Battery bench-testing 6V wiper motor
catahoula lou
catahoula lou is offline
PostPosted: Mon Jun 27, 2016 8:35 am    Post subject: Battery bench-testing 6V wiper motor Reply with quote
I have a pre-67 wiper motor with a 12V conversion armature within it. Want to bench-test it with my 12V battery (separate from switch) before I install it.
Have terminals 54/31b/54d. To which do I connect (-) and to which do I connect (+) testing leads from my battery?
Have seen Glutamoto's wiring diagrams, which are very helpful, but can't make out answer to my question.
Best,
Thom
1 great wife
2 Catahoula Leopard Dogs (Mahogany Star and Spartan) - RIP Lucy, Braveheart, & Dusty!
1 1959 mango green Ragtop Bug (the "Mango")
1 1958 pantina red Lowlight Ghia (the "Chili Pepper")
Still looking for:
(1) My Dad's 1955 356 (he raced it amateur-class at Riverside and other courses during 1950s),
(2) My parent's black 1955 hardtop bug (CA license plate FWC 201 or FWG 201), and
(3) My parent's agave green 1957 ragtop bug (CA license plate LFK 734).
flyboy161
flyboy161 is offline
PostPosted: Mon Jun 27, 2016 8:58 am    Post subject: Re: Battery bench-testing 6V wiper motor Reply with quote
A picture would help, because those numbers don't sound right.
However:
54 is motor power, 31b is ground, 54d should be park power. After running 54 to 31 ( where the motor runs continuously) switch to 54d to 31b and the motor should run up to one full revolution and stop. Repeat the test and that will confirm the motor works properly.
My father's 1970 Beetle-
http://www.thesamba.com/vw/forum/viewtopic.php?t=603879
The 1964...Diamond in the rough
http://www.thesamba.com/vw/forum/viewtopic.php?t=612776
My 1958 Morocco Bug-
http://www.thesamba.com/vw/forum/viewtopic.php?t=611483
catahoula lou
PostPosted: Mon Jun 27, 2016 9:01 am    Post subject: Re: Battery bench-testing 6V wiper motor Reply with quote
I want to test directly with my battery, not my switch...
1 great wife
Still looking for:
Luft kühl
Luft kühl is offline
This diagram might be easier to understand.
Connect (+) to 54d. and connect (-) to the case of the motor (31).
catahoula lou
PostPosted: Mon Jun 27, 2016 6:35 pm    Post subject: Re: Battery bench-testing 6V wiper motor Reply with quote
Well, I verified that the motor works, both on the constant and "intermittent" circuits by connecting the (-) battery lead to the motor body and touching the (+) battery lead - separately - to motor terminals 54 and 54d. Then installed motor/transom assembly into body.
Next, I connected the wires between the 1959 motor (converted to 12V) and the 1967 (6-connector) switch (using Glutamodo's 2nd diagram in link below), installed switch, then power. Made sure there is some bare metal for switch to ground to and installed the grounding wire from back of switch to ash tray holder screw.
Triple-checked connections.
http://www.thesamba.com/vw/forum/viewtopic.php?t=649751&highlight=wiper+motor
Problem is that the motor will not switch off in any of the three positions.
Is my switch bad, should I made a better bare spot on the dash for a better switch ground, or is it something else?
Best,
Thom
1 great wife
Still looking for:
flyboy161
PostPosted: Mon Jun 27, 2016 8:16 pm    Post subject: Re: Battery bench-testing 6V wiper motor Reply with quote
Um. Just a question, but why would you use a six connector switch with a 3 wire motor?
flyboy161
PostPosted: Mon Jun 27, 2016 8:27 pm    Post subject: Re: Battery bench-testing 6V wiper motor Reply with quote
The switch shown is a 67. Terminal numbers are correct for the switch.
Trick is wiring the motor.. 53a on the switch goes to 54 on the motor (according to his diagram. Always hot park power)
53 on the switch goes to 54d on the motor.
31b on the switch goes to 31b on the motor.
Power comes from fuse block and goes to wiper switch 30
Disregard the wire coming from switch 53b. It won't exist on your setup.
If it parks I low position and wipes on low speed in OFF, then switch the 54 and 54d wires on the motor.
catahoula lou
PostPosted: Tue Jun 28, 2016 7:17 am    Post subject: Re: Battery bench-testing 6V wiper motor Reply with quote
The switch came with the car when I bought it back in ~1979, and up to when I disassembled it for a pan-off restoration, the set-up worked fine. Unfortunately, I disconnected the switch/motor wires for storage, which I should not have done in retrospect.
I checked your text and Glutamodo's diagram, along with my hand-drawn diagram, and all connections are properly made.
One reason that I like Glutamodo's diagram, and using the pre-1967 motor and 1967 switch combination, is that his third diagram indicates using 2 voltage dropping resistors (no mention on Ohms of either resistor) to get a 2-speed operation , which I eventually would like to get going.
But for now I would like to just get the one-speed operation working...
Best,
Thom
1 great wife
Still looking for:
flyboy161
PostPosted: Tue Jun 28, 2016 7:57 am    Post subject: Re: Battery bench-testing 6V wiper motor Reply with quote
I can't help you with the resistor, but...
This is a '67 switch drawn hooked up to your motor
If the wipers don't shutoff on the high position on the switch, then for sure the switch is bad. Nothing is connected to the motor from the high position of the switch on my diagram. The wipers should just stop and stay when you switch to high.
If it doesn't park and shutoff in the Off position, you have crud in the limit switches behind the terminals on the motor and they need to be cleaned or replace the motor.
flyboy161
PostPosted: Tue Jun 28, 2016 8:07 am    Post subject: Re: Battery bench-testing 6V wiper motor Reply with quote
Sorry, I forgot all the terminal numbers on the switch
catahoula lou
PostPosted: Tue Jun 28, 2016 8:14 am    Post subject: Re: Battery bench-testing 6V wiper motor Reply with quote
I'll try your diagram next. Motor will park itself, so I suppose the internal contacts are OK...
Best,
Thom
1 great wife
Still looking for:
catahoula lou
PostPosted: Wed Jul 27, 2016 7:57 pm    Post subject: Re: Battery bench-testing 6V wiper motor Reply with quote
Finally made time to SLOWLY test both switch/motor separately. Both work fine separately. Installed and realized that I had switched the wires that go to motor terminals 54 and 54d (DOH!). After correcting problem, still did not work.
Used my clip/testing wire to temporarily ground motor better (mounting bolt brass clip) and realized that motor was not grounding sufficiently. Connected new ground wire from brass clip to cigar lighter ground connection and now wiper works just fine!
Plan to add an in-line resistor to the first position switch connector for a dual-speed wiper (fancy!).
Hope this helps others...
Best,
Thom
1 great wife
Still looking for:
flyboy161
PostPosted: Wed Jul 27, 2016 10:39 pm    Post subject: Re: Battery bench-testing 6V wiper motor Reply with quote
Good job, Thom!
catahoula lou
PostPosted: Thu Jul 28, 2016 6:38 am    Post subject: Re: Battery bench-testing 6V wiper motor Reply with quote
Yeah, considering that it's been over a hundred degrees or so over the past month and my shop swamp cooler recently died, it's been hard to get motivated...
Best,
Thom
1 great wife
Still looking for:
flyboy161
PostPosted: Thu Jul 28, 2016 6:40 am    Post subject: Re: Battery bench-testing 6V wiper motor Reply with quote
I hear ya. We've been pushing triple digits here in GA with 75%-95% humidity. Anything I do on mine is carefully thought out before I attempt it, haha
herbie1200
herbie1200 is offline
PostPosted: Fri Jul 29, 2016 12:32 am    Post subject: Re: Battery bench-testing 6V wiper motor Reply with quote
catahoula lou wrote:
Finally made time to SLOWLY test both switch/motor. Both work fine separately. Installed and realized that I had switched the wires that go to motor terminals 54 and 54d. After correcting problem, still did not work.
Used my clip/testing wire to temporarily ground motor better and realized that motor was not grounding sufficiently. Connected ground wire from mounting bolt to cigar lighter ground connection and now wiper works just fine!
Best,
Thom
It sound strange to me, a bad motor grounding is not a cause of non-stop wiper.
I would bet you problem was a bad ground of the switch; its ground is to short quickly the "31b" terminal of the motor to suddenly block it and avoid a re-start.
catahoula lou
PostPosted: Fri Jul 29, 2016 6:33 am    Post subject: Re: Battery bench-testing 6V wiper motor Reply with quote
No, it was a bad ground at the motor, as confirmed when I attached and then removed a wire from the front transom mounting clip (brass?) to the ignition switch mounting bolt, then installed wire as described.
Body had been completely re-painted as part of a pan-off restoration and the transom bolt mounting threads likely still have some fresh paint on them.
Best,
Thom
1 great wife
Still looking for:
grandpa pete
grandpa pete is offline
PostPosted: Fri Jul 29, 2016 7:17 am    Post subject: Re: Battery bench-testing 6V wiper motor Reply with quote
Thankyou Lou and Flyboy ; 12 volt wiper conversion is next on my schedule . Great info Laughing
63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery
