Rowens54 Samba Member
Joined: September 13, 2015 Posts: 17 Location: Hillsboro, ND
Posted: Fri Jun 24, 2016 3:45 pm Post subject: Stuck |
I am currently stuck in 2nd gear and cannot get out of it. I was driving and may have push down on shifter and the seemed like it got stuck in second. I can move my shifter but cannot find second gear. I can push it down and back but cannot find reverse. Any help would be great.
Thank |
EDragnDean Samba Member
Joined: July 13, 2005 Posts: 1148 Location: Vancouver, WA
Posted: Fri Jun 24, 2016 5:12 pm Post subject: Re: Stuck |
Try and get it into third and fourth both pressing down and not pressing down. |
germanbilly Samba Member
Joined: October 18, 2013 Posts: 378 Location: Victorville
Posted: Fri Jun 24, 2016 9:17 pm Post subject: Re: Stuck |
If none of that works get under it and take the fill plug out of the transmission and put a screw driver in the hole. Be careful, and pry the shift arm back and forth. You will feel a click when it moves. Some times it will work some times not. If it sticks again then it is rebuild time.
GB |
Posted: Sat Jun 25, 2016 7:04 am Post subject: Re: Stuck |
So if the transmission is shot what are the next options.
Would you go the same trans or upgrade to better?
What is a cost of trans or rebuild of old?
Can any transmission shop do a rebuild of a 1973 thing trans or do I need to find a specialist in the Congo that only works on Thing trans?
Thanks for any help. |
Posted: Sat Jun 25, 2016 7:21 am Post subject: Re: Stuck |
Pull it and have it rebuilt. There are several businesses that specialize in German transmissions. If you are driving it primarily on the road you might consider a slightly higher gearset, I would stay away from a freeway flier gearing. |
Joined: February 21, 2003 Posts: 868 Location: Clifton Park NY Saratoga County
Posted: Sun Jul 10, 2016 1:10 pm Post subject: Re: Stuck |
the fork inside the transmision is stuck, you can get to it with a screwdriver if you take out the filler plug on the side
theres a way to fix it with a screwdriver thru the hole
just not sure exactly how... _________________ Michael Basso
http://www.thingparts.com
New and Used VW Thing Parts Free advice
CALL 518 630 0173 |
