Glasser Samba Member
Joined: September 18, 2007 Posts: 1640 Location: Calgary Alberta Canada
Posted: Fri Jun 17, 2016 8:13 pm Post subject: Big horsepower buggies, What transmission??? |
So I need to do my homework here. I am in the early stages of planning a Porsche type 4 IV build. I don't think I will stroke it so it will be a 2365cc. Would be a 2.6 if I stroke it...
Anyways I need to plan this build so I have all my ducks in a row. Planning on adding rear disc brakes but the major thing I need to get figured out is what transmission to run.
Need some examples please of your big motors HP and what trans you are running. AND how you are driving it.
Can I go with a Type 1? Should I go bus and change the 1st,2nd 3rd, and 4th gears go get a decent ratio.
Keep in mind this type 4 will probably out last 2X any type 1 built so I need a trans set up that will do the same.
I am completely guessing but hoping to be in the 130 to 140 HP range. This may all change when I send the heads in to get checked for cracks. If they need to do any work on them then I'll be stuffing larger valves in and probably do some porting work. _________________ Brent
My build up http://www.thesamba.com/vw/forum/viewtopic.php?t=265364&postdays=0&postorder=asc&start=0
Project#2. Neighbors build up. http://www.thesamba.com/vw/forum/viewtopic.php?t=327008 |
slalombuggy Samba Member
Posted: Fri Jun 17, 2016 8:43 pm Post subject: Re: Big horsepower buggies, What transmission??? |
I run a type 1 box in mine, BUT, I run a weld in Berg midmount, steel rear mount, Kafer bar, HD side cover in a single side cover trans, urethane suspension bushings, bigger torsion bars and not so sticky tires. I don't do drag race starts, but once in a while I can paint some nice lines on the road. 200+ rwhp, 3 summers of fun so far, no issues.
brad |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20365 Location: Just a tiny bit west of Yosemite Valley
Posted: Fri Jun 17, 2016 9:33 pm Post subject: Re: Big horsepower buggies, What transmission??? |
Can you spell M-E-N-D-E-O-L-A ....
http://ranchotransaxles.com/mendeola-transaxles/
https://weddleindustries.com/transaxles/mendeola-s4s5-series
jsturtlebuggy Samba Member
Posted: Fri Jun 17, 2016 10:01 pm Post subject: Re: Big horsepower buggies, What transmission??? |
Ok you thinking about horsepower, but you also need to think how much torque the engine will have too.
Torque is what breaks transaxles.
What the rear tire diameter and width going to be?
You can get a 4.13 (4.125) ring & pinion for both a 002 and 091 Bus transaxles.
The Side gears and spiders in and 091 trans are the strongest in all the stock VW trans.
You can use 091 differential parts in an 002 trans.
One thing to remember is that aftermarket gears (1st-4th) are made for racing and are noisey. It can be more noise then you want to hear for extended period of times driving.
The quietest ones are Weddle Sportmans Gears, they are still noisier then stock.
I am using a Vanagon 5speed with a 2.5L Subaru in a Buggy. It is holding up well with 33in tires. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76760 Location: Sneaking up behind you
Posted: Sat Jun 18, 2016 3:44 am Post subject: Re: Big horsepower buggies, What transmission??? |
BERG 5, not much cheaper than Mendola but it gets the job done.
_________________ Glenn
Member #1009
#BlueSquare |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4026 Location: NW Washington
Posted: Sat Jun 18, 2016 8:35 am Post subject: Re: Big horsepower buggies, What transmission??? |
Get the 3rd and 4th gear hubs welded and run a stock trans.
As long as you don't launch like an idiot you should be fine.
If you want to do burnouts... then you can spend five grand on a transmission.
I slipped the hubs on two of my stock transmissions at 13 lbs boost which was probably around 130 hp. It just wouldn't shift anymore.
After the spare second transmission did it I had the first one rebuilt and 3rd and 4th gear welded. It needed a main bearing, a couple sycros and reverse gear replaced and adjusted for more engagement.
Cost me $350.00 and now shifts like butter and is holding at 22 lbs boost and who knows how much hp. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Sat Jun 18, 2016 1:06 pm Post subject: Re: Big horsepower buggies, What transmission??? |
clonebug wrote: |
Get the 3rd and 4th gear hubs welded and run a stock trans. |
I would add a GOOD side plate and a "Super-Diff" to that stock trans.
clonebug wrote: |
. . . don't launch like an idiot . . . |
Always PRE-LOAD before ya launch!!!!
And do what ever you can do to prevent wheel-hop!!!!!
PS . . . watched yer video Brent . . . cool car . . . sure makes me want to get my buggy going! _________________ Jesucristo es mi Señor y Salvador! |
Posted: Sat Jun 18, 2016 4:53 pm Post subject: Re: Big horsepower buggies, What transmission??? |
Thx for all the replies guys. Yes she should be a torque monger and this has me thinking I'll need to change up my gearing. Right now I have a trans out of a squareback. I believe 4:11 gear ratio. It works great for the 1776 but with this 2365 it would be a waste of torque. As it is now I can't get through an intersection with out RPM sky high when on it. Maybe a regular beetle trans gearing might work better with these tires. 245/60 26" tall.
Neutral drops are not my thing, preload and go like hell is. I'm hoping this engine is going to brake the tires loose once rolling and then on it.
I can't imagine that I'm going to be in a class of my own here, that is why I'm calling out for big HP buggies to see what you are all running. If it's working for you, should work for me. The gearing interests me. I mean the gearing I have now will work.... 110 Kmph at 300RPM. But will it be getting the most out of my engine is the question.
Thx Blitz! _________________ Brent
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15280 Location: Deep in the 405
Posted: Sat Jun 18, 2016 6:22 pm Post subject: Re: Big horsepower buggies, What transmission??? |
For a 150 HP street Buggy a well built type I is all you need. Don't know where you live in Canada but ask Bruce about a gearbox. http://www.thesamba.com/vw/forum/profile.php?mode=viewprofile&u=425 _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Sun Jun 19, 2016 7:48 pm Post subject: Re: Big horsepower buggies, What transmission??? |
I agree..... _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
63Fiberbuggy Samba Member
Posted: Tue Jun 28, 2016 4:45 am Post subject: Re: Big horsepower buggies, What transmission??? |
My engine ~300 Hp (Garrett T3/4 custom turbo by G-Pop, SuperFlo heads, 2276cc, FK-8, etc/etc); rears are 295/50/15s. Tried stock '67 T1 tranny & even without dropping clutch, it got where wouldn't shift. Contacted Geno Boyd for "performance pro street" build & switched to 3.88 R&P; love it! Stayed with stock gears at his recommendation. He has many years of race experience and work at Rancho; in fact his parts come from Rancho. I'd contact him and ask for advice; that's what I did and I'm very satisfied with results.
Will break tires loose after full release & rolling 1st or 2nd gears; so much so that I spun a wheel adapter last year...scary when left rear was hanging on by 1 lug. |
