PatsGhia Samba Member
Joined: December 20, 2015 Posts: 21 Location: Los Angeles, CA
Posted: Mon Jun 13, 2016 8:41 am Post subject: New Motor Noises (Long) |
I've built a few VW motors in the last 30 years, but I'm stumped on the sounds I'm hearing on the latest I built for my Ghia. So I turn to you all for some fresh ears. The motor specs:
New Brazil case, reground stock VW crank, rebuilt stock VW rods, used low-mile 87mm KS pistons/cylinders, CB 2280 cam, Brazil lifters from CB, stock rockers, stock push rods (9mm), rebuilt 040 heads with HD single springs, CB filter pump w/ Wix filter. Deck height: cyls. 1,2,4 = 0.063", cyl. 3 = 0.069".
Ran the motor at approx. 2000 RPM for 20 minutes to break-in the cam, then changed the oil/filter - no unusual amount of metal in the oil.
Here's a video of the motor running:
Here's what I've tried, with NO change in the sound:
- Run without the alt/fan
- Run without the fuel pump
- Pulled each plug wire one at a time
- Adjusted valves at TDCs - 0.004" intake, 0.006" exhaust
- Adjusted valves opposite from max lift valve @ 0.006"
- Stock rocker shaft setup
- Solid rocker shafts (CB) w/ approx. 0.003" side play per rocker
- Push in clutch pedal
Have also checked:
- Stethoscope on engine shows noise loudest at the rocker covers
- Crank end-play still good (approx. 0.004")
- Cam gear bolts all tight
- Cam end-play still good
- Brass dist. drive gear good
- No exhaust leaks
- Cylinder leakdowns all 2% or less
- No bent pushrods
- Oil pressure at idle: 40 psi cold, 15 psi warm (VR1 10w-30)
I'm wondering if this noise can be from some sticking intake valves. I ask because I pulled the valves after the heads were rebuilt to check everything out. The intake valves only had around 0.001" to 0.0015" clearance to the guides (new valves/guides). I figured since they were rebuilt by a well-respected shop, they know what they're doing and ran them as-is.
Anyway, I would really appreciate some help on this one... |
raul arrese Samba Member
Joined: July 23, 2006 Posts: 1330 Location: miami florida
mark tucker Samba Member
Posted: Mon Jun 13, 2016 9:02 am Post subject: Re: New Motor Noises (Long) |
adjust the valves using the preeload method, move the pully tin away from the rear of the pully. look for pushrod to pushrod tube clearance issues. look for head studs contacting any rockers. recheck side clearance. look at geo .check to see if the pushrods&rocker cups are interfearing with each other if using oe style pushrods |
Posted: Mon Jun 13, 2016 4:39 pm Post subject: Re: New Motor Noises (Long) |
raul arrese wrote: |
does the motor make noise when you first start it or after warm ?? |
Noise is the same cold or warmed up. |
Dougy Dee Samba Member
Joined: August 21, 2004 Posts: 1669 Location: Niagara Region, CANADA
Posted: Mon Jun 13, 2016 6:16 pm Post subject: Re: New Motor Noises (Long) |
Curious about the mismatched 3-4 side DH.
Is #3 cylinder higher than #4?
How did you get that to seal to the head?
Was the top of #3 cut?
To me the noise seems exhaust related. |
Type 5 Joe Banned
Joined: January 18, 2003 Posts: 1795 Location: Oregon
Posted: Mon Jun 13, 2016 6:21 pm Post subject: Re: New Motor Noises (Long) |
Sounds like the piston is hitting the head slightly. |
modok Samba Member
Joined: October 30, 2009 Posts: 26787 Location: Colorado Springs
Posted: Mon Jun 13, 2016 7:47 pm Post subject: Re: New Motor Noises (Long) |
sounds like a diesel, so, ah, I'll guess it has something to do with a piston |
Brian Samba Moderator
Posted: Mon Jun 13, 2016 8:51 pm Post subject: Re: New Motor Noises (Long) |
modok wrote: |
If a piston is in upside down, you'll find out on the freeway. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Posted: Tue Jun 14, 2016 3:35 am Post subject: Re: New Motor Noises (Long) |
PatsGhia wrote: |
Hmm . i was gona tell you too check valve lash when hot but that not relevent now if its the same hot or cold .. check all the stuff Mark recomended. _________________ " Hot vw feature , may 2014 issue "
" 2013 Bug Jam class winner "
" Bug Jam best motor and best paint "
" 2013 Lakeland Classic Best of Show "
" 2014 Show and Shine , First in class "
Like my facebook https://www.facebook.com/pages/Raul-Arrese-custom-fabrication-and-performance/1832968110262608 |
yamaducci Samba Member
Joined: March 30, 2010 Posts: 2335 Location: Mount Airy, Maryland
Posted: Wed Jun 15, 2016 1:21 pm Post subject: Re: New Motor Noises (Long) |
Not necessarily. Was it set wrong to begin with? Are you experienced with adjusting valves? What is the lash set to?
Edit: I see that you have them at .004 and .006. Check them again to see if they are still there and check to make sure the rockers aren't hitting the covers or if you have too much side play. What the heck; just run them with no valve covers. _________________ -John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
3rd Brake Light Safety Stars- I still have a couple with blue light left. Email me if interested. |
Posted: Thu Jun 23, 2016 8:01 pm Post subject: Re: New Motor Noises (Long) |
Tore the engine apart and found out that the cam ate into the thrust bearing, leaving the end-play at 0.013" - I set it at 0.002" on build. I'm pretty sure this is what was making the noise at low RPM. I guess I didn't do a good job of checking the end-play in the car.
On further inspection, the part of the cam that ate the bearing was rough, so I'll have to smooth it out. Everything else looks good. I'll report back whether this was the problem. |
modok Samba Member
Posted: Thu Jun 23, 2016 8:17 pm Post subject: Re: New Motor Noises (Long) |
A lot of people make that mistake, it does not usually make any noise. |
richparker Samba Member
Joined: November 24, 2011 Posts: 6982 Location: Durango, CO
Posted: Mon Aug 01, 2016 3:57 pm Post subject: Re: New Motor Noises (Long) |
Put in new cam bearings (double thrust to be safe), and the engine sounds normal now thankfully! The thrust surface on the gear side of the cam was parkerized, so I smoothed that out. To future aftermarket cam users, check out those thrust surfaces! |
Frank Bassman Samba Member
Posted: Mon Aug 01, 2016 6:16 pm Post subject: Re: New Motor Noises (Long) |
Hm, I made the mistake once of setting the valves thinking I was on #1 rather than 3. So I adjusted #1 but the motor was really on #3 TDC. And followed the consequent sequence.
Sounded like a diesel. Ran fine though. When I realized the mistake I made I re adjusted and the engine sounded like the good little sewing machine it was supposed to be.
Any chance that is what happened, and when you split the case you put it back and adjusted correctly the second time? It happens!
I DOUBT the changing of cam bearings was what fixed it. Either way congrats on getting it properly done.
-Frank |
