58 Plastic Tub Samba Member
Joined: September 03, 2007 Posts: 418 Location: Nowhere, USA
Posted: Wed Jun 22, 2016 3:52 pm Post subject: Re: Best street head to hit the market in many years |
Excellent. Most excellent. _________________ Stan Galat
"Everybody is entitled to their own opinions, but not their own facts." |
modok Samba Member
Joined: October 30, 2009 Posts: 26781 Location: Colorado Springs
Posted: Wed Jun 22, 2016 4:43 pm Post subject: Re: Best street head to hit the market in many years |
jason wrote: |
I don't know much about heads but what makes these any better than the Tims heads roughly the same price? |
Both the Tims heads and the Panchito were PORTED 043 mexico castings. For a long time, this was the best foundation to use for a small-mid cc engine, but they are NLA.
Tims is using china 043 copies, and CB has managed to get Autolinea to make a 043 like head with design improvements.
I'm not going to say anything BAD about the chinese heads until I see it happen, and besides core shift problems that did sometimes happen, and being thinner, they seem OK. Will they turn to mush or end up full of cracks in the long run we don't know.
Based on what LITTLE I do know about castings, the EMPI heads being "easy to weld", maybe good but it raises a flag right away for me. Aluminum alloy for high temp generally has added copper or nickel, and these make it HARD to weld. so, if it's easy to weld.....did they use the right alloy???
AUTOLINEA has been making aircooled heads for 15+ years, and the castings themselves do hold up very well......generally better than German.
So which would foundation would you rather use? |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4341 Location: Los Angeles, CA 90016
MConstable Samba Member
Joined: May 04, 2004 Posts: 1822 Location: Saint Charles IL
Posted: Wed Jun 22, 2016 6:29 pm Post subject: Re: Best street head to hit the market in many years |
Ok...would these heads be suited for a 2110, mild build with 1 1/2" exhaust in a Thing?
Or are they for more rpm, cc's? |
303epps Samba Member
Joined: May 16, 2010 Posts: 51 Location: British Columbia, Canada
Posted: Wed Jun 22, 2016 6:38 pm Post subject: Re: Best street head to hit the market in many years |
Arrrg, my stage 1s just arrived. |
rugblaster Samba Member
Joined: March 31, 2016 Posts: 1170 Location: San Angelo, Texas
Posted: Wed Jun 22, 2016 7:09 pm Post subject: Re: Best street head to hit the market in many years |
Pat D wrote: |
rugblaster wrote: |
What does "Panchito" mean?........the only reason I'm asking is we have a Mexican food restaurant here called "Panchitos."
I want some tacos now.....thanks a lot. |
That's a really good question. In Spanish, it means "Tuff Guy" The original CNC ported Panchito was based on the Mexican 043 casting. The owner of CB, Rick Tomlinson at the time found a stray cat and called him Panchito. The name fit the head since the casting came from Mexico so it was decided to call the head Los Panchito or "little Tuff Guy" |
When I was in junior high and high school, I learned all the Mexican curse words. That word is close to "panocho" which means your"balls" or "nuts" LOL
Your heads are a good value. Back in 1980 or so, I paid $1200 for some big valve, welded heads that probably didn't flow as much as your pendajos. They are like Vortec small block heads that will out flow any camel hump or 2.02 head ever made......out of the box. _________________ '69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
'09 MB E350 '18 MB E400, '65 Plymouth Valiant convertible and a '19 Ford F250 King Ranch (nicer, but dirty, farm truck)
VWoA factory trained line tech 75 till 90 or so
ASE Master Certification
VWoA Assoc. of Quality Technicians inductee (One of 25 in the five state southwest region)
La Confrerie des Chevaliers du Tastevin (San Angelo Chapter)
TCU ......GO FROGS!!!!!! |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
ALB Samba Member
Joined: August 05, 2008 Posts: 3483 Location: beautiful suburban Wet Coast of Canada
Posted: Thu Jun 23, 2016 6:07 am Post subject: Re: Best street head to hit the market in many years |
Well done, Pat (and CB). Nice to see enough confidence in the hobby/industry that products like this are still being developed. _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4856 Location: sanger ca
Posted: Thu Jun 23, 2016 7:40 am Post subject: Re: Best street head to hit the market in many years |
I installed this engine in a 59 Binz, also built the trans for it. With the gearing that some consider tall, this thing drove as nice as any modern car but pulled like a train. Cruising at 75-80 mph you could not get it to overheat, this was also using just the stock doghouse cooler. _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
sled Samba Member
Posted: Thu Jun 23, 2016 7:46 am Post subject: Re: Best street head to hit the market in many years |
since we are talking a specific engine..
were the heads on that engine worked AT ALL? or were the ports as cast and the valves still 40 x 35.5
if these heads were completely 'stock' I see no reason why 42x37.5 would be necessary for practically any street engine. 188 hp out of 40x35.5 without revving it to pluto is more than enough _________________ drive your split. |
Pat D Samba Member
Posted: Thu Jun 23, 2016 7:54 am Post subject: Re: Best street head to hit the market in many years |
sled wrote: |
if these heads were completely 'stock' I see no reason why 42x37.5 would be necessary for practically any street engine. 188 hp out of 40x35.5 without revving it to pluto is more than enough |
The engine that you ask about had prototype Panchitos that were as cast. The only thing done to them was a larger CNC chamber to help lower the compression. _________________ Pat, Im too fast slow me downs! |
Pat D Samba Member
Posted: Thu Jun 23, 2016 8:00 am Post subject: Re: Best street head to hit the market in many years |
Lingwendil wrote: |
No answer on if they include or work with the tin?
Yes they will work _________________ Pat, Im too fast slow me downs! |
GTV Samba Member
Posted: Thu Jun 23, 2016 9:24 am Post subject: Re: Best street head to hit the market in many years |
Are matching manifolds available or in the works? _________________ EMPI Power Rules! |
Pat D Samba Member
Posted: Thu Jun 23, 2016 9:27 am Post subject: Re: Best street head to hit the market in many years |
GTV wrote: |
Are matching manifolds available or in the works? |
Yes, we are very close on having our offset type-1 manifold finished with the panchito port. _________________ Pat, Im too fast slow me downs! |
yamaducci Samba Member
Joined: March 30, 2010 Posts: 2335 Location: Mount Airy, Maryland
Posted: Thu Jun 23, 2016 9:54 am Post subject: Re: Best street head to hit the market in many years |
Pat D wrote: |
GTV wrote: |
Yes, we are very close on having our offset type-1 manifold finished with the panchito port. |
Adding Sleeved manifold studs for port alignment and matching gaskets would be great. Pat just think about how many hours you wont have to do manual port work! Between the As-cast and the CNC everyone gets power without the pain.
Great job! _________________ -John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
3rd Brake Light Safety Stars- I still have a couple with blue light left. Email me if interested. |
ratsnotmice Samba Member
Joined: September 09, 2014 Posts: 64 Location: Mena, AR
Posted: Thu Jun 23, 2016 10:29 am Post subject: Re: Best street head to hit the market in many years |
[email protected] wrote: |
vwinnovator wrote: |
modok wrote: |
Whaaat??
Look at the pictures, it has "panchito 044" cast where the part number usually is |
That's worth an extra $20 in itself!!!
Man, these are really gonna cut into roy's market... |
Actually, knowing how much money, time, effort and testing goes into producing a new cylinder head; I am pretty happy to hear about this. Why? Because if anyone is going to go through that much trouble, the VW aftermarket has to be going very strong. We spent our money to develop our castings almost 20 years ago. Things are more expensive now.
I have 26-30 years until I can retire so I am happy that other companies are spending money on future products. |
That is absolutely the best response, Roy. Good for you! |
pupjoint Samba Member
Posted: Thu Jun 23, 2016 5:56 pm Post subject: Re: Best street head to hit the market in many years |
great stuff from CB. good to see more new parts for our old engines.
having said that i just got my Tims Stage 2 or else i would have given these a try. |
saw2 Samba Member
Joined: November 06, 2008 Posts: 321 Location: nw Oregon
Posted: Thu Jun 23, 2016 7:33 pm Post subject: Re: Best street head to hit the market in many years |
Just got a email from CB. Free shipping on any Panchito 044 head this Fri, Sat and Sun. Great time to buy. |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Thu Jun 23, 2016 10:34 pm Post subject: Re: Best street head to hit the market in many years |
pupjoint wrote: |
Pup I'll buy a set of Panchitos , drop ship to you and trade you for your stage 2s...
Jon _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
vwinnovator Samba Member
Joined: July 11, 2005 Posts: 1555 Location: Still doing it in the back of your VW
Posted: Fri Jun 24, 2016 7:38 am Post subject: Re: Best street head to hit the market in many years |
jfats808 wrote: |
pupjoint wrote: |
Jon |
I'll trade you my Jon Karcy heads or my pauter "B" heads (by mary) for them (stage 2's) |
