NewTechnicIan Samba Member
Joined: May 28, 2013 Posts: 367 Location: Burlington, VT
Posted: Thu Jun 23, 2016 4:50 pm Post subject: Re: Sanded Through Clear Coat And Other Issues |
Hey all, so I'm still hitting some issues with a couple other spots getting close or burning through on the body. Could also be some issues with my bodywork below it
So I'm betting it'll be best to respray the body at least. I want to smooth down the clear so I'm ready to spray it nicely, what grit should I use? Like 600 now or stay at 1000? I want to make sure it's not so fine that the base doesn't stick anymore.
And, guilty admission, it's taking forever to sand at 1000 So if I'm gonna spray it all again I might as well go quicker than slower.
Anyway, all help appreciated, thanks! _________________ My 73 Standard build - It's painted! It drives under its own power! Time to get it wired and upholstered!
My 1679 Engine build. |
Julio_Arcos123 Samba Member
Joined: August 28, 2011 Posts: 52 Location: Los Angeles, California
Posted: Thu Jun 23, 2016 5:03 pm Post subject: Re: Sanded Through Clear Coat And Other Issues |
Yeah people do that in the last coat of clear but these cars are different creatures. Slower reducer lets it staybwet longer so it flows out more but with all these curves the clear wants to sag and run. I wouldnt recommend it on this car.
Paint womt have a problem sticking to 1000 or even 1500. But since its a solid color with the metallic or pearl you could do it 600 or 800.
If youre going to respray the body with basecoat and clear coat do it with 600 if youd like the speed. Youll burn through on some spots but if your going to do the basecoat again it wont matter much since youll add more color on top anyways. _________________ 64 bug (o\ ! /o) |
jspbtown Samba Member
Posted: Thu Jun 23, 2016 6:47 pm Post subject: Re: Sanded Through Clear Coat And Other Issues |
Be sure to use a backing to your paper and not just your hand.
Criss crossing on larger panels is good as well. Everything should look nice and flat (dull) |
