busmania Samba Member
Posted: Thu Jun 23, 2016 8:20 am Post subject: Help fixing my battery charger? |
I know this is random but several years ago, I drove my bus out of the garage with my battery charger still attached. The clamps on both sides came off and I have been putting off fixing it. Now I need to use it. BUT, the problem is, I don't know which wire had the red lead and which had the black. Does it matter which side I put each clamp (one red, one black) back on?
Thanks. |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Thu Jun 23, 2016 8:23 am Post subject: Re: Help fixing my battery charger? |
if you just pulled the clamps off the wire, turn it on and hook up a voltage meter, that will tell you what is the + side and negative _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51057 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Jun 23, 2016 9:44 am Post subject: Re: Help fixing my battery charger? |
Also try looking very closely at the wires, one may have squared edges or tiny ribs on the insulation. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31271 Location: Hot Arizona
Posted: Thu Jun 23, 2016 12:27 pm Post subject: Re: Help fixing my battery charger? |
60ragtop wrote: |
if you just pulled the clamps off the wire, turn it on and hook up a voltage meter, that will tell you what is the + side and negative |
This. DC voltmeter 0-20 volts will tell you what you want to need. Even the free ones from Harbor Freight, with coupon and a purchase. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Thu Jun 23, 2016 6:30 pm Post subject: Re: Help fixing my battery charger? |
With your charger on it's lowest output (2amp) setting, grab an accessory 12volt fan or an old 12v Makita drill without the battery and hotwire the leads. If the fan or drill spins the right way- you've got red and black right.
Please note I am purely guessing here- but I do a lot of McGyvering. _________________
EverettB wrote: |
FU#5 |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13843 Location: White Mountains Arizona
Posted: Fri Jun 24, 2016 7:00 am Post subject: Re: Help fixing my battery charger? |
Not sure where here is busmania. Just obtain an inexpensive VOM = Volt Ohm Meter. It is a handly tool in your tool box assuming that you even have one. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Cusser Samba Member
Posted: Fri Jun 24, 2016 7:15 am Post subject: Re: Help fixing my battery charger? |
Cusser wrote: |
60ragtop wrote: |
This. DC voltmeter 0-20 volts will tell you what you want to need. Even the free ones from Harbor Freight, with coupon and a purchase. |
If you can't afford or know how to use a multimeter, you probably shouldn't be driving an old VW. Or any vehicle. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
