arizonabuckeye Samba Member
Posted: Sat Jun 11, 2016 1:11 pm Post subject: running after ignition turned off - possible relay problem? |
Fires up nice and runs fine. When I turn off ignition it keeps running like nothing happened. When I pull the power from a Bosch relay to my MSD 6AN box it kills it. I checked the relay and it works fine without the car running - ~12 volts to the MSD with key on none with it off.
Have you guys heard of these sticking on in different circumstances? Like it functions fine without the car running but sticks with it on?
And to save the bother... I have the relay (instead of running the MSD straight from the ignition) because it also powers an external oil cooler. |
Chip Samba Member
TinCanFab Samba Member
Joined: April 04, 2006 Posts: 2743 Location: Waterford, California
Posted: Sat Jun 11, 2016 1:20 pm Post subject: Re: running after ignition turned off - possible relay problem? |
Your MSD should have come with a resister in the kit. Wire it inline with your warning light wire at the alternator. The CDI box is getting back feed through that wire and keeping the spark going to the plugs. The MSD instructions have a section that talks about it. I just did this job on my bus 2 months ago _________________ Check out my truck brought back from the dead... http://www.thesamba.com/vw/forum/viewtopic.php?t=420762&highlight=sprayed+blood
They're never really ever finished 58 rag build...
http://www.thesamba.com/vw/forum/viewtopic.php?t=658092 |
Mikedrevguy Samba Member
Joined: October 15, 2008 Posts: 2234 Location: Medford, OR
Posted: Sat Jun 11, 2016 1:24 pm Post subject: Re: running after ignition turned off - possible relay problem? |
Good information for those of us who may not have purchased their MSD knew in box.
Rev. _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!! |
Posted: Sat Jun 11, 2016 1:31 pm Post subject: Re: running after ignition turned off - possible relay problem? |
So glad I didn't just swap out the relay thinking it was toast. I'll have to check into it more. The MSD is from the PO so I will have to check and see if it was done. |
tattooed_pariah Samba Member
Joined: April 24, 2006 Posts: 2047 Location: El Cajon, CA
Posted: Sat Jun 11, 2016 2:26 pm Post subject: Re: running after ignition turned off - possible relay problem? |
In the meantime, I've found that tapping the brakes draws enough power to the brake lights to stop the flow and kill the engine with mine..
Nowadays about 95% of the time it shuts off with the key, the other 5%, a quick brake tap does the trick.. _________________ -pariah (just a novice from "that other VW site")
'72 Volksrod "Effigy"
"Never worry about stepping on people's toes. People who get their toes stepped on are either sitting down, or standing still on the job."
-Admiral Arleigh Burke, USN(ret.) |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20365 Location: Just a tiny bit west of Yosemite Valley
Posted: Sat Jun 11, 2016 5:08 pm Post subject: Re: running after ignition turned off - possible relay problem? |
Radio Shack diode 2 @$1.99 ...
https://www.radioshack.com/products/3-amp-400v-diodes?variant=5717579653
Posted: Sat Jun 11, 2016 5:10 pm Post subject: Re: running after ignition turned off - possible relay problem? |
tattooed_pariah wrote: |
Nowadays about 95% of the time it shuts off with the key, the other 5%, a quick brake tap does the trick.. |
Add a diode and never have to tap brakes again...
Posted: Wed Jul 06, 2016 11:49 pm Post subject: Re: running after ignition turned off - possible relay problem? |
Would swapping the distributor bulb for an LED do the trick? |
Drewmon Samba Member
Posted: Thu Jul 07, 2016 4:56 am Post subject: Re: running after ignition turned off - possible relay problem? |
HOLY CRAP....
I've been trying to fight this issue for 2 months. I too have this same issue with my 66 (with MSD). I've just got so use to pushing the brake to stop the motor. I'll have to look into this ASAP. I'm so glad this topic resurfaced.
Does anyone know the resistor values or diode part number? |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Thu Jul 07, 2016 5:03 am Post subject: Re: running after ignition turned off - possible relay problem? |
arizonabuckeye wrote: |
Nope, may even make it worse (eliminate the ability to stop with brake tap) since LED's need less current to illuminate than a comparable incandescent. |
Posted: Thu Jul 07, 2016 7:08 am Post subject: Re: running after ignition turned off - possible relay problem? |
Bashr52 wrote: |
Its the amount of current flow through incandescent bulb which is causes run on problem which more than a actual led will allow, problem with trying to use LED is it needs more circuitry to work as a ALT/GEN lamp indicator, the additional resistor in LED circuit then causes the run on problem problem because if increased current flow though resistor... The actually LED only illuminates because of current/voltage change across resistor...
This circuitry needed to use LED as ALT/GEN idot lamp...
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Thu Jul 07, 2016 7:10 pm Post subject: Re: running after ignition turned off - possible relay problem? |
Drewmon wrote: |
Radio Shack # 276-1103 |
Posted: Fri Jul 08, 2016 5:07 am Post subject: Re: running after ignition turned off - possible relay problem? |
I looked through the MSD box and found the diode. I made a pigtail to attach to the Alt light (Had to wire the diode backwards because of the -/+ being reversed in the light cluster) and hooked it up. Now the VW actually turns off when turning the key off.
Thank you everyone. I thought the switch in my column was bad. |
Posted: Fri Jul 08, 2016 8:53 am Post subject: Re: running after ignition turned off - possible relay problem? |
Drewmon wrote: |
This is my project for the weekend. Any pics? |
Posted: Sun Jul 24, 2016 2:12 pm Post subject: Re: running after ignition turned off - possible relay problem? |
Have 74 super with external regulator:
Any reason the diode could not be inserted at the regulator side of the D+?
For those of use without any radio shack, any place carrying a 3v 50 will do?
Any suggestions? _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
Posted: Sun Jul 24, 2016 3:08 pm Post subject: Re: running after ignition turned off - possible relay problem? |
If you have run on with external regulator diode may fix, but wont hurt anything...
No Radio Shack?... Try local auto alarm/stereo store, ask for "blocking diode"....
Posted: Sun Jul 24, 2016 3:23 pm Post subject: Re: running after ignition turned off - possible relay problem? |
So shouldn't need a diode with an external regulator?
Radio shack went out of business here. _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
Posted: Sun Jul 24, 2016 7:22 pm Post subject: Re: running after ignition turned off - possible relay problem? |
Have not heard of using diode on external regulator, but there is always a first.....
Stat it up, shut it off with key, if you have run on, pull wire off terminal 61 of regulator, if it dies, add diode, if it continues to run, problem is else where..
Yep most RS stores are closing, guess mother company is not surviving bankruptcy...... Sears/Kmart is next in line to close many stores....
Posted: Sun Jul 24, 2016 8:41 pm Post subject: Re: running after ignition turned off - possible relay problem? |
Thanks, Dale. Appreciate the help.
76 914 with 2260
79 VW Iltis
69 Bwajaja
