cabrioclueless00 Samba Member
Joined: June 23, 2016 Posts: 1 Location: south bend, in
Posted: Thu Jun 23, 2016 3:05 pm Post subject: 2000 VW Cabrio help! immobolizer! |
I have a 2000 VW cabrio that has an immbolizer issue. Ran a snap on computer on it and it was the only thing that popped up. If I hook the battery up, it will start twice and shut right off every time. I unhook the battery for a long while and hook it back up same thing. 117k on it. Automatic. 2 door. It's my girlfriend's and I want to get it going for her very badly. She drives long distance and my truck is going to die. Please help thanks.
I am pretty sure it's the immo 2 system |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Thu Jun 23, 2016 3:44 pm Post subject: Re: 2000 VW Cabrio help! immobolizer! |
You have two choices to clear it.
1. Take it to a dealer and have it cleared.
2. Find a local with VAG-Com and they can clear the code.
Does it have more than one key? Is it one of them immo it? If you have one good and one bad, you either need to set the bad one aside and never use it, or take it to the dealer and have them code it to the car, only the dealer can perform this function. If you only have one key and it is immo it, might as well have it towed to the dealer and get it over with. |
Joined: August 31, 2013 Posts: 12816 Location: North Carolina
Posted: Thu Jun 23, 2016 4:17 pm Post subject: Re: 2000 VW Cabrio help! immobolizer! |
One down & dirty trick is to remove both positive & negative cables from the battery & connect both CABLES to each other for 5 seconds & reattach them to the battery & try to restart the car. The module will sometimes remember the key after doing this. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
