Fan whine
Page: Previous  1, 2, 3
nick wharton2
nick wharton2 is offline
PostPosted: Thu Jun 23, 2016 3:06 pm    Post subject: Re: Fan whine Reply with quote
theDrew wrote:
so if I wanted to get rid of this noise......what do I do to the shroud without compromising cooling? (if even possible)
I recommend checking the plate directly below the fan that is spot welded to the front and back pieces of the shroud. If to close to the fan, it will create this noise. We used to tin snip this spot and bend it closer to the fan to create this noise. As I mentioned earlier in this post.
cheap, fast, or reliable. Pick two
unless you're sponsored Wink
theDrew
theDrew is offline
PostPosted: Sun Jul 31, 2016 10:23 pm    Post subject: Re: Fan whine Reply with quote
you were correct. I pushed that piece of tin in the bottom of the shroud to be farther away from the spinning fan and whallah! no more whine! Makes me happy! thanks for all your help.
now onto the next problem....
Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
1985 Vanagon Campmobile w/ 2005 EJ25
Page 3 of 3
