mgoodman Samba Member
Posted: Wed Jun 29, 2016 8:55 am Post subject: front wheel bearings and seal.... |
I picked up a sand rail not long back, going through everything and found some bad front bearings, full of sand and junk.
I pulled everything apart, but I am having a hard time locating new bearings. They are not stock apparently, maybe upgraded spindles?
Numbers on bearings :
4T 30305
4T 30304A
Seal:
40x62x11 S r 4.4
Can anyone point me in the right direction for new parts here? |
tripicana Samba Member
Joined: February 13, 2003 Posts: 1164 Location: colorado springs
Posted: Wed Jun 29, 2016 9:09 am Post subject: Re: front wheel bearings and seal.... |
Did you try google?
Amazon has both those bearings... _________________ foam cowboy hats aren't good helmets. |
Mal evolent Samba Member
Joined: March 31, 2009 Posts: 2912 Location: San Antonio, Nuevo Mexico
Posted: Fri Jul 01, 2016 5:54 am Post subject: Re: front wheel bearings and seal.... |
one fits a Nissan patrol, one is used on Kawasaki motorcycles. google "XXXX fits" _________________ 73 Beetle Baja, Ghia front brakes, Type 3 rear brakes, 2220 ( 94 X 80 ), Weber Progressive, Bosch SVDA, '97 Mustang seats
Baja Bugs for Volkswagen Virgins: Index |
Posted: Fri Jul 01, 2016 7:25 am Post subject: Re: front wheel bearings and seal.... |
I managed to locate the ones I needed, on their way to me now... combination of Amazon and a bearing supply place.
I was hoping for them to arrive by the weekend, but doesn't look overly hopeful... so I guess I continue to tinker with the other things that need to be done on it. |
PhillipM Samba Member
Posted: Fri Jul 01, 2016 8:17 am Post subject: Re: front wheel bearings and seal.... |
They are a bit of a weird size, I used to have to special order mine over in the UK, nobody kept them in stock, so I made the new hubs take a more common pair of bearings instead that were half the price |
Posted: Fri Jul 01, 2016 11:39 am Post subject: Re: front wheel bearings and seal.... |
Yeah... it was a bit odd, not sure if the spindles were upgraded or something. I was told by PO that the front was from a 73' bus. It is link pin and not ball joint, if that matters. |
