Noblecr Samba Member
Posted: Sun Jun 26, 2016 6:06 am Post subject: Using the under mount spare space for storage |
Hi,
I know someone out there has come up with some great ideas and ways to use this space as usable storage. I have tried the Samba search, but no luck.
So thought I would ask....how do you use it? what do you use it for? How accessable? What type of container are you using if any? Picture are always appreciated.
Cheers
C. |
Howesight Samba Member
Joined: July 02, 2008 Posts: 3274 Location: Vancouver, B.C.
Posted: Sun Jun 26, 2016 8:18 am Post subject: Re: Using the under mount spare space for storage |
I love the Samba, but its search "engine" is not great, which makes sense, given the size and power of Google. Esoteric searches like the one you are pursuing yield incredibly good results by searching on Google for pictures of the thing you are looking for. I just tried "Vanagon spare tire space" on Google, hit images, and voila, hundreds of pics, most of them from the Samba! Click on the pic, go to the source of the pic, and you're done. _________________ '86 Syncro Westy SVX |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6247 Location: Portland OR
Posted: Sun Jun 26, 2016 11:27 am Post subject: Re: Using the under mount spare space for storage |
It took me about 10 seconds to come up with this:
http://www.thesamba.com/vw/forum/search.php?search...=titleonly
The secret to the search is to use the word "and" between search words.
In the search box at the top of the vanagon forum I typed "spare and storage" and checked title. results were quite good. Using the word and makes it search for all the words you type together and not individually. There are instructions on the site on how to use the search properly.
Good luck! _________________ 89 Westy 2.1 Auto
Posted: Sun Jun 26, 2016 12:03 pm Post subject: Re: Using the under mount spare space for storage |
Thank you |
bluebus86 Banned
Posted: Sun Jun 26, 2016 2:06 pm Post subject: Re: Using the under mount spare space for storage |
PDXWesty wrote: |
Good luck! |
I simply used the two words "spare storage" and did a titles only search on the vanagon forum and got eight results just as you did, no "and" needed. I believe the "and" is implied and is thus redundant to include it, wont hurt however to add it.
The Sambas search function works fine, it fact it is pretty damn good. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Madeouttaglass Samba Member
Joined: September 18, 2013 Posts: 228 Location: Shelter Cove, California
Posted: Sun Jun 26, 2016 2:20 pm Post subject: Re: Using the under mount spare space for storage |
I built this hinged piece for mine. It is framed with 1" square tubing. The intention was to also have diamond plate on the sides. I never got around to doing the sides as life changed and now the Westy is on ebay. (Auction ends in less than 6 hours as I write this. )
_________________ My 1987 Syncro Westy build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=575358&highlight= |
Posted: Sun Jun 26, 2016 4:50 pm Post subject: Re: Using the under mount spare space for storage |
I hate to disagree with you, (because I know you're always right), but a simple reading of the search page makes it clear the use of the words and, or, and not in the search rules. It's even underlined for you. In this case, you just got lucky. If you were doing a broader search these rules help a lot. See below.
_________________ 89 Westy 2.1 Auto |
davevickery Samba Member
Joined: July 16, 2005 Posts: 2887 Location: Fort Collins, CO
bluebus86 Banned
Posted: Sun Jun 26, 2016 5:59 pm Post subject: Re: Using the under mount spare space for storage |
PDXWesty wrote: |
I hate to disagree with you, (because I know you're always right), but a simple reading of the search page makes it clear the use of the words and, or, and not in the search rules. It's even underlined for you. In this case, you just got lucky. If you were doing a broader search these rules help a lot. See below. |
apparently the default is AND. put in "spare storage" and search for any terms or all terms made no difference. however put in only "spare" and you get a lot more results. one could conclude then that the and statement is the default choice. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
danfromsyr Samba Member
Posted: Sun Jun 26, 2016 6:58 pm Post subject: Re: Using the under mount spare space for storage |
want to get on a hot topic...
I have a 9gal aux gas tank up under in lieu of the spare.. _________________
Abscate wrote: |
bluebus86 Banned
Posted: Sun Jun 26, 2016 8:10 pm Post subject: Re: Using the under mount spare space for storage |
danfromsyr wrote: |
I have a 9gal aux gas tank up under in lieu of the spare.. |
Dont rear end a Pinto!
believe you me, pdxwesty knows I am always right, and lucky! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
shadetreetim Samba Member
Joined: January 10, 2011 Posts: 1994 Location: Riverside, California
