gblair Samba Member
Posted: Sun Jun 26, 2016 4:22 am Post subject: light bulb chart |
Is there a light bulb chart somewhere? I hope to get my car back tomorrow and the reassembly will begin. I want to change all of the lamps while it it apart but what I have in the car now is all over the place. Front turn signals one is 1157 one is 2057 the small lamp i can not see any identifier on either but they are different. I have LED headlights which worked great last year so I am good on that one. Basically need the front and rear turn signal bulbs and the license plate light. Thanks for the help. |
EDragnDean Samba Member
Joined: July 13, 2005 Posts: 1148 Location: Vancouver, WA
Captain Spalding Samba Member
Joined: February 19, 2005 Posts: 2519 Location: . . . in denial.
Posted: Mon Jun 27, 2016 6:58 pm Post subject: Re: light bulb chart |
gblair Samba Member
Posted: Tue Jun 28, 2016 7:40 pm Post subject: Re: light bulb chart |
Thank you |
oasis Samba Member
Posted: Wed Aug 10, 2016 8:20 am Post subject: Re: light bulb chart |
Is there any way of knowing the output in watts for these bulbs (or at least for the front and rear turn signals)? _________________ Now: 2003 New Beetle Turbo S / 1990 Single Cab Transporter / 2014 Tiguan R-Line 4motion / 2013 Tiguan S / 2002 Golf GLS TDI
Past: 1974 Thing Acapulco / 2009 Eos Komfort / 1997 Jetta GT / 2002 Cabrio GLX / 2002 Passat GLS / 1971 Super Beetle / 1993 EuroVan MV Westfalia / 1981 Pickup LX / 1985 Vanagon / 1986 Jetta GLI |
kenj06 Samba Member
ldj1002 Samba Member
Posted: Wed Aug 10, 2016 2:00 pm Post subject: Re: light bulb chart |
oasis wrote: |
Is there any way of knowing the output in watts for these bulbs (or at least for the front and rear turn signals)? |
On my tail light right below the bulb it tells the watt and candlepower |
Posted: Wed Aug 10, 2016 4:28 pm Post subject: Re: light bulb chart |
I had a couple of free minutes.
Per Bulbs.com:
6014 . . . . Sealed beam headlights: 60/50 watts
1034 . . . . Front turn signal/parking: 23/8.3 watts
57 . . . . . . Side Marker Lights: 3.36 watts
1073 . . . . Rear turn signal: 23 watts
1073 . . . . Stop lights: 23watts
67 . . . . . . Tail lights: 8 watts
1073 . . . . Back-up lights: 23 watts
89 . . . . . . License plate light: 7.5 watts
211 . . . . . Map light: 12.4 watts |
oasis Samba Member
Posted: Sat Aug 13, 2016 12:40 pm Post subject: Re: light bulb chart |
Ha! I thought it was 23 watts! I looked through all of my resources and came up empty. I must have seen it on the bulbs when I was tried to replace the rear lens covers but failed. I never thought to look on the bulbs intentionally for verification.
Thanks!
There are some "no resistor needed, no hyperflash" LED bulbs on eBay. The body of the ad says 18-watt resistance built in. So, I was right for being spooked that these still might cause hyperflash. _________________ Now: 2003 New Beetle Turbo S / 1990 Single Cab Transporter / 2014 Tiguan R-Line 4motion / 2013 Tiguan S / 2002 Golf GLS TDI
