Accelerator Cable
Titans12
Titans12 is offline
PostPosted: Tue Jun 21, 2016 2:16 pm    Post subject: Accelerator Cable Reply with quote
my Accelerator Cable on my 60' ghia broke and its only 95". All I can find is 104" any help?
60ragtop
Bonneville Belt Bitch
60ragtop is offline
PostPosted: Tue Jun 21, 2016 2:44 pm    Post subject: Re: Accelerator Cable Reply with quote
do you have the stock set up? because that is the one it calls for
58-66 use #111 721 555 C solid wire cable
Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote:
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote:
maybe he just snapped cause his car sucked Wink
Titans12
Titans12 is offline
PostPosted: Wed Jun 22, 2016 3:30 am    Post subject: Re: Accelerator Cable Reply with quote
no, dual carbs and linkage is in front of fan shroud
60ragtop
60ragtop is offline
PostPosted: Wed Jun 22, 2016 5:21 am    Post subject: Re: Accelerator Cable Reply with quote
is it a solid wire or braided cable ?
Rick
Titans12
Titans12 is offline
PostPosted: Wed Jun 22, 2016 5:28 am    Post subject: Re: Accelerator Cable Reply with quote
solid
60ragtop
60ragtop is offline
PostPosted: Wed Jun 22, 2016 5:30 am    Post subject: Re: Accelerator Cable Reply with quote
Does it have something like this on it ?
(crappy pic borrowed from the gallery)
Rick
Titans12
Titans12 is offline
PostPosted: Wed Jun 22, 2016 5:34 am    Post subject: Re: Accelerator Cable Reply with quote
No, it actually had a short cable with hoop and and thick end. I've googled trying to find a shorter cable, but no luck
60ragtop
60ragtop is offline
PostPosted: Wed Jun 22, 2016 5:40 am    Post subject: Re: Accelerator Cable Reply with quote
I don't know of anyone who sells a shorter cable as it isn't stock. Most cut the cable and use a cable extender like pictured.
Good luck
Rick
rbsurfguy
Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
rbsurfguy is offline
PostPosted: Wed Oct 05, 2022 6:29 am    Post subject: Re: Accelerator Cable Reply with quote
As you can see in the pic below, my accelerator cable is quite long. Crosslink bar sits behind the shroud in my set up. Is there a shorter cable I can try, or should I just clip it and throw on one of those cable extender ends? I see that as another point of failure, but may have to go that route anyway.
Anyone with experience with the cable extender ends, problems, no problems, things to look out for? Thanks,
Jeff
1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
74 Thing
74 Thing is offline
PostPosted: Wed Oct 05, 2022 8:58 am    Post subject: Re: Accelerator Cable Reply with quote
I use the cable extender that is photographed above. It just uses an allen head set screw. Make sure it does not hit your front tin when the throttle is fully open.
Not sure what length cable you are using now, but jbugs has a list of lengths so you can try to use a shorter one, but you may need to use the extender to make it perfect. I did.
https://www.jbugs.com/search.html?q=accelerator+cable
rbsurfguy
PostPosted: Wed Oct 05, 2022 10:09 am    Post subject: Re: Accelerator Cable Reply with quote
Thank you Sir, will look into the extender and try that route!
Jeff
2012 Passat-Sold
jeffrey8164 Premium Member
jeffrey8164 is offline
PostPosted: Wed Oct 05, 2022 12:00 pm    Post subject: Re: Accelerator Cable Reply with quote
I’ve always used a heavy duty braided cable like this.
https://www.chirco.com/dune-buggy-and-baja-bug-vw-...le-cables/
Easy to install. Even on the side of the road.
Volkswagen!
(Compression 8.7:1)
rbsurfguy
PostPosted: Wed Oct 05, 2022 12:05 pm    Post subject: Re: Accelerator Cable Reply with quote
Thanks Jeffrey, always good to have a back up for just those occasions, clutch cable, rotor, points, if stock set up, and a hundred other little pieces!! You really get to know how to fix almost anything on these cars after a while!
Jeff
2012 Passat-Sold
