Danwvw Samba Member
Posted: Sat Jun 18, 2016 9:42 pm Post subject: Re: Engine diagnostics request |
Ok so what is happening with your engine is it's too hot in your engine compartment for that fuel pump and those fuel lines running everywhere like that. Carb Technology and fuel systems had to change in order to tolerate todays gasoline with it's lower boiling point. Fuel systems now are pressurized and recirculate some gas back to the tank so there is always a little fuel flow to keep the lines cool so cars don't vapor lock on ethanol gas.
An electric fuel pump is a step in the right direction and I think if you go in and replace leaking fuel lines with good quality fuel line and mount that fuel pump or better yet a new fuel pump mounted on the under side of the bus through the floor there under the back seat where it's sloped. It would be mounted only be about 1 foot forward from where it is now. The vapor locking will clear up.
CB-Performance has good quality fuel line and fuel pumps. Use hose clamps on the fuel line if you go with the SAE 1/4" id fuel line. 5mm fuel line for stock solex carbs Not sure what you need.
If you have not sealed around the engine good to keep heat from below from entering the engine compartment that will help as well. I am not sure but there may be a kit for fitting your Type 4 1700cc engine into your early bay.
_________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Rubber Duck Samba Member
Joined: January 18, 2006 Posts: 806 Location: Pitt Meadows BC
Posted: Mon Jun 20, 2016 1:31 pm Post subject: Re: Engine diagnostics request |
I have virtually the same setup as yours (look up threads I started, not many hehe) and the pump going louder softer sounds a lot like fuel not getting to it. That said, my pump was just a loud thing, so I changed it.
I've heard that some pumps "push" better than "pull" as well. Perhaps yours pushes better? Maybe try relocating it under the bus (I have a thread on that too) and wire up a relay or two to control how things work.
As for minor leaks, well, any leak should be fixed and since you're doing that, pay close attention to how fuel lines could be routed to avoid the whole gravity feed thing...ie, keep your lines high up the engine compartment.
Good luck! _________________ ---------
Rubber Duck
1974 Westfalia |
jpaull Samba Member
Joined: February 22, 2005 Posts: 3461 Location: Paradise, Ca
Posted: Mon Jun 20, 2016 2:26 pm Post subject: Re: Engine diagnostics request |
Ok, the electric fuel pump simply getting louder and softer is totally normal. When the carb float opens, the pump gets louder, then the float closes, and the pump gets quieter.
If you said, "hey guys, I realize my pump gets louder and quieter, but now its twice as bad as before" then I would say maybe something to it.
It sounds more to me that once you had a problem, you started looking for signs of "things" happening, and notice the fuel pump getting louder and quieter and thought this was a issue.
if you want to stop guessing, drive it till issue happens, pull over, leave [b]ignition OFF, pull air filter and pump carb and see gas comes out. if gas comes out, then its your coil like I said before in previous post. if gas does NOT come out of accelerator pump jet, then yes you got a fuel issue. Your filter is plugging up or replace your pump.[/b] _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth. |
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Tue Jun 21, 2016 12:58 pm Post subject: Re: Engine diagnostics request |
Alright, the new information, I relocated my fuel pump to under the bus virtually right below where it come out of the tank. It pumps great! It would fill a coke can in 15-20 seconds. I bought a cheapo ignition coil, and put it on, didn't change a thing. So that leaves the carbs. I'm going to pull them off and clean em up and put them back on. They did sit for a year almost so they could have clogged. I'll report back when I'm done with that.
Does anyone have other thoughts than that? Also, my mechanic friend who drove the bus thinks that it is essentially flooding its self, so I'll be paying close attention to the float. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
richierich Samba Member
Posted: Tue Jun 21, 2016 1:04 pm Post subject: Re: Engine diagnostics request |
I have my electric pump mounted right under the tank - opposite the master cylinder in my Oval. The thing is ridiculously loud. I too had read that this is the best location for it - pushing fuel rather than pulling. |
Posted: Tue Jun 21, 2016 3:31 pm Post subject: Re: Engine diagnostics request |
Rubber Duck wrote: |
Good luck! |
So when you had this similar problem, was it ever under load? Also, the conclusion was that your gaskets that mate your intake header to your heads were leaking? I'll check that before removing my carbs tomorrow. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
timvw7476 Samba Member
Posted: Tue Jun 21, 2016 11:34 pm Post subject: Re: Engine diagnostics request |
You aren't doing yourself any favor fastening the pump directly to the
sheetmetal cover of the fuel tank, it's like the surface of a snare drum.
If the PO did it, at least put a barrier of rubber mat sandwiched in there
to cut the echo-chamber effect. Run a separate ground wire if needed.
When it's loud, it's re-loading your drained carbs, or pumping vapor.
I use a rubber grommet isolated pump myself, into 34 icts. When you get
it set up, it is the lowest maintenance dual carb set around.
Your running issue could be just one float failing/maladjusted, keeping
the other 2 cylinder bogged down. |
Posted: Wed Jun 22, 2016 4:56 am Post subject: Re: Engine diagnostics request |
timvw7476 wrote: |
It isn't to the sheet metal below the tank, it's essentially on the frame. (No I didn't drill into the frame)
And I'm hoping it is the float too. That's be easy to fix. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Posted: Wed Jun 22, 2016 4:42 pm Post subject: Re: Engine diagnostics request |
Alright, so I took apart and cleaned out my carbs. They had some deposits in them, but nothing too bad. But what is interesting is my jetting set up. Ready?
Emulsion tube: f8
Air main: 160
Jet main: 130
Idle jet: 40
So, I went about the Weber setup proceedure: http://www.redlineweber.com/html/Tech/carburetor_set_up_and_lean_best_.htm
Needless to say it didn't work well. I had to turn out my mixture idle speed screw 3 turns and my mixture screw to two and a half. And I still had to gas it to get it going and heat up a bit. Before it would "run like a tractor".
Thoughts and opinions? Can I tune this but just suck, or do I need to change out my jets? If so. Suggestions on what jets sizes to try first? _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Posted: Thu Jun 23, 2016 9:57 pm Post subject: Re: Engine diagnostics request |
I assume the floats were both still good, and both needle & seats shut
off cleanly, I know it's a hassle with out an access panel but you may
have to idle it & check with a mirror, air filters off, to see if you have gas
pouring out the main venturi of one of those carbs.
Seeing as you already ran a different coil, the other problem is shorted
condenser, if you're running points for ignition. |
Posted: Fri Jun 24, 2016 7:40 am Post subject: Re: Engine diagnostics request |
timvw7476 wrote: |
yes, both floats were good and the needles and seats seemed to be working well. There was some junk in the float bowl, which i cleaned out. But there wasn't ton. I'll check my condenser/distributor and make sure it all is up to snuff tonight before my test drive. Thank you for replying. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Fri Jun 24, 2016 8:28 am Post subject: Re: Engine diagnostics request |
I would assume you need bigger idle jets to start with. Say 50, or 55? |
Posted: Fri Jun 24, 2016 7:49 pm Post subject: Re: Engine diagnostics request |
FreeBug wrote: |
I thought that and my main jet both seemed kind of small, just after reading what other people are running. But I have never touched jetting, this is actually my first time touching carbs before. Also first times for setting distributor points, setting timing, adjusting valve lash, and working on a air-cooled engine... lots of firsts. Lots of research. It has me a little freaked out on figuring out what is going on with my engine. But they seem pretty straight forward and I think I'll really end up liking their simplicity.
Anyways, once I get this thing running would you suggest I go someplace reputable to get my jetting done? or should I just get a jet kit and fiddle with it until I find something responsive that doesn't over heat my engine. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Posted: Fri Jul 08, 2016 9:05 pm Post subject: Re: Engine diagnostics request |
well, I'll be removing my gas tank for a quick cleaning early next week (Monday probably) and if that doesn't fix my problem I will be having it towed to a reputable shop in Detroit (Munks Motors) and hopefully they will be able to get it right. Unless anyone else has ideas on this topic. I'm sure I have left information out, so throw out ideas/questions if you want. Ill answer them asap.
Ive never had any of my cars towed to get fixed... It's so defeating. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
surfwagonorangevw Samba Member
Joined: February 06, 2013 Posts: 111 Location: Hawaii
Posted: Sat Jul 09, 2016 11:30 am Post subject: Re: Engine diagnostics request |
Baby Webers , ICT 34 -- my setup on a 2.0 type 4 is
idle 60 , main 160 , air 185 , emulsion f 6 . At sea level . |
volksnhousin Samba Member
Joined: July 18, 2006 Posts: 326 Location: Ellerslie, GA
Posted: Sun Jul 10, 2016 4:57 am Post subject: Re: Engine diagnostics request |
An air-fuel meter is a worthwhile investment, I think you can even rent one from Aircooled.net. if it's just for this once. |
Posted: Thu Jul 14, 2016 5:34 am Post subject: Re: Engine diagnostics request |
I dropped her off at Munks motors yesterday. Really nice people, even showed me the shop and current projects. They have a 10 day wait, but ill keep you posted on what it ends up being. The master mechanic's first comment was "I bet you have a contaminated gas tank"... I'll be kicking myself if that is what it is, because I was just too lazy to properly test for that...
So I'll keep you posted on what they find out.
Till later _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Slow 1200 Samba Member
Posted: Thu Jul 14, 2016 5:56 am Post subject: Re: Engine diagnostics request |
did you ever check the tank breather? |
Posted: Mon Jul 18, 2016 11:45 am Post subject: Re: Engine diagnostics request |
Slow 1200 wrote: |
Yes, I took the cap off the fuel filler, no change. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
