alimadani Samba Member
Posted: Mon Jun 27, 2016 7:22 am Post subject: Karmann ghia 1971 coupe |
I did rewire my ghia 1971 and I used wire diagram that available for ghia 71. but there is plenty wire diagram for ghia 71 and almost 3 slightly different diagrams. how can I know which one is mine?
Do you know anybody who can help me on my car in Norcross, Atlanta
Thank you everyone. |
c705ncp Samba Member
Joined: May 06, 2008 Posts: 156 Location: North East England
Posted: Mon Jun 27, 2016 8:38 am Post subject: Re: Karmann ghia 1971 coupe |
Having simular problem rewiring my 73 RHD that I imported from Japan.It was sent from factory direct to Japan and I have imported to UK. The 12 fuse ,fuse box has disintergrated and I'm changing to blade type fuse box . Only problem is wires hanging loose so I'm having to start from scratch and extending wires as have relocated position of fuse box. I downloaded a wiring diagram from a page on this forum and it seems the wire colours are the same
Robert |
NOVA Airhead Samba Member
Joined: July 20, 2005 Posts: 5221 Location: Richmond, VA
Posted: Mon Jun 27, 2016 11:53 am Post subject: Re: Karmann ghia 1971 coupe |
alimadani wrote: |
Use the one that is on this site. Its from the Bentley. I have owned two 71s and this diagram has been accurate with both.
http://www.thesamba.com/vw/archives/info/wiring/bus_8_70_usa.jpg _________________ Ghia Owner Emeritus |
Posted: Mon Jun 27, 2016 3:57 pm Post subject: Re: Karmann ghia 1971 coupe |
it seems right and accurate wire diagram. however still regulator has 5 pins and its different from other 71s. |
Posted: Tue Jun 28, 2016 11:20 am Post subject: Re: Karmann ghia 1971 coupe |
alimadani wrote: |
I am not sure I am following you. Are you saying that the regulator in your car has five pins? If so then its likely some type of aftermarket unit designed for more than one application.
Mine has four connection points plus a ground where the regulator attached to the car. _________________ Ghia Owner Emeritus |
TheStuffyNose Samba Member
Joined: June 30, 2016 Posts: 5 Location: Bakersfield Ca
Posted: Thu Jun 30, 2016 6:08 pm Post subject: Re: Karmann ghia 1971 coupe |
NOVA Airhead wrote: |
alimadani wrote: |
Mine has four connection points plus a ground where the regulator attached to the car. |
THERE ARE FIVE LIGHTS |
