snowbug Samba Member
Joined: June 12, 2005 Posts: 167 Location: Oshawa Ontario Canada
Posted: Wed Jun 22, 2016 2:09 pm Post subject: Dist. Drive Washer |
I pulled my dist. drive part way out to turn it one tooth. The washer spacer went down in the engine. Can I get it out without a tear down? Can I get it out if I pull the oil pump? It is a 36hp. Engine is not in the car. thanks Jim _________________ Old enough to remember THRILLS, the gum that tastes like soap.
sgmalt46 Samba Member
Joined: April 20, 2005 Posts: 1296 Location: south san francisco
Posted: Wed Jun 22, 2016 4:35 pm Post subject: Re: Dist. Drive Washer |
oil pump. no. maybe if you pull the fuel pump. and use a skinny long magnet. _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back (sold) ! good luck with it Henry!
46 beetle 552nd royal army service corps CCG |
Posted: Wed Jun 22, 2016 6:03 pm Post subject: Re: Dist. Drive Washer |
The fuel pump is off and I can`t see it. Washer is down in the bottom I think. _________________ Old enough to remember THRILLS, the gum that tastes like soap. |
catahoula lou Samba Member
Joined: August 30, 2008 Posts: 594 Location: south of Silver Springs, NV
Posted: Wed Jun 22, 2016 6:10 pm Post subject: Re: Dist. Drive Washer |
You'll need to pull bakelite-type fuel pump base out if you want to fish it out that way. Buy an extra base, as they get fragile over time and can break.
OR: pull drain plate/"filter" out. Might be able to fish out with a magnet on a bent arm.
Best,
Thom _________________ 1 great wife
2 Catahoula Leopard Dogs (Mahogany Star and Spartan) - RIP Lucy, Braveheart, & Dusty!
1 1959 mango green Ragtop Bug (the "Mango")
1 1958 pantina red Lowlight Ghia (the "Chili Pepper")
Still looking for:
(1) My Dad's 1955 356 (he raced it amateur-class at Riverside and other courses during 1950s),
(2) My parent's black 1955 hardtop bug (CA license plate FWC 201 or FWG 201), and
(3) My parent's agave green 1957 ragtop bug (CA license plate LFK 734). |
Posted: Thu Jun 23, 2016 7:04 am Post subject: Re: Dist. Drive Washer |
Good news , the washer did not go down into the engine. Seems the starter jammed up on my engine tester. _________________ Old enough to remember THRILLS, the gum that tastes like soap. |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Thu Jun 23, 2016 11:31 am Post subject: Re: Dist. Drive Washer |
Did you find the spacer? |
