fxportapot Samba Member
Posted: Fri Jun 24, 2016 12:12 pm Post subject: Pivot arm bolt |
Hmm I started hearing a clunk from the rear, something is missing here....!!
Relyt Samba Member
glutamodo The Android
Joined: July 13, 2004 Posts: 26311 Location: Douglas, WY
Posted: Fri Jun 24, 2016 12:34 pm Post subject: Re: Pivot arm bolt |
next question is, did it just loosen and fall out or did it break off with the threads still in it? If It loosened the threads might be messed up some, if it broke then you'll have to deal with extracting the remains. _________________ Andy T.
Posted: Fri Jun 24, 2016 12:43 pm Post subject: Re: Pivot arm bolt |
I hadn't thought that maybe it broke.... i'm hoping it just backed out. I'll have to check!! |
enjoyther1de Samba Member
Joined: December 19, 2010 Posts: 1279 Location: chino,ca
Posted: Fri Jun 24, 2016 1:00 pm Post subject: Re: Pivot arm bolt |
Preventative measures. _________________ HBB took me to BBV. |
Posted: Fri Jun 24, 2016 2:41 pm Post subject: Re: Pivot arm bolt |
enjoyther1de wrote: |
Preventative measures. |
I dig the idea! |
helowrench Samba Member
Joined: August 27, 2003 Posts: 567 Location: dallas texas
Posted: Sat Jun 25, 2016 10:19 am Post subject: Re: Pivot arm bolt |
mine:
[img][/img]
[img][/img]
[img][/img] _________________ Current VWs:
70 bug vert for wifey
73Thing bucket o rust
73 914 1.7
12 Passat 2.5 Highway cruiser |
Posted: Sat Jun 25, 2016 10:23 am Post subject: Re: Pivot arm bolt |
I want to say the holes were drilled with a #50 drill bit, and the safety wire is .025"
(but I have slept since then) _________________ Current VWs:
73 914 1.7
