danielzink Samba Member
Joined: August 03, 2004 Posts: 282 Location: Lansing Michigan
Posted: Sat Jun 25, 2016 11:51 am Post subject: New arms - advice on correct way to make disc brake kit work |
Got some new arms and had some other issues with the stub axles (see previous thread) and now I need to sort out my existing disc brake kit.
Here's the bracket mounted with the stock spacer:
I've verified that everything sits flush and nice but there seems to be a difference with these aftermarket bearing carriers.
Here's the bracket and mounted:
And here's the issues:
It's not much...maybe 1/16th or even 1/8th off...
I've got a local shop that I can do a drop off and they'll machine the brackets...I'm wondering if I have 1/8th milled down here - will it affect the strength of the bracket much:
The other option is to use a thinner "front" shim to pull the rotor in a smidge.
I can't find online thinner front spacers...but with my other previous issues I got some various thickness "rear" shims:
Would it be a bad idea to use the thinnest rear spacer in the front ?
Any advice/help is appreciated.
Thanks !
Dan _________________ 1965 Notchback 2300cc Type4
Subaru Powered Rail
1915 Rail
www.danielzink.com |
Dale M. Samba Member
Posted: Sat Jun 25, 2016 4:33 pm Post subject: Re: New arms - advice on correct way to make disc brake kit work |
It all comes down to the arms being a bad product and manufacture put it back on you....
tripicana Samba Member
Joined: February 13, 2003 Posts: 1164 Location: colorado springs
Posted: Sun Jun 26, 2016 7:59 am Post subject: Re: New arms - advice on correct way to make disc brake kit work |
Those brackets look THICK. From the pics, there are no threads past the end of the axle nut? Not much axle spline engagement?
Is the axle seal supposed to go into the bracket, and not use the stock seal cover? The axle seal isn't sealing anything on a splined area.
I know this doesn't address your caliper alignment issue, but something else looks funny here... _________________ foam cowboy hats aren't good helmets. |
Posted: Sun Jun 26, 2016 1:50 pm Post subject: Re: New arms - advice on correct way to make disc brake kit work |
tripicana wrote: |
I know this doesn't address your caliper alignment issue, but something else looks funny here... |
Here are some better pics.
This is the fully "assembled and torqued to spec" side:
Now...on the other side this is what I have for spline length:
and rotor spline depth:
Both...by my unexact measurements are at 2 1/2"...
Let's be honest here....I'm not getting my money back for these arms...I've drilled them for my spring plates....I've welded shock mounts to them....blah blah blah...I don't have the kind of cash to throw at another set of arms and bin these...
By my logic I have a couple of options....
If spline engagement looks liveable then I have the mounting surface of the caliper mount machined (as shown earlier):
If I need more spline engagement then I can do (2) things:
Have the thicker shims I used machined down a smidge:
and...*maybe ?* have the face of the caliper mount bracket shaved a bit as well ?:
All of that is going to cost me a whole lot less than starting over with a new set of arms....
Thoughts ?
Thanks, Dan _________________ 1965 Notchback 2300cc Type4
Subaru Powered Rail
1915 Rail
Dark Earth Samba Member
Posted: Sun Jun 26, 2016 2:07 pm Post subject: Re: New arms - advice on correct way to make disc brake kit work |
Just a thought ... Measure how thick your original stock inner and outer spacers were. Determine if you can get away with a little bit thinner spacer on the inside, where you were rubbing before. If you can ... have the inside spacer machined down to where it isn't rubbing, but has minimal space between the axle and the hub, then machine the outer spacer down to where the inside and outside spacers equal the measurement of your original stock spacers. If you can't get away with a thinner inner spacer, maybe just machine the outer spacer until you get an equal inner and outer spacer measurement as the original, like you're already talking about. Then if the caliper still doesn't fit, you'll have no choice but to machine it down as well. You'll have a one off set-up, but you should be able to get it to work if it's only off by 1/16"-1/8". _________________ My Build: '69 Baja - Dark Earth Version
~I'm almost done. I just lack finishing up.~ |
Posted: Sun Jun 26, 2016 2:50 pm Post subject: Re: New arms - advice on correct way to make disc brake kit work |
Another thought ... Are the hubs in the aftermarket arms the same as the stock arms ?
If so, they were welded too deep towards the inside. If that's the case, it might be better to machine the inside of the hub 1/8" and stick with the stock bearing spacers. ( other-wise the axle and cv's are being pushed towards the trans as well).
If the hubs are different, maybe the machinist can make the aftermarket hubs identical to the stock hubs enabling you to use the stock bearing spacers.
You have a lot of variables. I'm just spit-balling ideas here. _________________ My Build: '69 Baja - Dark Earth Version
B Ramsey Samba Member
Joined: February 05, 2006 Posts: 477 Location: Ramona ca.
Posted: Sun Jun 26, 2016 3:32 pm Post subject: Re: New arms - advice on correct way to make disc brake kit work |
lose the caveman caliper bracket and make your own, and weld it to the arm. _________________ Go outside and do something. |
Posted: Sun Jun 26, 2016 5:00 pm Post subject: Re: New arms - advice on correct way to make disc brake kit work |
The thickness of caliper bracket also has effect on how bearing retainer plate clamps bearing in place.... IF bearing outer shell is not clamped proper bearing can move laterally and also rotate, neither thing is good...
I would backup and step or two and grind the rim of bearing holder till you get flange clearance, then deal with brake caliper/rotor... You initial problem with shaft fit up on rear of arm is still killing you even with manufacturers patch up with extra wide spacer.... VW made everything to specific tolerances/dimensions and it works on 10,000,000 cars what is one thing on your car that was initial indicator there was a problem....
A big part of your problem starts here.... And more shims are not the answer
cbeck Samba Member
Posted: Mon Jun 27, 2016 6:31 am Post subject: Re: New arms - advice on correct way to make disc brake kit work |
Do you have a og stub you can stick in there and see if you have the same issue? Some thing is machined wrong. If you are lucky it will be the stub, some thing tells me you won't be that lucky. I would start with what Dale said, and add don't remove all the weld and make flush,that might weaken the area. If the bearing spacing is off from the housing you may have to resort to all of the above. Good luck and let us know how you work it out. I wanted to add on my aftermarket arms and stubs I have about 1/8 " of axle sticking out past the end of the axle nut. |
Posted: Mon Jun 27, 2016 7:40 am Post subject: Re: New arms - advice on correct way to make disc brake kit work |
In picture of fully torqued axle nut do you have full access to cotter pin hole... If not, its not good....
And with pictures like one below with parts (stub shaft) not fully inserted, its hard to tell what you are trying to do becasue partial install of parts visually confuses people as the are trying to figure out what is going on and problem is not clearly shown... Remember we can only make suggestions based on information you provide...
And I would NOT machine off any material here as it is where the threads are that hold the bolts that hold caliper, any reduction of thread reduces reliability of brake system....
Also can you explain the difference in rotor/caliper position in these two pictures...
Posted: Mon Jun 27, 2016 9:15 am Post subject: Re: New arms - advice on correct way to make disc brake kit work |
Dale M. wrote: |
Yes - plenty of access for the cotter pin
Apologies..
Okay
Just different views. One from the back side and one from the front.
Subaru Powered Rail
1915 Rail
Posted: Mon Jun 27, 2016 7:16 pm Post subject: Re: New arms - advice on correct way to make disc brake kit work |
danielzink wrote: |
Dale M. wrote: |
Apologies..
Okay
What confuses me is in the two different pictures the caliper is in two different positions to center casting line for caliper.... whibh picture is correct...
Posted: Thu Jul 07, 2016 8:04 am Post subject: Re: New arms - advice on correct way to make disc brake kit work |
I'm slowly coming to a resolution on this...
I've ground down the back of the bearing housing so that I can use the stock rear spacer and get proper spline engagement as well as more threads on my castle nut.
Still having issues with the caliper mount.
Turns out there are a couple different "thicknesses" between the different styles of mount.
my existing mount:
Two other styles:
difference in mount thickness:
all three mounts:
The issue is of course...with the arms I have...the thicker mount is pulling the bearing cap away from holding the bearing properly.
This could potentially let the outside bearing move at least 40 or 50 thou....
I have choices...
I could buy a set of the black (thinner) mounts...wait for them to get here from wherever...
or...again....
Take my mounts to a local machine shop and have them milled to the proper thickness...
Subaru Powered Rail
1915 Rail
Posted: Thu Jul 07, 2016 8:33 am Post subject: Re: New arms - advice on correct way to make disc brake kit work |
or make your or mount and weld it to the arm. I have done this before its not a big deal.
-but-
even with the mount installed, how can the bearing be loose in the housing, if axle nut is torqued? _________________ Go outside and do something. |
Posted: Thu Jul 07, 2016 9:26 am Post subject: Re: New arms - advice on correct way to make disc brake kit work |
B Ramsey wrote: |
-but-
even with the mount installed, how can the bearing be loose in the housing, if axle nut is torqued? |
Outer bearing....
....the inner race "floats" being as it's a needle bearing - not a roller bearing like the rear.
You can take out the inner race and leave the bearing in place.
The bearing itself is secured by the bearing cap. _________________ 1965 Notchback 2300cc Type4
Subaru Powered Rail
1915 Rail
Posted: Thu Jul 07, 2016 5:22 pm Post subject: Re: New arms - advice on correct way to make disc brake kit work |
danielzink wrote: |
B Ramsey wrote: |
-but-
Outer bearing....
The bearing itself is secured by the bearing cap. |
ok, you have a different setup than anyone else. ever. _________________ Go outside and do something. |
cbeck Samba Member
Posted: Thu Jul 07, 2016 5:48 pm Post subject: Re: New arms - advice on correct way to make disc brake kit work |
Those weld on caliper mounts might be the easy way out. You might have to modify[grind a little] but you center your caliper on the rotor after mounting it to the mounting bracket and buzz the mount on to the arm. |
Posted: Thu Jul 07, 2016 6:21 pm Post subject: Re: New arms - advice on correct way to make disc brake kit work |
B Ramsey wrote: |
danielzink wrote: |
B Ramsey wrote: |
-but-
Outer bearing....
ok, you have a different setup than anyone else. ever. |
I think he's saying the inner race of the outer roller bearing is removable. Not that you'd run without it, but it's unlike the inner bearing where the inner race is non removable.
Posted: Thu Jul 07, 2016 6:58 pm Post subject: Re: New arms - advice on correct way to make disc brake kit work |
Ahem ... Caliper mount bracket will have effect on how outer bearing outer race is clamped, depending on year model of ends of axle tubea, as depth of bearing insert in each of the bearing caps... Also the thickness of caliper brackets that are different will also effect clamping ability of bearing cap....
Only some serious time with measuring tools are going to solve your problem... Then gettong proper alignment of caliper on bracket is stil at issue....
Posted: Fri Jul 08, 2016 8:29 am Post subject: Re: New arms - advice on correct way to make disc brake kit work |
Well I'm up and running again.
Took it for a test drive last night and everything is perfect.
After looking at the relative "flimsy-ness" of the stamped brackets vs my cast bracket - I went ahead and had my brackets machined.
This brought the bearing cap down perfectly.
As far as centering the caliper - I'm just about perfect. The pic looks like it's a smidge off but that's just the angle.
There should be no worries regarding the threads for the caliper mounting bolts. The bolts actually go deeper into the bracket itself now - and are of course Loctite'd.
Thanks everyone.
Subaru Powered Rail
1915 Rail
