bridgemute Samba Member
Posted: Fri Jun 24, 2016 8:26 am Post subject: wheel width question |
I purchased some used original VW rims from a local guy but I didn't realize at the time that 2 of them were 4Jx15 and 2 were 4.5Jx15. I had sand blasted them and realized something was up. Since I went through the effort of sandblasting, I don't really want to search for 2 more wheels and start over. The tire size I purchased was 165x80x15.
My question is: will this affect overall tire height on the wider wheels vs. the narrower wheels. I plan on putting the wider wheels on the back and I don't expect to see much difference. I was wondering if anyone else had experience with this. |
beetlenut Samba Member
Posted: Fri Jun 24, 2016 10:06 am Post subject: Re: wheel width question |
It means the tire would sit a 1/4 inch further out on each side. On tires with that tall of profile, I doubt you could even see the difference, let alone worry about the overall difference in diameter of the two. I'd say roll them and be happy with freshly painted rims and new tires! _________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
Posted: Fri Jun 24, 2016 10:33 am Post subject: Re: wheel width question |
That is my plan! I appreciate the feedback, I wonder if anyone has done this? |
ach60 Samba Member
Joined: May 14, 2001 Posts: 4139 Location: Santa Maria
Posted: Fri Jun 24, 2016 11:39 am Post subject: Re: wheel width question |
The lesson I learned was to check for bent rims.
I put the 145's on a set of 4", lowered the car 2" with lowering struts, and went to reset my toe in.
3 tries, and I couldn't set it! Finally I discovered rims where bent.
I went through my stash of old rims and found that 3 of the 6 I had were bent! _________________ Good Luck
Al |
DeathTrap Samba Member
Joined: February 26, 2004 Posts: 1757 Location: Sacramento/Vermont
Posted: Fri Jun 24, 2016 11:56 am Post subject: Re: wheel width question |
And I believe the stock wheels come in different offset too. |
