Phaedrus Samba Member
Joined: January 06, 2014 Posts: 500 Location: Washington
Posted: Sat Jun 25, 2016 6:10 pm Post subject: Timing Question: Any Harm in Increasing the Advance? |
As the title says. Curious. Playing around with the timing after a full tune, I noticed a marked difference in pep advancing about 4 degrees past 37 btdc. Nothing crazy, but just a little bit quicker response. Didnt really notice much difference on hills. Idle was a bit high though, maybe 900-1k. Set her back to 37 degrees, proper idle.
Question is, does it hurt the engine in any way to increase the advance? What are the downsides? I.e. why should I not go past 37 btdc? _________________ 1986 WBX (Tin Top Camper) |
captcory Samba Member
Posted: Sat Jun 25, 2016 6:19 pm Post subject: Re: Timing Question: Any Harm in Increasing the Advance? |
too much advanced timing will cause pinging "detonation" and can burn a hole in the top of your piston. _________________ Cory Cotherman |
Posted: Sat Jun 25, 2016 6:27 pm Post subject: Re: Timing Question: Any Harm in Increasing the Advance? |
K, but how much is too much? Ive heard the wbx is pretty resilient to pinging. How much room do we have to play with? 4 degrees, 10 degrees, 20? Gimmie more to ruminate on. _________________ 1986 WBX (Tin Top Camper) |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9798 Location: Mt Lemmon, AZ
Posted: Sat Jun 25, 2016 7:24 pm Post subject: Re: Timing Question: Any Harm in Increasing the Advance? |
I've run 40° BTDC all-in with all hoses connected for many years w/o issue - this on a GoWesty 2.2L Digijet.
The risk is pinging as noted. You can listen for pinging at low speed (accelerating hard in 4th to create a load).
The problem is a ping at high speed -- you'll probably never hear it -- and that is the ping that will get you. |
UrS6Vanagon Samba Member
Joined: August 26, 2012 Posts: 31 Location: Nederland, CO
Posted: Sat Jun 25, 2016 8:00 pm Post subject: Re: Timing Question: Any Harm in Increasing the Advance? |
I advanced my timing an additional 4 degrees to help compensate for the high elevation where I live (8500 ft). Most of my driving is in the 7k-12k ft range, and from what I've read it's safe to advance it a few degrees if your normally above 4k-5kft. It's helped the engine feel a little more lively and I haven't had any pinging. _________________ 1986 Westfalia Weekender
2019 VW Golf R
1995 Audi S6
1987 Audi 4000 quattro
2011 Nissan Pro-4x |
bluebus86 Banned
Posted: Sat Jun 25, 2016 8:14 pm Post subject: Re: Timing Question: Any Harm in Increasing the Advance? |
UrS6Vanagon wrote: |
I advanced my timing an additional 4 degrees to help compensate for the high elevation where I live (8500 ft). Most of my driving is in the 7k-12k ft range, and from what I've read it's safe to advance it a few degrees if your normally above 4k-5kft. It's helped the engine feel a little more lively and I haven't had any pinging. |
So you mean you havent heard any pinging right?
Note inaudiable pinging can be destructive. use of high octane fuel can help compensate, but high octane fuel is not readily available in many areas. in some areas of california, 91 is the highest at most stations, sure some places offer racing fuel at near 2 times the price.
VW I am sure would have set the timing as far advanced as they felt safe for running using normal fuels. why would they not set it for added power if no down side. try it at your own risk. damage may not be apparent for a long time, maybe. engine life may suffer, it is all a matter of degree! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Sat Jun 25, 2016 8:38 pm Post subject: Re: Timing Question: Any Harm in Increasing the Advance? |
Ah, yes, but the prophet hath spoken to the Vanagon God and doth bequeath us with His knowledge:
tencentlife wrote: |
The 2" mark is 35deg. BTDC. You can vary the setting 5 deg. either side of the 2" mark (timing spec is 35 +/- 5 BTDC at 3k rpm). Maybe yours likes a little more or a little less.
I misspoke when I said 37. My old mark is the standard 35, all in, all connected (tencent method). I'm gonna push it back up to 37/38 and see how she does. Heard no pinging @ ~40 at any and all throttle openings. Only downside is the slightly high idle. Makes the summertime traffic jams a little more... heat-inducing _________________ 1986 WBX (Tin Top Camper) |
Posted: Sat Jun 25, 2016 9:32 pm Post subject: Re: Timing Question: Any Harm in Increasing the Advance? |
Yeah, I mean I haven't heard any pinging. I've been driving it this way for about 10 years without any issues. The need for higher octanes to reduce pinging also decreases with elevation, however I've always used 91. I wouldn't run too much advance at sea level but for my application it runs better overall. Apples to Oranges but my 2011 Nissan truck has the option to advance the timing 2 degrees. This can be done at the dealership or with an aftermarket programmer. Why didn't Nissan just make all of their Frontiers run the additional 2 degrees if they can safely handle it? _________________ 1986 Westfalia Weekender
2019 VW Golf R
1995 Audi S6
nemobuscaptain Samba Member
danfromsyr Samba Member
Posted: Sun Jun 26, 2016 7:03 pm Post subject: Re: Timing Question: Any Harm in Increasing the Advance? |
you can always add a stand alone knock sensor monitor and then adjust accordingly.
it's best to be educated when messing away from factory settings.
https://www.google.com/webhp?sourceid=chrome-insta...k%20sensor _________________
Abscate wrote: |
jberger Samba Member
Posted: Mon Jun 27, 2016 11:31 am Post subject: Re: Timing Question: Any Harm in Increasing the Advance? |
The WBX is resistant to knock.. however it is quite a bit less so if you have Brazilian Piston sets or some other hackery that increases deck height.. That being said, the Digifant protraining manual states something about checking total advance after setting idle timing that it must advance 35° over the initial setting +or- 5°.. so I have always taken that to mean 45° of advance at 3000rpm is safe for stock engines. And indeed I have driven them timed like that for Thousands and thousands of miles. YRMV.
As a side note, as can be read in some of my engine build threads I have also experienced severe knock\pinging in non stock engines, over time\miles and the heads of the pistons were just fine. The only results... rod bearings that will fall off the rod when disassembled from the hammering action. Not damaged or spun mind you, just un-sprung |
DenCon Samba Member
Posted: Sun Aug 14, 2016 1:28 pm Post subject: Re: Timing Question: Any Harm in Increasing the Advance? |
I just set my '85 to 40° BTDC (everything connected, ≈3K RPM). Woke that Vanny right up and it starts more easily and I haven't heard detonation. |
jackbombay Samba Member
Joined: October 19, 2007 Posts: 2723 Location: Eastern Idaho
Posted: Sun Aug 14, 2016 1:47 pm Post subject: Re: Timing Question: Any Harm in Increasing the Advance? |
bluebus86 wrote: |
VW I am sure would have set the timing as far advanced as they felt safe for running using normal fuels. why would they not set it for added power if no down side. |
Advancing timing increases NOx emissions, that is why VW doesn't spec the timing for the edge of pinging, because the vehicle wouldn't pass emissions testing. _________________
Gas struts to pop your top easily!
Pop Top strut kits now available for late Bay window Westies
Samba ad here.
DIY artificial rain gutters (ARGs) |
