D. Haviland Samba Member
Joined: October 30, 2009 Posts: 536 Location: Burlington, Vermont
Posted: Fri Jun 24, 2016 4:40 am Post subject: 12 to 6 volt conversion |
I'm converting a 12 volt engine back to 6 volt. It is running a 009 distributor. I'm wondering if the condenser has to be changed. Are there 6 and 12 volt condensers? |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Fri Jun 24, 2016 5:16 am Post subject: Re: 12 to 6 volt conversion |
no, it does not care about the voltage _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Posted: Fri Jun 24, 2016 4:01 pm Post subject: Re: 12 to 6 volt conversion |
Thank you |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76903 Location: Sneaking up behind you
Posted: Fri Jun 24, 2016 4:08 pm Post subject: Re: 12 to 6 volt conversion |
But the electric choke will need to be changed. _________________ Glenn
Member #1009
#BlueSquare |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51125 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Jun 24, 2016 4:12 pm Post subject: Re: 12 to 6 volt conversion |
And any solenoids on the carb as well. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Danwvw Samba Member
Posted: Mon Jul 26, 2021 3:42 pm Post subject: Re: 12 to 6 volt conversion |
I just did this and there is a lot to it. Mine was a 71 Dual Port Bus engine going into a 1960 Beetle while it's 36 Horse engine gets rebuilt. One thing leads to another.
1. 6 volt generator.
2. 6 volt generator generator stand with correct oil fill for the engine.
3. 12 to 6 volt starter bushing because I have a 68 transaxle that is 12 volt.
4. Probably need a 36 horse fan but I fit it in a aftermarket Doghouse 36 style fan shroud so I used the 36 horse generator backing plate and ran a late Dual Port Fan that I punched holes in for generator cooling as the 36 horse generator backing plates don't have cooling like the dog house backing plates.
5. I got a rebuilt 200mm 6 volt flywheel from "MOFOCO" so I could run a 1600 clutch with the 1600 engine.
6. 6 Volt coil.
7. An 6 volt Electronic Voltage Regulator because 6 Volt systems need all the help they can get.
8. I ran Dual NDIX 32 Porsche carbs that don't have any electrical on them so no solenoids or choke heater elements had to be changed.
_________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
