Used auto linea case
Vw1600dellortoGR
Vw1600dellortoGR is offline
PostPosted: Sun Jun 19, 2016 10:49 am    Post subject: Used auto linea case Reply with quote
Hello everybody, i spotted this case and i would like your opinion about its condition machining judging from how it looks and wear, can it be used for a 1914 engine build even though it was clearanced for a stroker?
the2ndcashboy
the2ndcashboy is offline
PostPosted: Sun Jun 19, 2016 11:09 am    Post subject: Re: Used auto linea case Reply with quote
No problem using a clearanced case for a stock stroke crank. Assuming it's clearanced properly, it should add a little to the value. It looks decent, assuming there isn't something ugly under the blob of epoxy in that first picture....
If you get it, don't just assume everything is ok since it was used previously. I'd still check for oil gallery alignment (those haven't been touched, and they're usually off) and the other usual AutoLinea case issues.
SRP1 wrote:
You see....... He talks in code and translation requires a priest, geologist, astronomer, biophysicist, and Indiana Jones.
modok wrote:
If anything comes out perfect it just means your measuring tools are substandard.
FeelthySanchez
Location: Now is that a real poncho, or a Sears poncho?
FeelthySanchez is offline
PostPosted: Sun Jun 19, 2016 11:14 am    Post subject: Re: Used auto linea case Reply with quote
Re cond: spotted crack on a #1 stud hole, so needs weld-up & re-tap.
Re 1914: of course it could build this - the 69mm crank doesn't know or care if it's case has had any clearancing done.
Vw1600dellortoGR wrote:
....... i would like your opinion about its condition machining judging from how it looks and wear, can it be used for a 1914 engine build even though it was clearanced for a stroker?
modok wrote:
I would like if you had enough clue to communicate what you are doing.
Ryan Tucker wrote:
Enough clue..Whats that mean?
OldIronSpine wrote:
I'm not sure how compression works.
Turbos don't produce torque, they produce HP. Instead of torque.
The real problem with NA engines is you don't hear the nice whine of the turbo as it spools up.
Before I commit, I'm going to do more research because I don't really know what piston rings are.
Vw1600dellortoGR
PostPosted: Sun Jun 19, 2016 11:15 am    Post subject: Re: Used auto linea case Reply with quote
How do the main bearings get aligned to they oil galleys ?
Vw1600dellortoGR
PostPosted: Sun Jun 19, 2016 11:22 am    Post subject: Re: Used auto linea case Reply with quote
You mean the crack on the bottom left stud? or the one that might be hidden under the epoxy? is this caused by the 94mm cylinders leaving to little material or is the case bad quality? I thought that perhaps it had raised decks to compensate for the larger stroke, which would have to be skimmed .
Vw1600dellortoGR
PostPosted: Sun Jun 19, 2016 11:30 am    Post subject: Re: Used auto linea case Reply with quote
Does this look like a crack on the left of #1 or a mark from clearancing?
FeelthySanchez
PostPosted: Sun Jun 19, 2016 11:31 am    Post subject: Re: Used auto linea case Reply with quote
Re: You mean the crack on the bottom left stud?
Yep. The cracked saver'd/10mm stud hole that is directly below epoxy "repair".
Be advised there may be others as well ........
FeelthySanchez
PostPosted: Sun Jun 19, 2016 11:33 am    Post subject: Re: Used auto linea case Reply with quote
I'd flag this as a likely crack - the pic is pretty good.
Have any dye penetrant?
the2ndcashboy
PostPosted: Sun Jun 19, 2016 11:34 am    Post subject: Re: Used auto linea case Reply with quote
Yeah, that looks like a crack too. I think I'd pass on that case. Something evil happened in that area to crack the webbing like that.
FeelthySanchez
PostPosted: Sun Jun 19, 2016 11:37 am    Post subject: Re: Used auto linea case Reply with quote
Unless you're handy w/ a heliarc, I gotta agree here: 3 def cracks + 1 epoxy "repair" = FLUNK, or else MUCHOS $$
Vw1600dellortoGR
PostPosted: Sun Jun 19, 2016 2:13 pm    Post subject: Re: Used auto linea case Reply with quote
Is it repairable or will the cracks reform even if welded?
FeelthySanchez
PostPosted: Sun Jun 19, 2016 2:57 pm    Post subject: Re: Used auto linea case Reply with quote
Adding some clean-up machining costs, & given a good welder/machinist: these 3 crack MAY repair just fine.
Whether they "reform" or not after assy is a good one (roll the dice) Wink
Bottom line: this case is already stroker-clearanced & thus way overkill for a 1914, plus it needs much remedial work.
The right gent w/ welding & machining skills could possibly clean-up here, but for the average guy it's very likely a cash pit.
Vw1600dellortoGR
PostPosted: Sun Jun 19, 2016 3:08 pm    Post subject: Re: Used auto linea case Reply with quote
Ι am thinking about it because it is about half a price of a new one.
Boolean
Boolean is offline
PostPosted: Sun Jun 19, 2016 3:16 pm    Post subject: Re: Used auto linea case Reply with quote
In that shape, it's worth a quarter of the price of a new one.
I strive for perfection. Excellence will not be tolerated!
Build thread here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=529379
Vw1600dellortoGR
PostPosted: Sun Jun 19, 2016 3:20 pm    Post subject: Re: Used auto linea case Reply with quote
So you think it is not worth trying to repair?
the2ndcashboy
PostPosted: Sun Jun 19, 2016 3:21 pm    Post subject: Re: Used auto linea case Reply with quote
A new AL case like that is ~900$ http://vwparts.aircooled.net/Aluminum-Super-Case-85-5-94mm-Bore-Stroke-Relief-p/alsupercase.htm. If that one is 4-500$, then it's not a good deal. It's not going to save you much money total (unless you can weld aluminum). And in the end you'll never really trust the case. With cracking spread out over that large of an area, there's a pretty good chance there is more damage you can't see that's waiting to rear its ugly head.
esde
esde is offline
PostPosted: Sun Jun 19, 2016 5:16 pm    Post subject: Re: Used auto linea case Reply with quote
While that case may be repairable, it may not be also. Anyone who has welded cast will tell you that sometimes you just can't get it right. It could be a shitty casting to begin with, which might explain the numerous cracks there. If thats the case, a good welder could chase his tail for hours trying to get the porous s casting clean enough to take a good weld. It might be easy, or impossible.
That's the kind of case someone with an AC tig and a mill throws in the corner, for a rainy day when they feel like a challenge. Or they're scrounging for parts for a buddies project. Not the case you buy to save money, unless you're the gambling type..
modok wrote:
raul arrese
raul arrese is offline
PostPosted: Sun Jun 19, 2016 6:23 pm    Post subject: Re: Used auto linea case Reply with quote
I have welded on the autolinea cases , they weld pretty good..
" Hot vw feature , may 2014 issue "
" 2013 Bug Jam class winner "
" Bug Jam best motor and best paint "
" 2013 Lakeland Classic Best of Show "
" 2014 Show and Shine , First in class "
Like my facebook https://www.facebook.com/pages/Raul-Arrese-custom-fabrication-and-performance/1832968110262608
nsracing
nsracing is offline
PostPosted: Sun Jun 19, 2016 6:42 pm    Post subject: Re: Used auto linea case Reply with quote
Unless this case is free, and you have a TIG welder is worth repairing if you can handle all the work.
But if you have to spend any dime on it, which I think will be a bunch, just take a pass.
Save your money for something more viable.
Busstom
Busstom is offline
PostPosted: Sun Jun 19, 2016 10:13 pm    Post subject: Re: Used auto linea case Reply with quote
You should be thinking about it if it's FREE, not half price. That would be a foolish waste of money, don't be that "sucker born every minute" that the seller is praying you are.
Now since you've got half the money, save up the rest and do it right.
