rcproductions Samba Member
Posted: Thu Jun 23, 2016 11:04 am Post subject: Buggy won't start. Died while driving |
I have a 1969 beatle bug type 1 motor installed in a manx meyers style body. While driving the other day it just concked out and I was unable to get it running. Since I got it back to the shop I have made the following repairs. (ALL NEW) plugs, wires, distributor cap, rotor, points, condenser and fuel filter. Fuel pump is working, and coil has proper ohms. Now I can start the motor, but it runs at an iddle but runs like crap. I tried to adjust carbs, but can't keep it running long enough to get a proper tune on the carb. Heres the kicker.... I get absolutely no responce from throttle when I rev the motor. At that point motor wants to die again. Anyone got any Ideas?
Thanks in advance. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31385 Location: Hot Arizona
Posted: Thu Jun 23, 2016 12:37 pm Post subject: Re: Buggy won't start. Died while driving |
rcproductions wrote: |
it just conked out and I was unable to get it running. Since I got it back to the shop I have made the following repairs. (ALL NEW) plugs, wires, distributor cap, rotor, points, condenser and fuel filter. |
Congratulations; you threw parts at it before troubleshooting what was wrong. That was a big mistake. Now you get to troubleshoot the initial isue PLUS what you just did. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2745 Location: Hamble, Hampshire, UK
Posted: Thu Jun 23, 2016 12:56 pm Post subject: Re: Buggy won't start. Died while driving |
Does it stink of gas from the exhaust ? Did it die after a fast run when you slowed down ?
It could be the fuel metering valve in the carburettor is leaking and fuel is flooding into the engine so it is running if at all very rich.
While you were going fast the fuel air mix would be rich so the engine might have stumbled a little but once you slow down and the air flow stops the mixture goes way rich and it will stop. Sometimes if you stop and fiddle with the carburettor for about ten minutes it will briefly start again and die as the pool of gas in the manifold evaporates.
These valves are a part of one of the the 34PICT-3 service kits you can buy. And are a standard spare for other carburettors. _________________ Ancient vehicles and vessels
Dauz Samba Member
Posted: Thu Jun 23, 2016 1:28 pm Post subject: Re: Buggy won't start. Died while driving |
pull the jets from the carb(s) and blast carb cleaner through them. The smallest debri can wreak havoc. Happened to me on several occasion. |
smkn_vw Samba Member
Posted: Thu Jun 23, 2016 1:29 pm Post subject: Re: Buggy won't start. Died while driving |
Bad coil weak spark coil gets warm and konks out. _________________ "So didja?" -Bob Hoover |
