Flare Samba Member
Joined: June 22, 2016 Posts: 6 Location: Brisbane QLD
Posted: Wed Jun 22, 2016 3:55 am Post subject: Gutless after rebuild |
Hi all, I'm at my wit's end here, I just rebuilt a perfectly running 1600 to a 1776. The combo I'm running is 90.5mm pistons, 69mm VW crank, dp heads, Engle 110, and dual Solex 34 Pict 3 carbs with 130 main jets, electronic points and a 009 dizzy. I'm confident that the tappet timing is correct. Note, this is my first engine build also. I have managed to get the car running alright after quite a bit of tweaking of the carbs and dizzy - I managed today to get it running relatively nicely and when I took it down the road it was totally gutless. Would anyone be able to give me an idea where i f***d up? |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Wed Jun 22, 2016 4:07 am Post subject: Re: Gutless after rebuild |
Dual solex 34 pict 3's?
Double check your timing. Make sure at TDC you are firing #1. Rockers for number 3 should be open at TDC.
Should pull pretty hard with that combo. _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
TinCanFab Samba Member
Joined: April 04, 2006 Posts: 2743 Location: Waterford, California
Posted: Wed Jun 22, 2016 5:52 am Post subject: Re: Gutless after rebuild |
MURZI wrote: |
Should pull pretty hard with that combo. |
I had the same combo with ICT's, and it was very peppy. But it was as slow as a 36 horse until I reamed the main jets one size at a time, leaving everything else alone. Before, I couldn't do more than 40 going up any hill. After jetting, it screamed between 40-80 mph, couldn't be happier.
My first guess is carbs/ignition. My second guess is something else off with the combo, like huge deck height and low compression ratio. A big cam bleeds off a ton of cylinder pressure at lower RPM where the stock cam does the opposite. Without bumping the cr, it will be gutless _________________ Check out my truck brought back from the dead... http://www.thesamba.com/vw/forum/viewtopic.php?t=420762&highlight=sprayed+blood
They're never really ever finished 58 rag build...
http://www.thesamba.com/vw/forum/viewtopic.php?t=658092 |
mark tucker Samba Member
Posted: Wed Jun 22, 2016 3:07 pm Post subject: Re: Gutless after rebuild |
roachdub58 wrote: |
MURZI wrote: |
My first guess is carbs/ignition. My second guess is something else off with the combo, like huge deck height and low compression ratio. A big cam bleeds off a ton of cylinder pressure at lower RPM where the stock cam does the opposite. Without bumping the cr, it will be gutless |
x3. |
Brian_e Samba Member
Joined: July 28, 2009 Posts: 3291 Location: Rapid City, SD
Posted: Wed Jun 22, 2016 3:31 pm Post subject: Re: Gutless after rebuild |
Make sure you are getting 100% full throttle on both carbs. |
Flare Samba Member
Posted: Wed Jun 22, 2016 4:35 pm Post subject: Re: Gutless after rebuild |
Calculated compression ratio is 8:1 but haven't got a compression tester - may have to invest in one.
When i was trying to get it to run properly it was backfiring and just generally running like crap. The plugs are 180 around also. Could i have put the cam in incorrectly - I honestly only found out about the dots on the gears after re-assembly. Used feeler gauges before the engine was pulled apart against a lobe and lifter to get what im using.
Yes, it is a 34 pict 3! i had two laying about and a local guy had an empi manifold to suit for it. I coulnd't find too info much on this combo really.
jets installed:
Idle 55
Main 130 (have two 134 jets and a single 145 to play with)
Sprayed around the manifolds with ether and it dosen't seem to be sucking air. definatly getting full throttle.
The engine seems to rev but it dosen't pull. i was in 3rd gear pushing 50kph
Ill have to check the rockers when i get home from work. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Wed Jun 22, 2016 6:38 pm Post subject: Re: Gutless after rebuild |
Flare wrote: |
jets installed:
Idle 55
If cam timing is off, its never going to run...This is first thing I would verify....
Flare Samba Member
Posted: Wed Jun 22, 2016 8:24 pm Post subject: Re: Gutless after rebuild |
Thanks Dale, Starting to restore a little confidence. That's that image I went off to double check the cam when putting it in. If it was 180 wrong would it possibly fire but run badly? |
Danwvw Samba Member
Posted: Wed Jun 22, 2016 8:35 pm Post subject: Re: Gutless after rebuild |
I bet it's the Dual PICT 34's Probably set up way wrong. Best to just get some real carbs for it. That engine would roar dual IDF's or DRLA's _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Flare Samba Member
Posted: Wed Jun 22, 2016 8:40 pm Post subject: Re: Gutless after rebuild |
Defanatly planning on getting some decent carbs in it but the budget dosen't allow at the moment. May just have to bite the bullet and get some if i can't get this running reasonably |
Danwvw Samba Member
Posted: Wed Jun 22, 2016 8:48 pm Post subject: Re: Gutless after rebuild |
so just how bad does a 180 out cam run? mine runs just fine......how exzactly do you get cam 180 out? and what differance does it make ? none. it starten to sound and look like you need to find somebody local that can help you. we can give suggestions but if you do not under stand they do no good. is it running on all 4 cylinders? are the valves adjusted right? is the cam degreed right? off a tooth will still run in most instances.some even more.and depending on witch way it's off. fix it befor it kills it's self. |
modok Samba Member
Joined: October 30, 2009 Posts: 26787 Location: Colorado Springs
Posted: Wed Jun 22, 2016 10:57 pm Post subject: Re: Gutless after rebuild |
Flare wrote: |
j |
I'd like to see that! Take a picture
It probably isn't a good idea, especially with that cam, but that never stops anybody from trying, and occasionally succeeding. |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Posted: Thu Jun 23, 2016 1:43 am Post subject: Re: Gutless after rebuild |
I want to see too! I love dual stocker setups. I'd love to see which manifolds and linkage it's using. I've toyed with the idea for a while, and had dual 30PICT3s on a 40 horse a while back, that sucker was smooooooth....
I bet the 34PICTs have different flange numbers and are plumbed a bit differentlty internally, or need some jetting help. _________________ 73 super beetle thread http://www.thesamba.com/vw/forum/viewtopic.php?t=649622 Back on the Road!
Modify your Kadrons for SVDA http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
Cast iron VJU4BR8 SVDA reference thread- https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Need replacement filters for original Kadron aircleaners? WIX #42087 is a perfect fit, as is Napa Gold #2087!
Flare Samba Member
Posted: Thu Jun 23, 2016 4:32 am Post subject: Re: Gutless after rebuild |
Thanks a lot for everyone's comments. I spent some time this afternoon reaming the jets and am feeling the engine drastically change for the better. before the jet change it was running a lot rougher than what i actually thought. now it purs without missing.
Ill see if i can get some images for people interested. |
Posted: Thu Jun 23, 2016 8:35 am Post subject: Re: Gutless after rebuild |
bore the vents, bigger jets, bigger airs.....then on to some idf's |
Patrickvw Samba Member
Joined: June 20, 2011 Posts: 108 Location: British Columbia
Posted: Thu Jun 23, 2016 4:48 pm Post subject: Re: Gutless after rebuild |
What muffler system are you using |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4856 Location: sanger ca
Posted: Thu Jun 23, 2016 5:56 pm Post subject: Re: Gutless after rebuild |
Might want to get rid of this dizzy thing and start with a distributor, then figure out how to set timing, You can not br any where acurate with a "dizzy" _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Flare Samba Member
Posted: Tue Jun 28, 2016 8:13 pm Post subject: Re: Gutless after rebuild |
Using a GT style muffler
Haha - MCMScott - Timing makes me feel dizzy /s
Images for anyone interested in the dual carb setup - only took pics of one side. Ignore the messy engine bay and lack of tinware - that's getting worked on.
http://imgur.com/a/Ck2QS
Also to let everyone know after a weekend of tweaking the thing runs like a champ now! |
