sperlingerrit Samba Member
Joined: July 22, 2015 Posts: 35 Location: Shell Beach, CA
Posted: Fri Jun 17, 2016 9:04 pm Post subject: Retrofitting Factory Cruise Control |
Hello all,
Im working on retrofitting the factory cruise control into my van and im having trouble with the wiring. I was wondering a few things. After looking in the bentley im still having trouble seeing where a few of the wires should go. Is there a relay for the cruise system? Does anyone know what the specific functions of each of the 8 pins on the brain are? Has anyone ever done this on an early pre-86 van? I have an 84 passanger van. I know all about the vss and vacuum lines and how the system is supposed to work but the wiring up front is just giving me trouble. Please help!
Thanks
Gerrit |
16CVs Samba Member
Joined: February 22, 2004 Posts: 4026 Location: Redwood City, California
Posted: Sat Jun 18, 2016 1:15 am Post subject: Re: Retrofitting Factory Cruise Control |
Are you fabricating your own harness, or installing a factory harness. There is no relay just an ECM. All the wires are plug and play. You should have the 8 pin plug which goes to the ECM, a plug for the VSS , a plug which interrupts the brake switch , a set of wires that go to the pedals a flat 4 prong which goes to the control switch as well as +\ - . There is an extra plug from the harness that does not plug into anything, lastly there are 3 wires which go the back and hook up to the bi pressure pump in the engine compartment.
That's all from memory, make sure that your ECM has a 251 number on it as a secondary number as it is only for a Vanagon 2WD which gets its signal from the wheel, my first retrofit I had to make my own harness, but I had all the plug ends as my buddy who pulled it didn't realize it is just a sub harness.
Good luck, they are frustrating to get to work properly.
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
tschroeder0 Samba Member
Joined: April 14, 2008 Posts: 2096 Location: Boulder CO
Posted: Sat Jun 18, 2016 8:34 am Post subject: Re: Retrofitting Factory Cruise Control |
if you search cruise control troubleshooting you will find all you need, I think. |
Howesight Samba Member
Joined: July 02, 2008 Posts: 3274 Location: Vancouver, B.C.
Posted: Sun Jun 19, 2016 12:24 pm Post subject: Re: Retrofitting Factory Cruise Control |
I built mine from scratch. The 1986 and later Syncro vans, even the ones like mine with no factory cruise control, all came pre-wired with the three-wire cable from the area just behind the instrument panel, which goes all the way to the black junction box on the left side of the 1986 and later engine firewall. I think that you will have to make and install your own cable for that.
Here's a link to my install:
http://www.thesamba.com/vw/forum/viewtopic.php?t=655366
As for wiring, look at the cruise control wiring diagram at page 97.175 of the Bentley manual. You need to provide 12V "key switched on" positive power to "G2" on the Bentley diagram. On your 1984 Vanagon, the location on the fuse panel for "key switched on" positive power will be different. You need to connect the control unit terminal 3 to the brake light switch circuit. _________________ '86 Syncro Westy SVX |
Posted: Mon Jun 20, 2016 8:30 am Post subject: Re: Retrofitting Factory Cruise Control |
So the main reason i was getting so confused by the wiring diagrams etc. is that i think the person I bought the system from gave me the wiring harness out of a different vw not a vanagon. |
16CVs Samba Member
Posted: Mon Jun 20, 2016 11:07 am Post subject: Re: Retrofitting Factory Cruise Control |
What is different about it? I would imagine any Mid 80's VW would have the same connections.
Did you read through my list of things in the harness? The easiest part of my Retrofit was installing the harness.
Throw some pictures up and I'll compare it to a harness I have for sale. Which I personally removed from a Vanagon.
Posted: Tue Jun 21, 2016 12:12 am Post subject: Re: Retrofitting Factory Cruise Control |
These are all the pictures i currently have of my harness:
Posted: Tue Jun 21, 2016 3:43 pm Post subject: Re: Retrofitting Factory Cruise Control |
So does it look different? |
Posted: Fri Jun 24, 2016 12:53 pm Post subject: Re: Retrofitting Factory Cruise Control |
Is anyone able to see and possibly point out any differences? |
ajdenette Samba Member
Joined: February 15, 2009 Posts: 768 Location: Hope Valley RI
Posted: Sat Jun 25, 2016 11:59 am Post subject: Re: Retrofitting Factory Cruise Control |
sperlingerrit wrote: |
The wire lengths will have to be changed by cutting and splicing. All the wires and terminals are there in your picture. Use the Bentley wiring diagram to understand which wire does what.
Here's the wiring diagram for the harness you have. You need to lengthen and shorten the wire runs to suit your Vanagon.
Which Vehicle Speed Sensor (VSS) do you have? The 3-wire one?:
Or do you have the Vanagon 2-wire VSS:
Here's a pic of the wiring pigtail for the factory Vanagon cruise stalk:
Posted: Sat Jun 25, 2016 7:57 pm Post subject: Re: Retrofitting Factory Cruise Control |
I have the two wire VSS. Thanks for the responses. I has been a little tricky trying to identify which wires do what from the bentley cause im not sure which position on the eight pin connector each wire comes from. Is it really just simple and im overlooking it? |
Posted: Sun Jun 26, 2016 8:52 am Post subject: Re: Retrofitting Factory Cruise Control |
Have you looked at the wiring diagram in your Vanagon Bentley manual at page 97.175?
If not, you will never solve your dilemma. It is really simple, but you need to look at the Vanagon wiring diagram. Both the Jetta diagram I posted above and the Vanagon diagram show the pin numbers on the CC control unit. The control unit itself has a diagram painted on it that shows you which pins correspond with which numbers.
The only interface to your vehicle is to find a 12V power source that is only powered when the ignition switch is on, a ground, and the connection to the brake light switches. Everything else is just the CC system itself, which you can wire up in exactly the way that the Bentley manual shows at page 97.175. _________________ '86 Syncro Westy SVX |
Posted: Sun Jun 26, 2016 5:53 pm Post subject: Re: Retrofitting Factory Cruise Control |
I feel really dumb i mever noticed those little numbers! One thing i was looking at in that page of the bentley though is there is an inductive sender in the diagram that i dont have. Is it necessary? Its connections on the diagram dont seem to go anywhere. Just wondering.
Thanks! |
Posted: Sun Jun 26, 2016 6:02 pm Post subject: Re: Retrofitting Factory Cruise Control |
Nevermind i see now its the VSS! |
Posted: Sun Jun 26, 2016 7:01 pm Post subject: Re: Retrofitting Factory Cruise Control |
I just need help with one more thing I promise! Its just not entirely clear to me which pin on the CC Main control is the one that needs swutched on power! Is it the second one? Please help! Thank you guys so much for everything! |
Posted: Mon Jun 27, 2016 8:28 am Post subject: Re: Retrofitting Factory Cruise Control |
This one last piece of info would help me greatly! Anyone?
Thanks
Gerrit |
FrankenSubySyncro Samba Member
Joined: May 03, 2007 Posts: 638 Location: Vancouver, WA.
Posted: Mon Jun 27, 2016 10:14 am Post subject: Re: Retrofitting Factory Cruise Control |
The ECM gets its power from the switch. The red wire from the switch is what you connect to key on power. _________________ Syncronize it!
1987 Franken Syncro (converted 2WD auto)
2004 2.5 SOHC Subaru
F & R lockers, decoupler, SS, 6.17 R&P
Trans Cooler
EMPI race prepped 930 CVs and axles
Bilstein coilover front, rear ProComp MX-6066R shocks, 14" hypercoil springs
30x9.5 15" BFG Muds
Custom skid plates
Nose job (custom front bumper) http://www.flickr.com/photos/subyvanagon/sets/72157624970330925/ |
davideric9 Samba Member
Joined: January 21, 2009 Posts: 1002 Location: Oakland CA
Posted: Mon Aug 15, 2016 5:45 am Post subject: Re: Retrofitting Factory Cruise Control |
Quote: |
There is no relay just an ECM. All the wires are plug and play. |
To clarify, there is a relay in the cruise control system, its only on the automatic transmission, not on the manual trans. Its not quite plug and play because its wires are often cut from behind the fuse panel, no connectors for two of the four relay wires. Bentley shows these wires going to C18 and G3.
ALSO for you all you trusting owners, NOT all the post 86 vans came prewired with CC in engine compartment. My 87 syncro has the connector and my 88 wolfsburg does not. _________________ 1987 Syncro Westfalia, stock (bought 1994)
1986 Syncro Westfalia SVX, 3 knob (bought 2008)
1987 Westfalia (bought 2010)
1988 Wolfsburg GL (bought 2012) |
Åsmund T3 Samba Member
Posted: Wed Jul 08, 2020 9:43 am Post subject: Re: Retrofitting Factory Cruise Control |
Hi guys
I'm retrofitting the factory cruise as we speak.
But I have a question
#1 do someone have a picture of the criuse control wire diagram on a vanagon with automatic transmission?
The guy that pulled out the cruise that I'm retrofitting did a beautiful job, no wires are cut and all the connectors are on. But I'm struggling to figure out where a Black single cable from the ECM unit goes,
The "kit" also included a fuce holder with one grey and white stripet wire. Not sure of that has anything to do with the cruise control/ECM unit.
