Moondrip Samba Member
Posted: Thu Jun 23, 2016 12:16 am Post subject: New buggy windscreen - Measurements? |
I just recieved a new, aluminium windscreen from EMPI.
The measurements does confuse me. Which measurement is the correct one? Is there a difference when ordering? Is it adjustable? See attached pic
i would suspect that the screen fits from 41, 3/4" up to 42, 1/2. But why do they set 41, 3/4 inch as minimum
God forbid that my buggybody should be 40, 3/4" wide... or perhaps 41" (dead on) Then it wouldnt work at aaall(?)... Im honestly upset.
_________________ Old piece of junk! |
manxdavid Samba Member
Joined: November 24, 2003 Posts: 1841 Location: David Jones, Anglesey, North Wales, UK. Manxclub #678.
Posted: Thu Jun 23, 2016 1:05 am Post subject: Re: New buggy windscreen - Measurements? |
If it's 'frame only' I presume they mean you can trim the bottom rail to suit the width required, then get it glazed locally. |
Posted: Thu Jun 23, 2016 1:22 am Post subject: Re: New buggy windscreen - Measurements? |
manxdavid wrote: |
It is the "frame only" indeed. Hmm i would suspect so now when you say it _________________ Old piece of junk! |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20365 Location: Just a tiny bit west of Yosemite Valley
Posted: Thu Jun 23, 2016 7:11 am Post subject: Re: New buggy windscreen - Measurements? |
http://bugshieldsbydino.com/
Posted: Thu Jun 23, 2016 7:36 am Post subject: Re: New buggy windscreen - Measurements? |
Sure but when the OP said he'd just recieved the screen it sounded like he'd already bought one to me. |
Posted: Thu Jun 23, 2016 10:12 am Post subject: Re: New buggy windscreen - Measurements? |
manxdavid wrote: |
Frame (only) .... And it might be returnable ....
HeidelbergJohn4.0 Samba Member
Joined: March 01, 2004 Posts: 1199 Location: Havre de Grace, MD
Posted: Thu Jun 23, 2016 7:36 pm Post subject: Re: New buggy windscreen - Measurements? |
my Dino's windshield has about the same 3/4 inch of flex. between the mounting legs. _________________ 71 LWB Manx style dunebuggy
71 Beetle
71 Volksrod
Machette Speedster
2012 Passat TDI SE (sadly sitting in a buyback parking lot somewhere waiting for it's heart to be ripped out.) |
Posted: Mon Jun 27, 2016 4:47 am Post subject: Re: New buggy windscreen - Measurements? |
HeidelbergJohn4.0 wrote: |
my Dino's windshield has about the same 3/4 inch of flex. between the mounting legs. |
OK - So it is flexible. Tho pure aluminium. Does it need pre-heating Before "flexing/bending" the mountinglegs? _________________ Old piece of junk! |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16754 Location: State College, PA
Posted: Mon Jun 27, 2016 4:58 am Post subject: Re: New buggy windscreen - Measurements? |
Installed a new windshield on a Berrien recently. Seems like most windshields come complete, BUT you can have a local glass shop make your glass if needed. Just so its DOT safety glass for a street car.
Theres several things to know . First - the measurement is taken from the flat base of the windshield as it sits across the dash.
If the body was made using a mold that used the cowl area from a Myers Manx, the angle of the side of the dash is different on both sides, so you will need to bend (by hand and carefully) the bottom legs of the windshield diferently. Be careful. I ended up replacing the glass - not 100% sure if I put the little crack in the corner or if it was from shipping damage.
If you need, to add a little width, you can make aluminum spacers for the bottom rail. Take your time and you wont even notice them. I added 1/8" to the last one I did. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Mon Jun 27, 2016 5:11 am Post subject: Re: New buggy windscreen - Measurements? |
andk5591 wrote: |
If you need, to add a little width, you can make aluminum spacers for the bottom rail. Take your time and you wont even notice them. I added 1/8" to the last one I did. |
Yes, I will hav eto bend the legs slightly inwards in order to make the frame "hug" the dash of the body. Here goes! thank you _________________ Old piece of junk! |
