VW Horn Button Guy Samba Member
Joined: July 28, 2012 Posts: 4 Location: Cedar Park, TX
Posted: Thu Jun 23, 2016 9:37 am Post subject: Side markers... running lights or turn signals? Why not both??!! |
Dual purpose side markers with one bulb..
So not sure if someone has already done this or posted something similar....but I couldn't find much info on this.
My 66 is US spec, so all that factory "key in one position and turn signal switch on" stuff doesn't apply. (although I do have the euro parts to do it) I thought this was far more useful in today's traffic.
Thanks to a thread on here I as able to install the side markers in the correct location with ease. Thanks guys!
Originally I wired up my side markers to be turn signals. Not real thrilled with the driving at night thing....I decided to see if I could figure out how to get them to do both. Running light and turn signals at the same time.
I used a few relays and an old Hella relay box that had a busted off pin so it would never work again anyways. With a little logical thinking (I know alot about electronics and relay logic) I came up with this....
It all fit quite nicely in the original Hella relay box with only some slight, easy modifications to the new relays.
Then I found a nice, out of the way spot to mount it. I decided the easiest way to do it was here on the left side on the flat panel.
Ran a couple wires from the original flasher box to this new box and then the taillight terminal off the fuse box.
Viola! It works perfectly!
If I ever sell this car....the next owner is going to be scratching their head if they even need to do electrical work.
I think the install turned out pretty clean. If I can figure out how to upload a video I will. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Thu Jun 23, 2016 11:52 am Post subject: Re: Side markers... running lights or turn signals? Why not both??!! |
That is very nice & doing both functions! I'm gonna look for some used Hella flasher boxes to trade for? _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
inzel Samba Member
Joined: April 11, 2014 Posts: 196 Location: Spokane, WA
Posted: Thu Jun 23, 2016 12:36 pm Post subject: Re: Side markers... running lights or turn signals? Why not both??!! |
Nice work. Looks real clean _________________ --inzel--
66 Bug
69 Fasty
Old school Sandrail |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
Posted: Sat Jun 25, 2016 7:23 am Post subject: Re: Side markers... running lights or turn signals? Why not both??!! |
Thanks. I am super anal about wiring. I tried to use the factory color coded wiring and crimp on connectors too so someone one day will indeed be scratching their head as to wtf is going on. I think I've owned far too many rat nest wired cars over the years. Everyone is a VW electrician after all.....
Mike Fischer...if you want to send me a Hella relay box I'll make one for you and we can trade stuff for it....I have far too many cars to not need some trades for stuff... |
savannanotch Samba Member
Joined: August 30, 2015 Posts: 31 Location: Washougal,WA
Posted: Sat Jun 25, 2016 4:50 pm Post subject: Re: Side markers... running lights or turn signals? Why not both??!! |
Just a technical note . Italian versions of type 3 were wired similarly at the factory ,with the exception that the side markers acted only as blinkers not running lights .
I think a few other Euro versions were similar . This info is available in the technical section under M codes. |
Posted: Sat Jun 25, 2016 11:34 pm Post subject: Re: Side markers... running lights or turn signals? Why not both??!! |
savannanotch wrote: |
Canadian too, my '63 is like that and has amber side marker lenses _________________ How to Post Photos
