, as I'm having a deja vu moment.
I'm trying to find the correct/best trim clips for the following:
1) VW logo on hood. (Need cups/clips that secure the round Vw enblem to the hood.
2) The 'VW 412' logo on the lift gate.
Getting close, _________________ 1973 412 Wagon
1976 Westy
1978 SB Vert
Last edited by ClassicCamper on Wed Sep 28, 2016 9:30 am; edited 2 times in total |
Posted: Wed Sep 28, 2016 7:41 am Post subject: Re: Side Trim Question |
Let me see what I can find. The little elastomer cups or grippers that hold on the rear badges....I have gotten from West Coast Metric in the past. Ray |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34013 Location: Conejo Valley, CA
Posted: Wed Sep 28, 2016 9:40 am Post subject: Re: Side Trim Question |
On other models and over the years, there are different diameter pins on the badges. This means the cups/grippers came in different sizes. Maybe they got it together for the Type 4, but I don't know, so beware. |
Posted: Wed Sep 28, 2016 9:49 am Post subject: Re: Side Trim Question |
Thanks for the heads-up. I'll let you know what I find out. _________________ 1973 412 Wagon
1976 Westy
1978 SB Vert |
Posted: Wed Sep 28, 2016 11:17 am Post subject: Re: Side Trim Question |
OK.....for the type 4..these are the part numbers for the little elastomer gripper cups.
Believe it or not there is no part # for the gripper cups that hold the rear tailgate and hood "VW 411 or 412" badges....but I have found that they are very nearly identical to the same part that holds on the rear quarter vent grate on the 411 and 412 sedans....that little louver behind the rear quarter window.
That part # is 411 819 451
And....it is very nearly identical to the part that holds on the front hood VW logo badges.
That part # is 113 853 615
This is going from memory and I may be able to check later today....but the difference between these two seals is that...as KTPhil mentioned...one has a little tighter ID than the other...which can work perfectly with very little mods...but the real difference is that one has a very slightly larger OD than the other. I have been able to make the same 113 853 615 part # work for all of them on my 412 in the past.
In fact....the memory just came back.....the 411 819 451...which is used for the rear quarter louver trim on 411/412 sedans....has a smaller OD. Using the 113 853 615 cups for the quarter window louvers means that you need to push the little cups into the body very hard with a wooden dowel. Since this makes the ID close up a little...also applying the lover means you need to carefully push quite hard to get the louver to stick on flush.
Likewise....trying to use the 113 853 615 for the rear deck badge...I found that the holes in the lid were a little loose....but simply applying a little RTV as an adhesive and letting it dry...made them function perfectly well.
Over the years these parts have been made variously of nylon 6 (the yellowish ones that snap of and crumble when you try to remove them)....and of polyethylene from WCM (which had the most variation from batch to batch....and basic black polypropylene or similar.
It would be great if someone just made them from rubber so they had some flexibility.
So with care the 113 853 615 can function in all locations.
And from this list of offerings...you can see the general range from shitty to good these parts range in reproductions.
http://vwparts.aircooled.net/VW-Hood-Emblem-Seals-Clamps-Set-113-853-615-p/113-853-615-3.htm
https://www.vwheritage.com/shop/113853615/badge-clip/
http://www2.cip1.com/ProductDetails.asp?ProductCode=C16-113-615
The one from Airhead are theg closest to what the originals looked like...and what MCM sold at one time...
http://www.airheadparts.com/Hood-Emblem-ClampSeal-Set3/item/113-853-615%20ST3
https://www.appletreeauto.com/EMBLEM-SEAL-and-RETAINER/
And the winner is:
NOS in the box of 100 in the Samba Classifieds
http://www.thesamba.com/vw/classifieds/detail.php?id=783100
For the record...these are the front VW logo badges used on the 411/412
113 853 601 B to Chassis # 419 100 000 (‘68 and ‘69 411)
411 853 601 from chassis # 410 2000 001 (the 411 front wing badge)
411 853 601 from Chassis # 413 2000 001 (late 1972 early 412 and 1973 and on 412)
These are the rear script badge part #'s:
“Automatic” 411 853 675
“VW 411 L” 411 853 687
To chassis # 412 2100 000
For models: 411. 412, 421, 422, 461, 462
“VW 411 LE” 411 853 687 A
To Chassis # 412 2100 000
For models: 022: 411, 412, 421, 422, 461, 462
“VW 412 L” 411 853 687 B
From Chassis # 413 2000 001
For models: 411, 412. 421, 422, 461, 462
“VW 412 LE” 411 853 687 C
“VW 411” 415 853 687
For models: 415, 416, 425, 426, 465, 466
“VW 411 E” 415 853 687 A
To/From Chassis # ? (no listing so this is the first cars)
“VW 412” 415 853 687 B
From chassis # 413 2000 001
“VW 412 E” 415 853 687 C
For models # 022: 415, 416, 425, 426, 465, 466
“Variant” 361 853 689 A
From Chassis # ? (original models)
For models: 461 through 466
So...if I have not posted these before, this is how you tell what car you have:
So...ClassicCamper....you have:
A left hand drive variant which makes it a 461` which is the "L" variant because all cars in the US were "L" models. Because of this there was no need to differentiate. It was rare to see an "L" badged car in the US unless it was gray market import.
And technically you have a 412 LE because its fuel injected.
But for the same reasons...that virtually all 411 and 412 in the US were luxury and injected ("LE" models") it would be rare to find an LE script on one.
See here in this thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=464596
And....you have a 022:3 ...which is variant engine with Automatic
So from the badge list...this is most probably the badge yours had:
http://www.ebay.com/itm/Volkswagen-VW-412-Script-Emblem-415-853-687-B-/291397333152
http://www.ebay.com/itm/VINTAGE-VOLKSWAGEN-VW-412-...2022485792
And there are about one dozen script badges in the Samba classifieds right now
http://www.thesamba.com/vw/classifieds/search.php?...412+script
Ray |
Posted: Thu Sep 29, 2016 9:40 pm Post subject: Re: Side Trim Question |
Interesting stuff. The post about the different T4 trim packages was a cool read. Now I feel like I'm stylin' with th carpeted trunk, 'wall to wall' interior carpet, a clock and wider back rest to name a few. I didn't realize there was a stripped down model available outside the US. _________________ 1973 412 Wagon
1976 Westy
1978 SB Vert |
Posted: Sat Oct 08, 2016 10:15 am Post subject: Re: Side Trim Question |
I was combing through the site and was hoping to find some pictures as to how the side/belt line trim appears on the car.
I have the clips and trim, but I'm going to have to cut the trim at the ends. So, I guess what I'm saying is I need some detailed, close-up pics of the trim, most importantly the ends, so I can cut and fade it into the car correctly.
Any help would be appreciated. _________________ 1973 412 Wagon
1976 Westy
1978 SB Vert |
Posted: Sat Oct 08, 2016 9:32 pm Post subject: Re: Side Trim Question |
In your original picture showing the two trim pieces. ...the small lne of course is the beltline trim....goes about waist high.
The piece of trim in that picture is the "inner" end shape of any given tfim shape. There are only two end treatments.
1. What i call thumbnail shaped in your picture......which goes ......starting at the front fender and moving toward the rear......
Thumbnail shape at the rear edge of the front fender
Opposing thunbnail shape at the leading edge of the door.....
Thumbnail shape at the trailing edge of the door
Opposing thumbnail shape at the leading edge of the rear fender.
These thumbnail shaped ends have a slight bevel at the end so that when the door is,open they do not smash into each other.
The other shape is the "bullet" or oval shape. You will have one on the leading end of the front fender,and on the trailing end of the rear fender.
Ray |
Lars S Samba Member
Posted: Sat Oct 08, 2016 9:56 pm Post subject: Re: Side Trim Question |
You can cut the end to match the thumbnail shape....with some practise it will look better than these pics shows.
Lars S
_________________ Porsche 914 -72, Bahia Red daily driver
VW411 2-d -70, White, sold
VW412 4-d, -73, Gold Metallic, daily driver
Suzuki T500, -69, Candy Gold, sold
Suzuki K50, -77, Black, daily driver
BMW R69S -69, White, sold
Husqvarna 118cc, -47, Black, Sold |
Posted: Sun Oct 09, 2016 6:22 am Post subject: Re: Side Trim Question |
Perfect! Thanks Lars!......thats what I was trying ot explain.
The bevel allows areas of the trim strip that have to get close to each other to fit without a large gap.
Thinking about this...there may be a third end shape.
The bevel that Lars is showing is definately the door gap to front fender bevel. I know that the factory lead edge of the front fender and trail edge of the back fender were bullet shaped ends.....more bullet shaped than what is in your original picture in this thread.
That thumbnail shape may go on the lead edge of the rear fender near the door.
You might also did around in the type 3 section as they used the same cross section trim. Ray |
Posted: Sun Oct 09, 2016 1:35 pm Post subject: Re: Side Trim Question |
Apologies---- I can't tell what end goes where and how to trim the strips. Can someone shoot over a few pics of the trim ends on the car? When I got the car, it had no belt line trim.
I'm much better with a visual on the car. _________________ 1973 412 Wagon
1976 Westy
1978 SB Vert |
Posted: Sun Oct 09, 2016 2:25 pm Post subject: Re: Side Trim Question |
ClassicCamper wrote: |
I'm much better with a visual on the car. |
I can make sketches but no pictures. I dumped the trim years ago....rust magnet. When the tike comes I will be making surface mount trim to replace it.
Ray |
Posted: Mon Oct 10, 2016 8:26 pm Post subject: Re: Side Trim Question |
Thanks Ray -- that would be great. If I have some trim left, I'll happily donate it to the T4 cause. _________________ 1973 412 Wagon
1976 Westy
1978 SB Vert |
Lars S Samba Member
Posted: Tue Oct 11, 2016 5:04 am Post subject: Re: Side Trim Question |
Not that I dont trust Rays coming sketches but today I had a chance to take some pics of my 2-d 411 original side trim, the 412 side trim looks the same to me.
It seems to be to types of ends in total: te rounded one at the wery front and rear ends and the thumbnail type on all the others. I used some late Type3 trim (which still is available in sets) on my 412. The Type3 trim has the same profile (also the rounded ends).
If you look 5 posts above i this thread there is a tip with photos on how to cut and trim it - exercise on the old ones or on excess pieces!
Pics below are from left side front to rear (sorry for the rust spots ).
/Lars S
Front end, close to headlights.
End of front fender/front of drivers door.
End of door/front of rear fender.
End of rear fender. _________________ Porsche 914 -72, Bahia Red daily driver
Posted: Tue Oct 11, 2016 11:18 am Post subject: Re: Side Trim Question |
Thanks very much this is a lot of help! I'll post pictures as I attempt to do this. _________________ 1973 412 Wagon
1976 Westy
1978 SB Vert |
Posted: Thu Oct 13, 2016 10:26 pm Post subject: Re: Side Trim Question |
Peeeeeerrrfffect!
Ray |
Pepperbilly Samba Member
Joined: April 08, 2017 Posts: 977 Location: Seattle, Wa
Posted: Tue Oct 27, 2020 5:40 pm Post subject: Re: Side Trim Question |
Looking to replace all my upper trim. Just way too many bad dents. So it has been suggested using late type 3 trim. My 412 wagon trim measures as follows...
Front fender is 48 1/2” long
Door is 45” long
Rear is 61” long
The long piece is what worries me. Is the type 3 rear trim long enough? Has anybody used the ISP West pieces?
Bill |
