DaBraink Samba Member
Posted: Sat Jun 25, 2016 7:40 pm Post subject: Fulcrum type floor jack |
Is this a factory VW jack? If so was one made for busses?
_________________ If it ain't broke.................find something else to fix.
There's never enough time to do things right, but always enough time to do them over. |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7047 Location: Lawrenceville, Ga
Posted: Sat Jun 25, 2016 8:19 pm Post subject: Re: Fulcrum type floor jack |
interesting piece, never seen one _________________ regards
Uli
Malokin Martin Samba Member
Posted: Sat Jun 25, 2016 9:37 pm Post subject: Re: Fulcrum type floor jack |
Oh man I want one of those |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Posted: Sat Jun 25, 2016 10:44 pm Post subject: Re: Fulcrum type floor jack |
Maybe that was the one used before they decided it might be better to have one that would stow easier.... and impress Archimedes a little more.
I'm sure you could make one for a bus... might be a little cumbersome.
"Give me a lever long enough and a fulcrum on which to place it, and I shall move the world." _________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
Posted: Sat Jun 25, 2016 11:03 pm Post subject: Re: Fulcrum type floor jack |
It would be hard to carry around but really quick to use.
I wonder if this was used at the factory and also what the opening at the top was for, a tie down? _________________ If it ain't broke.................find something else to fix.
BarryL Samba Member
Joined: November 01, 2004 Posts: 14257 Location: Casa de Oro, California
Posted: Sun Jun 26, 2016 9:27 am Post subject: Re: Fulcrum type floor jack |
Ahem...that replaced the harpoon...nothing VW; you ought to see the pole and reel. |
Posted: Sun Jun 26, 2016 2:08 pm Post subject: Re: Fulcrum type floor jack |
The reason it appears to be a tool is the end nearest the vehicle has what appears to be a rod going into the jack point. That, with its length, would suggest it could be used to lift the vehicle. _________________ If it ain't broke.................find something else to fix.
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Sun Jun 26, 2016 2:50 pm Post subject: Re: Fulcrum type floor jack |
I think that would only work on a car with the round jack hole like a KDF or very early beetle?
Would be slick for a quick tire change or valve adjustment |
EverettB Administrator
Joined: April 11, 2000 Posts: 69802 Location: Phoenix Metro
Posted: Sun Jun 26, 2016 9:57 pm Post subject: Re: Fulcrum type floor jack |
I'm curious what sort of force would be needed to lift the vehicle.
I'm no fulcrum expert but if you need 1000 lbs. of force and that long arm is 5' and the short one is 1' it looks like 200 lbs of force.
That seems a bit high for a normal user so maybe my math is off.
Or it's not 1000 lbs of lift needed. _________________ How to Post Photos
velvetgreen Samba Member
Posted: Mon Jun 27, 2016 6:04 am Post subject: Re: Fulcrum type floor jack |
well if it isn't a jack then it sure could double for braking by being used as an anchor. storing it in the vehicle might be a issue however |
easy e Samba Member
Posted: Mon Jun 27, 2016 6:18 am Post subject: Re: Fulcrum type floor jack |
EverettB wrote: |
That seems a bit high for a normal user. |
Maybe not an expert, but you're correct.
In general the effort force can be expressed as
Fe = Fl (dl / de)
where
Fe = effort force (what we're solving for)
Fl = load force (say 1,000 lb)
dl = distance from load force to fulcrum (say 1 ft)
de = distance from effort force to fulcrum (say 5 ft) _________________ aka: Evan
Abscate Samba Member
Joined: October 05, 2014 Posts: 22639 Location: NYC/Upstate/ROW
Posted: Mon Jun 27, 2016 7:38 am Post subject: Re: Fulcrum type floor jack |
The mechanical advantage on that puppy is more like 8-10:1, so you would only need about 80 pound force on that lever to lift a 1800 pound curb weight VW.
The eye at the top is to store it on its hook on the wall, of course. _________________ .ssS! |
MrPolak Samba Member
Joined: June 20, 2004 Posts: 1337 Location: AG ,atnaltA
Posted: Mon Jun 27, 2016 7:42 am Post subject: Re: Fulcrum type floor jack |
easy e wrote: |
EverettB wrote: |
Fe = Fl (dl / de)
where
de = distance from effort force to fulcrum (say 5 ft) |
You need to use the ratio of distance of the lever pull to the distance the jack point moves. In this case the mechanical advantage is rather high since the car moves vertically only a small distance. |
Clara Samba Member
Posted: Mon Jun 27, 2016 7:46 am Post subject: Re: Fulcrum type floor jack |
Abscate wrote: |
The eye at the top is to store it on its hook on the wall, of course. |
And you are not lifting the entire bug, but just one side.
I think a square peg goes in the jack point, the peg pivots in the tool.
Useful tool for an emergency vehicle come to change a tire. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Posted: Mon Jun 27, 2016 8:10 am Post subject: Re: Fulcrum type floor jack |
It really seems like it would need more of a nub (height) if it was meant to switch out a tire though... |
Col_Forbin Samba Member
Joined: November 25, 2011 Posts: 84 Location: Austin, Texas
Posted: Mon Jun 27, 2016 9:38 am Post subject: Re: Fulcrum type floor jack |
Malokin Martin wrote: |
I was thinking that too but maybe you are supposed to double pivot it until the long arm is on the ground and you stand on it to hold it in place.
I think it might be high enough at that point. _________________ How to Post Photos
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51121 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Jun 27, 2016 10:02 am Post subject: Re: Fulcrum type floor jack |
Maybe it's not for tire changes, it could be for shifting the car sideways in tight garages, or getting out after some ass traps you in between other parked cars.
Looks like alot of other big prybars for moving frieght employed in the pre forklift days, but more specialized for a specific use. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2204 Location: UK (South)
Posted: Mon Jun 27, 2016 11:55 am Post subject: Re: Fulcrum type floor jack |
Not saying whether it's a jack or not, but for what it's worth, F1 teams employ quick lift lever-type jacks for tyre changes during races. Different shape, same premise...
_________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
easy e Samba Member
Posted: Mon Jun 27, 2016 12:22 pm Post subject: Re: Fulcrum type floor jack |
MrPolak wrote: |
Is this better... (Beetle is 4'-11" high)
