wcfvw69 Samba Purist
Posted: Thu Jun 23, 2016 3:06 pm Post subject: Re: The secret build of my wifes first car. 1971 Super Beetle |
Robert Haas wrote: |
TheViking wrote: |
congrats! Really beautifull car!
One question? How is the exhaust system working for you? I cant seem to get mine to stop leaking... |
yep, same here. We are probably going to have to cut it up and re-weld it. Luckily I am a very good welder and own a very nice TIG |
Just be aware the muffler you have there doesn't provide hardly ANY hot exhaust gas flow through the carb pre-heat manifold. It can be troublesome in the summer but even more so in the winter. A stock VW muffler is designed to flow a lot of hot exhaust gas through that manifold to keep the carb from icing up. It also helps the engine's driveability when it's cold.
Just an FYI _________________ Contact me at [email protected]
The Samba member since 2004.
Robert Haas Samba Member
Joined: March 11, 2016 Posts: 31 Location: Salinas California
Posted: Thu Jun 23, 2016 4:43 pm Post subject: Re: The secret build of my wifes first car. 1971 Super Beetle |
wcfvw69 wrote: |
TheViking wrote: |
Just an FYI |
The heat risers appear to have the same diam. as the originals, What am I missing? |
Posted: Thu Jun 23, 2016 7:16 pm Post subject: Re: The secret build of my wifes first car. 1971 Super Beetle |
The stock VW muffler was designed in such a way as to produce a vacuum or low pressure area that pulled the hot exhaust thru the heat risers. This picture of a stock muffler cut away shows this. Headers or mufflers like yours don't have that vacuum or low pressure to pull large volumes of hot exhaust gas through the carb manifold heat risers. As such, they don't get anywhere near hot enough to do what they are suppose to do, keep the carb from icing and helping the fuel stay atomized down those long intake runners.
If you have a laser temperature gun, point it at your heat risers with that current exhaust on it and see what temp it shows. You also need to insure the heat risers are clear and not clogged up with carbon.
This picture from Robbie shows how hot it's suppose to get.
http://www.thesamba.com/vw/forum/viewtopic.php?t=642924&highlight=heat+risers
http://www.thesamba.com/vw/forum/viewtopic.php?t=627243&highlight=heat+risers
Here's a couple of old threads that talks about it.
When I bought my 70 bus, it had a header on it. It was a cold engine pig. It would fall all over itself when first started and take 5 minutes for the driveability to improve. After I pitched the POS header in the garbage, I installed a stock muffler and made sure the heat riser tubes were clear. Night and day difference in cold engine driveability. It improved to perfect when I reinstalled the flaps and thermostat. Now, I can start the dead cold engine and drive right off and it runs perfect. _________________ Contact me at [email protected]
Goldbug3318 Samba Member
Joined: September 06, 2014 Posts: 210 Location: Jacksonville, FL
Posted: Fri Jun 24, 2016 3:26 pm Post subject: Re: The secret build of my wifes first car. 1971 Super Beetle |
GREAT story.....& fabulous car!!!!
Mike _________________ 1971 Super Beetle 1302S
1641 DP, lowered, 914's, etc...
1990 Ford Mustang Coupe
2008 Ford Mustang Coupe
2003 Chevy Corvette |
coxbzh Samba Member
Joined: March 01, 2016 Posts: 22 Location: Brest meme
Posted: Wed Jun 29, 2016 5:20 am Post subject: Re: The secret build of my wifes first car. 1971 Super Beetle |
that's a beautiful story
my favorite color, congratulations |
