67vwcruising Samba Member
Joined: March 31, 2015 Posts: 127 Location: Carson City NV
Posted: Thu Jun 09, 2016 7:53 pm Post subject: oil temp on new build |
I'm having an issue with the oil temp on my rebuild.
when i'm driving highway speeds 65-70 my temps creep up to 230+
that's when i let off and try to cool down. Driving city speed doesn't do much to drop the temps back down.
I've tried everything I've read on the forum and had no luck.
The build is as follows:
1699 74x85.5 full balanced.
kueltek cam (same as an engle 100)
8.5:1 compression
kadrons 140 mains and 55 idles.
009 30 deg at full advance
doghouse with all tins
the motor runs smooth and pulls strong but runs hot.
i have 300 miles on it and when i did the first oil change at 200 miles there wasn't a single speck of metal so i don't think its an internal issue.
anyone think of something i missed? |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76912 Location: Sneaking up behind you
Posted: Thu Jun 09, 2016 7:58 pm Post subject: Re: oil temp on new build |
New engines run hot due to tight tolerances.
Try backing the ignition down to 28*. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Thu Jun 09, 2016 8:12 pm Post subject: Re: oil temp on new build |
I'll try that. Thanks for the quick reply!
i love how this engine drives! i hope im able to get the oil temp under control! |
Posted: Thu Jun 09, 2016 8:25 pm Post subject: Re: oil temp on new build |
i forgot to mention there is a flat spot any time im driving and try to go further than 2/3 throttle. i went from 132 to 140 mains and it didn't help
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15303 Location: Deep in the 405
Posted: Thu Jun 09, 2016 8:44 pm Post subject: Re: oil temp on new build |
Just curious exactly what oil temps do you consider safe and being under control?
Have you verified the accuracy of your temp gauge with anything else? Where are you measuring oil temps? _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
Posted: Thu Jun 09, 2016 8:45 pm Post subject: Re: oil temp on new build |
what oil and what oil pump are you using? What is your oil pressure at speed? _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Posted: Thu Jun 09, 2016 9:20 pm Post subject: Re: oil temp on new build |
I know that 190 to 210 is considered operating temp. i think that on a hot day even 220-225 would be ok. But when i pull off the highway my temps are 230 and climbing. I put a meat thermometer in the dipstick tube and it matched my vdo gauge.
I'm running a 26mm or 28mm(its bigger than stock) pump with 20-50 VR1 valvoline
even when i'm pushing 230 degrees the oil pressure is still 10lbs per 1000rpm
I've never seen more than 40 psi oil pressure even cold and it takes 15-20 seconds to show changes on gauge. i think this might be due to the fact that i'm using air brake line for my gauge. its pretty flexible. |
Frank Bassman Samba Member
Posted: Thu Jun 09, 2016 9:41 pm Post subject: Re: oil temp on new build |
Go down to a 30 or 40 weight oil. Of whatever single dual viscosity suits your fancy. I like shell but it's just me. 20-50 is probably way too thick for your new motor. I broke in my 1699 with 30 weight straight.
If your car is so equipped, change the oil filter.
Report back. |
wcfvw69 Samba Purist
Posted: Thu Jun 09, 2016 9:50 pm Post subject: Re: oil temp on new build |
67vwcruising wrote: |
X2 on that road tar 10-50 being way too thick causing the high oil pressure to by pass your oil cooler. I'm in Phoenix and only run 10-30 oil with low mileage engines in my VW's.
There was a thread yesterday where another guys dip stick warning light sensor was triggering on freeway runs. He also was running that road tar. He dropped down to 10-30 and his problem went away. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Thu Jun 09, 2016 10:18 pm Post subject: Re: oil temp on new build |
I can definitely try a lighter weight oil. My aircooled parts guy said I needed 20-50 for the summer here in Reno. Anywhere from 60° to 100°f
If 10-30 isn't too light I'll give it a try. |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Thu Jun 09, 2016 10:27 pm Post subject: Re: oil temp on new build |
I run a full synth 5-40 here in southern Idaho with no problems. I'd wait for a couple of oil changes then switch over (if you want).
(Don't ask for advice from that parts guy....) |
JohnnyRingo Samba Member
Joined: October 22, 2011 Posts: 415 Location: United States
Posted: Fri Jun 10, 2016 1:35 am Post subject: Re: oil temp on new build |
Stick with Valvoline vr1 it has the proper zinc.....in order to cool oil down, you need to cool the heads. Have you tried the porshe 356 alternator pulley.....it will make a huge difference. 10/30 makes my engine run hotter here in NC......straight 40w gives the best results in my 1904 stroker motor built by Pat Downs at cbperformance. You can buy the pulley at stodderds, and I purchased the 36mm stainless nut from jorg. Also bigger displacement requires more air flow in an early bus. |
ALB Samba Member
Joined: August 05, 2008 Posts: 3483 Location: beautiful suburban Wet Coast of Canada
Posted: Fri Jun 10, 2016 5:21 am Post subject: Re: oil temp on new build |
What is this in? In older cars with increased displacement, doghouse fan and dual carbs, sometimes you have to increase air intake into the engine compartment. Do temps change driving with the engine lid open slightly? _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
flat4olsen Samba Member
Joined: February 20, 2014 Posts: 342 Location: Denmark, Europe
Posted: Fri Jun 10, 2016 5:31 am Post subject: Re: oil temp on new build |
ALB is right on that one. There is no way, that the tiny vents under the rear window can supply both carbs and the doghouse fan with enough air to share. VW knew that , when they put more and more vents in the engine lid. I would put a stand of on the lid, or just do the tennis ball trick on the lock.
If you drive a 1967, which your name suggest, then you have no vents, and definately need more air to cool the engine! |
Posted: Fri Jun 10, 2016 6:37 am Post subject: Re: oil temp on new build |
It is a 67 but does have a vented deck lid. I think the head temps are fine. I used a infrared thermometer and only see around 260-300 head temps. [/list] |
Posted: Fri Jun 10, 2016 7:36 am Post subject: Re: oil temp on new build |
http://www.thesamba.com/vw/forum/viewtopic.php?t=656654&highlight= _________________ Contact me at [email protected]
Posted: Fri Jun 10, 2016 8:00 am Post subject: Re: oil temp on new build |
you have to stop and get out of car to check head temps w/gun........get a Dakota real time cylinder head temp gauge.....then you will know???????? |
PumaVW79 Samba Member
Joined: January 31, 2012 Posts: 487 Location: WGS84: 22.9083° S, 43.1964° W
Posted: Fri Jun 10, 2016 8:31 am Post subject: Re: oil temp on new build |
Glenn wrote: |
New engines run hot due to tight tolerances. |
If an engine is running hot due to tight tolerances it's because those tolerances are too tight -- hence out of specs -- not allowing the oil to coat the mating surfaces in order to reduce friction. Higher friction translates to heat.
Two random pics from internet:
"Oil Starvation / Marginal Oil Film Thickness."
Posted: Fri Jun 10, 2016 9:00 am Post subject: Re: oil temp on new build |
VR1 10-30 will lubricate better and run cooler than the 20-50 you are using now.
Change, and if the temps don't drop you can change back. But the 10-30 will drop oil temps a lot. Right now your cooler is being bypassed due to too much pressure. _________________ It's just advice, do whatever you want with it!
Posted: Fri Jun 10, 2016 11:49 am Post subject: Re: oil temp on new build |
Ok. This afternoon I will try a lighter weight oil and maybe dial the advance to 28° and see if that helps. |
